Omni-directional bass - when does it start and why?
Why does bass become omni-directional? The oft-quoted point is 80Hz, but why would that be? And is it true everywhere?
It is due to the distance between your ears (>30cm, but probably <40cm) relative to the sound you're trying to localise? For me, the distance between my ears would be about 7% of the length of an 80Hz wave. Would that be a suitable yardstick?
Or is it due to the size of the room that you are in? Where the shortest dimension of your room determines when the localisation of your bass becomes difficult? So, say, in a 7 foot ceiling room, that half a wavelength of an 80Hz signal - and with a 9 foot ceiling, that becomes 65Hz? Or is it more complex than that?
And is there an absolute limit to where you cannot determine where something is coming from? One example from freespace is thunder, as after the initial clap, the rumbles (40-100Hz) are easily followed even if the eye did not see the bolt of lightening. This is obvious when you live in the Top-end, as the lightening is mostly sheet lightening, from cloud to cloud, and you don't always see it. But you can definitely follow it by ear. So it seems that it's easier to localise lower frequesncies outside, rather than inside.
Are there any technical articles on the subject?
Hugh Covill trying to explain treating subwoofers as an array Demystifying Directional Bass from Audio Technology (Hugh Covill)
An article on the Kii Three and that (but not how) it attempts  to make the speaker more directional at low frequencies by cancelling out some of the almost omnidirectional bass that comes from the main driver Does hi-fi end here? from The Rational Audiophile
Frequency Analysis of Thunder Features
Edited by Cloth Ears
“the Occasional Podcast” had an episode posted 6/4/21, “Subwoofers & 2 channel audio: everything you ever wanted to know “, a deep dive with SVS Director of Technology Ed Mullen.
It wasn’t actually too technical but did have some interesting points (for me anyway). He did cover the questions in your post, and much else. I found it worth a listen.
Direction is figure out using differences in phase and level in each ear.
At high frequencies is is mainly level differences (not phase) .... part of this reason is that the head is too big.
Below about 1000 hz ... the head is small enough not to mess with the phase .... and so phase starts to dominate.
Below about 300 hz .... level differences are almost gone.... any sound will start to sound the same loudness in both ears.
Below about 80 hz .... phase differences are almost gone .... a sound arriving from (for example) hard left, has approximately the same phase in both ears.... and all ability to tell the direction is gone.
Yes.... but it starts to get complicated with headphones.... where level and phase differences can be achieved, at LF.
... but two things happen.    Your brain is not used to processing it (and so doesn't "hear" it as much as maybe expected).... and conduction of sound through the head is very significant.
80Hz signal
80Hz is often chosen because if the is the "crossover point" with a steep-sh filter, then the level is suitably low by ~200 and definitely ~300 Hz to be swamped by sources which are "in the right place".
It can be difficult to do these experiments because is requires low distortion and "point sources"...... but error in the experiment tell us we can "hear bass to lower frequencies" than we actually can.
So it's somewhere around 200hz .... but most people don't believe that because when they try it that can "hear stereo" a lot lower .... but they're not testing it right  (distortion, rattles, etc.)
It simple... thunder is easy to localise as it contains high frequencies.
No.
Yes... Rooms if anything make it worse, as the room is relatively small compared to the sound wavelength.... but the effect still exists in full force outside.
At low frequencies, the kii three operates all of it's woofers in phase.
At middle frequencies (eg. 100 to 800) it uses the side and back to cancel the sound, and increase directionality.
There is a LOT of merit to narrower coverage (increase directionality) in the range between ~200 and 1000..... it offers a HUGE improvement in clarity..... but avoids the "in your head" effect from headphones.
IMVHO it is the fundamental reason why speakers like horns, dipoles incl kii three (can) sound so much better.    (I say "can" as not all are well designed).
  • Haha 1
So, Dave, to use a stupid example to illustrate a serious point, an alien with a metre wide head would be able to localise sound to a lower frequency than us simple humans?  Given that he has similar hearing instruments to us humans and not a thousand sucker-like nodules oozing green slime?
Dave, you keep saying that. But that means that every subwoofer I've ever heard has distortion and rattles enabling it to be located (if not pinpointed). Relative to the wavelength of the sound, you should be able to localise down to 10% (if not 5%). I mean, there are people on this site who can hear the difference between frequencies that are 1/64 tone different (that Music Lab test), so surely L/R at some lower frequencies should be possible.
But I've yet to see an article that explains it to me.
Don't shoot the messenger?!  ;)
Shrug.
Many subwoofers produce high amounts of non-linear distortion when played at realistic levels.
As an example.... At 200Hz, the distance from ear to ear is extremely approximately 10% of one wavelength.... and there is basically zero level difference.
... and because when you move, or turn your head, it doesn't change.... your listening system has evolved to not consider it "information".
https://en.wikipedia.org/wiki/Sound_localization
1 hour ago, deepthought said:
This paper certainly seems to suggest that people can perceive left to right movement of low freqs (30-60hz) in reverberant rooms - https://www.acoustics.asn.au/journal/2014/Vol42No2_DEAN.pdf
Quote
It is important to bear in mind (as detailed in the Appendix), that while the digital signal leaving the MAXMSP synthesis in each case contained very little energy at frequencies above 200 Hz, that generated by the subwoofers contained some energy detectable above the acoustic background of the studio, in some cases at frequencies up to about 600 Hz. Correspondingly, sending high dB sine tones to the speakers produced pitch-discernible audible sound at least up to 1000 Hz. Thus even ‘clean’ low frequency sounds as presented by these excellent speakers will always contain higher frequencies. The same observations held for larger (much more expensive!) Meyer subwoofers
Aside from the above (which doesn't necessarily explain what they observed) ....  it's important to undcerstand that the paper is not talking about "being able to hear where the subwoofer is"
.....  but about the creation of a spatial effect using multiple subwoofer, each producing different content... ie. being able to hear a different, or even "moving" spatiality (is that even a word, lol) to the sound, based on multiple tones.
I touched on this in the other thread (erplying to AndyR).    Yes, it can be possible to encode stereo effect into LF sound like this "articifically" (which isn't a negative connotation, just noting that you wouldn't get this effect from any typical "real" multi-mike recording).    If you play it back in your room, you won't necessarily get the same effect heard by the person creating it.... which is a big part of why it isn't typically done.
"I conclude that musically-experienced listeners have good capability in relation to location/lateralization and movement perception of low frequency sounds in our reverberant studio environment, though movement accuracy is much lower than location accuracy, as normally observed."
So his conclusions are not correct?
OK - in that case, I think we might be in agreement (say it ain't so...LOL). Just created a test set of tracks, with ~32-37Hz signals in both left and/or right channels. And also with "in-phase" and "out-of-phase" frequencies - by "phase", I mean that the peaks of the sine waves were either in-sync, or exactly out of sync (peaks to troughs). Is there a name for that?
And, with only the bass amps on, I couldn't locate the sound with my ears as to whether it was left or right. Actually, I could, but only with practice of listening to the tracks more than once and then being able to know it's coming from one speaker or the other. Pretty obvious when the signal was both channels, as it would be slightly louder (if "in-phase") or weirdly lobing (if "out-of-phase").
Left and right was different. I could tell when the signal was coming from one or other channel, just not which one. And, I expect, I would have the same issue with the bottom end of my main speakers if I used a 60Hz signal. As my bass modules are directly below the main speakers, they should be time aligning properly. But I also think that if the signal was in mono, rather than stereo, I would be getting a different sonic picture than I am getting from having the stereo signal being sent to the correct speakers.
Yes!    If you measure your channels carefully.... they will not be the same.   They sound different.    Your brain can hear different.... and it tries to tell you information because of the difference.
Time alignment of the bass, is only relevant as far as it relates to summed levels.....  You should make sure the overall levels of everything are the same/correct .... as difference in level is very audible.... (See above)
Being able to tell them apart.... isn't the same as being able to actually hear the location of the woofer.   Your brain is more sensitive to chages of level in the bass.... or any difference between the two is very obvious.... and leads to "I can hear something".
If we do identical bass tones, we can't hear where thy are coming from.
If we do different bass tones (ie. stereo bass) .... then we can hear something.... but this "something" doesn't rely on the location of the subs.   The can be front/back.... left/back... wherever .... and we get the same(similar) effect.    The effect will be different for every room/setup.... which is why it isn't done  (and why it is standard mixing practise to make bass mono).... and why when artists try to make such bass effects, they usually stipulate they should be listen to on headphones, as hen the bass effect is the same for everyone.
For the rare occasion there is stereo bass in a recording, it is usually either:
Panned full range signal..... which doesn't provide such "bass effect" .... and so you can't hear anything (it just sounds mono) ... and you could send the bass to every subwoofer location, and it would sound the same.
Multi-mike "stero/milti" recording.... eg. mike stage left... mike stage right.....  but unless there is big separation, and no room (or huge room) the effect is not what you'd expect...... and then... you can't play it back (the same as recorded) in a small room, as the bass just mixes together..... which is why it isn't (or rarely) done (bass gets mixed mono).
Except when you get recordings done using a crossed pair of mikes (like Clark Terry Live at the Village Gate). Now, in that one you can see (with the right tools) that the bass isn't mono'd, but also that there also aren't any fundamentals down low enough to really matter (in the context of this discussion). In other words, you can always tell that the bass is slightly to the left of centre stage and the drums are to the right of that.
Or maybe I've misunderstood you.
How far apart are the microphones?    If they're not (quite) far apart then the bass entering each mike is practically the same level and phase  (so you can't record stereo bass).
... but it depends on how far, and what frequency.
Bass and drums both have lots of high frequencies (even in their "low frequency bits".... as they are short sounds, with wide bandwidths).   So unless you are filtering out everything above 80hz, then of course you can tell their direction.
As far as I'm aware, using a coincident pair of directional mikes for stereo recording needs them to be at 90 degrees (or greater for some types) and as close as possible without touching.
Right... so it cannot record stereo bass.... because it is not directional at low frequencies, and they are too close together.
Are you referring to the classic "Blumlein pair" recording mike config? 2 recording mikes co-located at 90 degrees?
Unfortunately not used much these days - most recordings are close miked...
...with a recording done on on a Blumlein pair you get a real sense of the space the recording was done in with a good playback system...
...but what @davewantsmoore is saying is correct - there's no stereo bass in anything captured by a Blumlein pair - the mikes are too close together compared to the long wavelengths of bass.
cheers,
Mike
cheers,
Mike
Yet, in this recording you can tell where everyone is on stage, including the double bass, the pieces of the drum kit and the way the piano is set-up. And you can see (looking at the digital stuff) that the bass notes of the drums, DB and piano are not in the 'centre' (i.e. not a mono signal), they are in the same 'location' as the attacks on the various instruments.
So, what has been recorded?
I suspect your ears are getting the location information from the “attack” part of the sound and your brain is putting it together with the low part.
If you applied a low pass filter my guess is that you’d lose the ability to locate those instruments.
Sorry if I missed it, but typically at what frequency is the transition from mono bass to stereo?
I remember speaking to an audiologist during a medical check re this topic and she explained that there is "some evidence" to suggest that "around" 300Hz directionality is decreased /lost for those who do not speak a tonal language. For those who speak a tonal language, it is around 200Hz.
My wife's native language is tonal (and her ears actually work) so if she tells me something sounds good, I nod wisely and agree - I use her to set up my system (particularly handy getting her to lift the big amplifiers......) and she has always got things pretty much right.
Interesting, but my question was about what is contained within a typical recording.
Are stereo recordings devoid of 200 - 300Hz?
If there is an "attack" (although what is "an attack" could be subjective, so it's hard to do this via the internet) then this means it contains high frequencies..... and so the low pass filter is some how insufficient.
Becauae all of thse instruments contain lots of high frequencies.... a bang on a bass drum contains lots of high frequencies.
That's my question, at what frequency does the typical average recording stop being stereo and become mono?
~100Hz.... although it can be  bit higher in a room.
  • Thanks 1
Ahhh.... you mean in a typical recording (by comment before was about what you can hear).   It's hard to generalise.... and it's much more varied these days with multitrack/mic recordings that are panned.   It is general practise to mix all bass into mono, but if/how varies.    Aside from really wierd edge cases, there's just no point leaving any differences in bass frequencies per channel..... at worst it will sound the same if mixed to mono.... and if anyting will sound better.
  • Thanks 1
Quite possibly. But I continue to feed my separate woofers (located under my main speakers) with the stereo signal (low passed at ~50Hz) instead of the summed mono signal (which I can). Because it sounds different.
And my ears (probably a priori) seem to prefer it when  the signal is "stereo" instead of "mono".
I can hear a difference - even if it's not a located difference, there is still a difference.
I mean, the guys mixing down a track to be cut onto a vinyl LP - they didn't just cut the track as is - they had to mix the bass signal to create a mono bass track. So obviously there was stereo bass to be mixed down.
I also bit the bullet and put a deposit on a Klipsch SPL-150. First, because my wife said the one I was going to build was too big and second because the SPL-150 covered what my design was going to do (110dB from 15Hz to 45Hz) in a much smaller package. And at $1800 (from Hollywood Cinema Store in Narre Warren - unashamed plug) I couldn't resist!
Sure... TBC, I'm not saying this is "impossible".
That depends on how the recording was made (panning, etc.) ....  in a more "live" type recording setup, a basic/silly example being a mic at the lef side of stage and a mic at right..... that doesn't have any significant stereo bass.
I don't actually mix-down tracks for cutting to vinyl, but that's what is generally done. Not all the time, from reading, but generally. And it may not always be due to consideration for vinyl. As one person in Sound On Sound puts it:
There may also be hidden phase gremlins between the left and right channels of stereo bass-synth patches, which you'll only hear when the channels are mixed to mono. The worst-case scenario is that the low frequencies will cancel badly, and won't make it out of club and PA systems, or single-subwoofer home/car systems. If the phase mismatch is static, adjusting the polarity, timing, or phase response of one channel may help, but if the bass is seriously flaky in mono, you might as well filter it out and layer in a mono sub-bass synth.
Live recording using stereo pairs will definitely pick up differences in all frequency spectrums, even with a crossed pair. Simply due to the venue and sound reflections therein. AFAIC that's the best sort of live recording to listen to.
P.S. When I was running around having a look at stuff, I noticed an interesting dichotomy regarding one of my albums. Anthony Wilson Trio "Our Gang". In an original review by Marc Mickelson on SoundStage, he says (in 2001) "This CD could pass for a 24/96 DVD, and it was recorded live to two track DSD, so expect an SACD soon." But in Audio Trends advertisement for the same album on 180g vinyl (more recently), I can see "Mastered Directly From The Original 30 IPS 1/4 Inch Analogue Master". We have such a fun interest!!!
In some rooms, it would be impossible.
And, when some of those low organ stops are used...if you can actually hear them, then it's just there. Where? Just 'there'!
I think this is flawed logic.
Yes... if you've got phase difference in the LFs .... and you don't expect them, then it will catch you out.
.... but, assuming we are talking about quite low frequencies.... then these sounds will just cancel in the room.... as opposed to in the mix.
Not at low frequencies, it won't  (assuming not "huge" separtation)
The phase and level of any low frequency sound enternig the microphones will be the same for both microphones.
You can see this is true by looking that the microphone datasheet (omni directional behaviour below X Hz) .... and the phase difference between them will be tiny in WL (a function of distance).
Or just simply do a recording, and look at what you get  (don't don't get stereo bass).
