Looking for: Grace 707 Tonearm anti skate weight
Any thoughts, suggestions or help gratefully received.
chris
Anything can be used for the weight on the end of a fine nylon thread.  A small nut, blob of bluetak, etc will all work fine.
ProJect sell a replacement bias weight that's affordable, and probably the easiest available.
Thanks. I checked out the project one but it’s not what I need.
have attached a pic so you know what I mean.
it’s a small donut  with a thumb screw to tighten
chris
Where about are you.
I have a spare tonearm you can have.
I cracked the mount where the tonearm lift goes by over-tightening it.
I'm located at Ipswich QLD.
  • Like 3
I am in the same search as you.
You could use also 840's ones they are similar or try to fabricate one ,they are about 2.4 grams as I remember and the hole for the post is 0.9 mm in diameter.
Amazing!  Thank you.  I am just round the corner. Karana Downs.
* edited due to being an excitable dumbass. PM sent
chris
Edited by W47ty
7 hours ago, Antipodean Brad said:
Chris,
It is advisable to not put phone numbers in posts: a PM (Personal Message) is the place to do it.
Hope it goes well.
You’re quite right. Excitement got the better of me whilst rushing around. Good tip duly noted.
