FS: PS Audio DirectStream DAC (Ex-Demo)
Item Condition: Ex Demo , Full Warranty
Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost.
Suburb or Town: NottingHill
State: VIC
Reason for selling:
Further information:
Location: Class A Audio, 8/585 Blackburn Rd, Notting Hill, VIC, 3168. phone (03) 8555 0735
The DirectStream DAC is our reference standard D to A converter. It is unlike any standard chip-based DAC, and has received countless awards, worldwide.
DirectStream is one of the most remarkable DACS ever built as all the major reviewers agree. Hand written, discrete, perfection based conversion that uncovers all the missing information hiding in your digital audio media. CD’s, streaming audio, high-resolution PCM or DSD based media are expertly upsampled in the DirectStream to twenty times DSD rate and output as pure analog directly into your amplifier or preamplifier. There has never been a better sounding DAC at anywhere close to the price of DirectStream. It is the first choice of thousands of critical listeners worldwide, and with its ability to accept our free Operating System upgrades, will never become obsolete.
Specifications
Physical
Unit Weight 22 lbs [9.97 kg]
Unit Dimensions 14” x 17” x 4” [ 36cm x 43cm x 10cm]
Shipping Weight 31 lbs [14 kg]
Shipping Dimensions 20.5”x 24” x 10” [52cm x 61cm x 25cm]
Power requirements
Input Power Model specific 100VAC, 120VAC, or 230VAC 50 or 60Hz
Power Consumption 30W
Digital audio inputs
I2S(2), Coax, XLR Balanced, TOSLINK, USB, Network Bridge slot
Sample Rates
I2S, and USB — 44.1kHz to 352.8kHz 16bit, 24bit, DSD 64, DSD 128
TOSLINK – 44.1kHz to 96kHz 16bit, 24bit
XLR (AES/EBU)S/PDIF (coax)– 44.1kHz to 192kHz 16bit, 24bit, DSD 64
Analog Audio Output
Connector RCA/XLR Unbalanced /Balanced (X2)
Output level, low 0.282 VRMS Balanced
0.141 VRMS Single Ended
Output level high, maximum 2.818 VRMS Balanced
1.414 VRMS Single Ended
Output Impedance 100Ω/200Ω
Frequency Response 20-20KHz +/- 0.25dB
THD&IM @ 1KHz (full scale) <0.03%
Output Stage Passive audio transformer, fed by high current, high speed analog amps producing double rate DSD.
Data Handling
Format PCM or DSD
Sample rate (PCM) 44.1kHz, 48.0kHz, 88.2kHz, 96.0kHz, 176.4kHz, 192kHz, 352.8kHz
Word length (PCM) 16b, 18b, 20b, 24b
Data rate (DSD) Standard (2.8MHz) or Double (5.6MHz) DoP as well as raw DSD on I2S and USB inputs
Input jitter reduction effectively 100%, residual immeasurable. No input PLLs, FLLs.
Input Processing 170MHz
Signal Processing 50MHz
Synchronous Upsampling, all inputs 28.224MHz
Digital Processing S/N ration >146 dB
Digital Volume Control Zero loss of precision
Analog Conversion method Delta Sigma (DSD) Single-bit double rate
I2S Digital Input
Connector HDMI
Format PCM or DSD. DoP on all inputs as well as raw DSD on I2S inputs
USB Digital Input
Connector USB “B” Type
Format PCM or DoP v1.1 (DSD over PCM)
Transfer mode Asynchronous
    • By Pim
      Item Condition: 8/10 Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Tumbulgum State: NSW Payment Method: Bank transfer / Cash / Cheque Reason for selling: Planning to go passive LS50 Meta Further information: There is a pair of LS50 Meta's up for sale here and i own a Devialet amp. For a while i've been thinking of going passive with the Devialet amp so if I can sell these, I'll buy the LS50 Meta's.
      In 2017 I lost some speakers in a flood and because I was insured, the insurance company bought me these. They're not my main speakers so I hardly use them. They wouldn't have more that a few hundred hours on them.
      I don't have the boxes anymore but I have plenty of ply wood lying around and can build a crate for safe transport.
      PLEASE READ
    • By foryou
      Item Condition: used good condition Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Doncaster State: VIC Payment Method: Paypal (buyer need pay thr fees) , EFT, Cash on Pickup Reason for selling: bought new amp Further information:
       first densen pre amp and the current densen still use the same design . This amp are very musicality and natural , sound will get better after some warm up .
      amp has be serviced by ClassA audio recently .
      it still come with the owner manual and double box . So it can ship to anywhere and good for audio collection.
      Densen didn’t make many of DM20 preamp and this is one of the early one .
      well build and icon design
      Description :
      The Densen DM-20 is designed and built without compromises. It is a successful merger of extravagant sound, design, and usability. The design trademark compact aluminum case, is not only good-looking and easy to incorporate in any interior – it also dissipates heat and reduce magnetic distortion much more effectively than the large steel cases used by many manufacturers. In 1994 at the CES winter show, the Densen DM-20/DM-30 preamp/poweramplifier combination was named the “Highest airguitar factor and best affordable sound” at the CES. In later years, Densen has used the slogan “Life is too short for boring hifi” to describe the Densen sonic signature. Densen hints that the truth of sound is a combination of the Flat earthers focus on PRAT (Pace Rhythm and Timing), and the more classic audiophile focus on timbre, details, soundstage and tonal character. For several years now the phrase has been used by Densen to describe the ultimate goal for all Densen systems, namely that the performance is so good that the listener wants to stand up and play the airguitar, instead of passively letting himself be entertained. Engaging is perhaps the best word to describe the sound from the DM-20. The strong and quick music will breathe through the atmosphere and musicians' emotion can be felt in the sound. A discreetly elegant addition to any home, the Densen DM-20 provides with world-renowned musical experiences and family-friendly usability.
      Specifications :
      Input Sensitivity................................All inputs: 200mV
      Input Impedance...............................20k ohms
      Frequency Response........................2 to 400,000Hz. +0 -3dB
      Total Harmonic Distortion + Noise......Less than 0.01% at rated output
      Signal-to-Noise Ratio........................More than 95dB at rated output, "A-weighted"
      Power Consumption.........................Min(Idle): 10 watts
      ..........................Max: 10 watts
      Power Supply Size...........................Transformers: 2 x 14VA
      Amount Of Rectifiers........................4 (Also known as power supplies)
      Dimensions(w x d x h)......................44.5 x 43 x 8 cm
      Weight............................................5kg
      PLEASE READ
    • By sum1
      Item Condition: As New Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: BEVERLY HILLS State: NSW Payment Method: EFT, Cash on Pickup, Paypal with fees on the buyer unless sent as a personal payment Reason for selling: No Longer Used Further information:
      As New Condition.
      Complete with the original box, receipt and warranty.
      Purchased locally from Digital Cinema at 26/06/2020 so the local warranty still have a long validity on them.
      As far as I can tell there is no local store that stocked this speaker as i think the PSB brand is not popular in Australia even though its predecessor the Alpha B1 was popular worldwide and so is this new Alpha P5 .
      So ended up having to do an order in on them, used it for a short time after which I went to a smaller sized speaker.
      Supposedly PSB have great synergy with NAD amplifiers since they belong under the same parent company.
      Further Reviews
      https://www.stereophile.com/content/psb-alpha-p5-loudspeaker
      https://www.soundstagehifi.com/index.php/reference-components/1390-recommended-reference-component-psb-alpha-p5-loudspeakers)
    • By Davidbigeye
      Item Condition: As new Shipping Options: Pickup available but audition is not available. Suburb or Town: Dalkeith State: VIC Payment Method: Cash, EFT, Paypal confirmed Reason for selling: Not using, and want to buy a MV Agusta! Further information: DEQX unit, can act as digital premap too!
      I bought 2 of these, with the intention of building a system comprising of 3 main speakers, triamped horn setup for home theatre (and hifi), so I needed 2 DEQX units.
      I experimented with some other speakers (2 channel only) and triamped those with 1 DEQX unit, which I am still using.
      The horn setup never got off the ground, so I have an unused DEQX unit available.
      Today was the first time it has ever been turned on, just to verify it works!  It's brand new.
      This one was kitted out with the full digital in - digital out capability so you can go as far as having a seperate DAC on each speaker driver if you choose!
      It also has the balanced XLR output if you like to use it's internal dac(s).
      This one does the lot!
      If you are looking for an active crossover for an insanely good system; looking to time align drivers; and/or looking for room correction, etc...then this is a great unit.
      I am happy to assist in setting up for Perth based purchaser.  I am very familiar with DEQX.
      PLEASE READ
    • By candyflip
      Item Condition: As described below Shipping Options: Shipping is available at agreed cost. Suburb or Town: Bulleen State: VIC Payment Method: Paypal, EFT, Credit cards Reason for selling: latest finds
      The Corrs – Jupiter Calling
      2017 gatefold 2LP pressing
      NM/NM - BRAND NEW and SEALED.
      The album was primarily recorded live, with minimal overdubbing.
      While working on the album, producer T-Bone Burnett made use of 40 spools of two-inch tape and a Ludwig drum kit for the fullest analog sound.
      It works.
