Questions about subwoofer in 2 channel system
OK, so I have very little knowledge about subwoofers and in particular their use in a 2 channel music only system, so thought I would ask the more knowledgeable members here for some insights and advice.
Firstly, and I know this can be a contentious question, do I need a subwoofer or is it likely to improve my system; I have read several threads here and on other Forums about a well integrated sub adding a richness and depth to a 2 channel set up, but I really don't know.
I currently have Monitor Audio Silver 500 speakers; these have 2 x 8" bass drivers in each cabinet and a frequency response of (-6 dB) 30Hz - 35Hz; my amp is a Rega Elex-R. My room is 8m x 5m but open on one side to a staircase and hallway. I get pretty good bass from my speakers, but will  still lower frequencies potentially provided by a sub going to improve things?
I have been considering something like an SVS SB-1000 Pro or perhaps a Rel T/5i as these seem well regarded for music and are within my budget; I don't want to spend too much initially as I don't know whether a sub will make a difference and space for a sub is limited. Are either of these sufficient to make a difference in my set up/room?
I am leaning towards the SVS; this has a 12" driver and a frequency response of 24Hz ±3dB, whereas the Rel only has an 8" driver and 32Hz at -6bB, which is no better than my MA speakers and according to Rel, prefers to be placed in a corner, which is difficult in my room. Am I missing anything here, or are there other options?
Another question is about how to connect these to my integrated amp. On this Forum there is a basic set up guide that says "connect the subwoofer in parallel with your main speakers. If your sub is near the mains, simply connect another pair of cables from the main speakers to the sub amp. If closer to the amplifier, you may connect another pair from the amp to the sub."
I am limited in my placement options for the sub due to room layout, being open plan to one side and with full length windows along the opposite wall. The only real option I have is on the front wall between, but close to either one of the main speakers. So to confirm the above information, am I able to connect the sub using speaker cable from one of the main speakers posts directly to the High Level input on the Sub? Can anyone see any problems in connecting in this way?
Any further advice/information/ guidance on how to set up and integrate a sub is appreciated.
Derek
  • Replies 71
Popular Posts
Ideally, the room should be treated, but that is usually not possible in a shared space.  If space is limited, why not get 2 of these, assuming of course you have the funds? https://www.svsound.c
I have a single svs sb1000 ( not pro) in a very simple 2.1 home theatre system Dali concept 2 book shelves , the integrated is an older luxman integrated driving the sb1000 via pre-outs. Used mainly f
Agree with above, although I am in Rel camp.    Competition to SVS sb-1000 is  REL HT/1205 (for HT)  or T7i(for music).
If the 6 dB down is at 30 Hz (as I would suspect) then you are probably getting a reduced bass response from at least 50 Hz.
In that case a subwoofer will add 'heft' to the sound and more reality to the music.
In regards to the details about models and connections I cannot comment.
  • Thanks 1
Thanks, your comments reinforce a lot of my reading on the use of a sub
It doesn't sound like you're down a lot.
Depending on your amps current ability, and the power handling of your speakers, some EQ could go a long way.
Yes, a sub - or better, 2 - will (as Greg noted) add some richness and 'heft' to the sound.  :thumb:  My listening system is entirely 'music only' ... with 2 subs for visual symmetry - but also better control of bass modes.
Absolutely it will.  Only after I got my subs did I fully realise just what I'd been missing out on for 20 years, with my big Maggie bass panels!
An 8" driver does not a "sub" make!  :lol:  Go with that SVS - unless you can afford something that has a -3dB point of 20Hz or below.
I suggest this "basic setup guide" comes out of the HT crowd - as AVRs tend to prefer this "high-level" connection; music systems are better served with an RCA out to the subs, from the preamp - in addition to the output to the power amp.
But if your integrated amp doesn't have 'pre out' sockets ... you don't have any choice but to connect up the sub to your amp's spkr terminals or the spkr BPs.
Good luck,
  • Thanks 1
Good luck,
Thanks Andy.
You have confirmed my thinking on the SVS. Unfortunately any sub that goes below 20Hz looks to be too large for the space I have available, not to mention WAF.
My amp does have preamp output, so can I confirm the best way to connect the sub is separate RCA cables from this output?
Thanks again,,
Derek
Yep, that makes it very simple.
The sub will be receiving the same signal that is going to the main channels.
All that's left to do is adjust the sub's crossover frequency.  (This will filter out frequencies above the crossover so you're not creating bass bloat by reproducing frequencies already covered by your main speakers.)
I have my sub set up like this, and the crossover is quite close to the lowest possible setting.
  • Thanks 1
Great thanks Ken
1 hour ago, DT999 said:
Thanks Andy.
That's my view, Derek - which I am sure is supported by a number of folk here.  :)  But there is certainly a coven here, of believers who promote the "REL way" (ie, high level connections) as "the only true way to do sub connection".  :lol:
Thanks again,,
Derek
I assume this back-panel pic shows that:
  • inside the case, the preamp section of your integrated feeds into the power amp section
  • but you can take 'preamp out' in parallel with this (in order to feed to subs)?
If so - that's a great solution.  :thumb:
There is, IMO, a better solution - which DrTF has not implemented - which is to roll off the mains at a frequency above their 'natural roll-off'.  This has several advantages:
  1. by rolling off the mains, you reduce the distortion which occurs when they are reproducing their lowest frequencies - as loud+low --> maximum excursion --> distortion.
  2. by stopping the mains from having to reproduce their lowest frequencies ... you give some relief to the amp which is driving them - so it is less stressed ... and able to deliver a better sound to the rest of the frequency spectrum.
However, you can't do this with your integrated amp.
There is a final point re. sub placement - particularly when there is just 1 sub.  This is ... you should have the sub the same distance away from your ears as the main spkrs are ... so that they are 'time aligned'.  In my 2nd system, the sub is located midway between the standmounts - but, if you do the trigonometry ... because the seating position is about 4m away from the standmounts, there's very little difference in the distance-from-ears between the central sub and each standmount.
In my primary system, each sub is about 1.5m further away from my ears than the Maggie bass panels they cross over to.  So I apply a delay to the Maggies in the miniDSP unit which provides the 4-way active XO, so as to time-align the Maggies with the subs.
Thanks again Andy.
As I said I am somewhat limited in my available placement for a sub, but it will be between the mains, albeit much closer to one than the other, and almost exactly the same distance from my main listening spot as the mains, so hopefully I should be able to integrate this well into my system.
Looks like I now just have to spend some money and then do some more experimentation. ?
Derek
https://www.svsound.com/products/3000-micro-subwoofer
Dual subs make the bass more even in the room.  Contrary to popular belief, it is not how low or loud a sub can go.  The key is properly integrating them to provide even bass in the room.
  • Like 4
Thanks Snoop, although they look good a bit out of my price range at this time. I may well experiment with a single sb-1000 and if it makes a noticeable difference I might be able to move things around and fit a second one in down the track.
I have a single svs sb1000 ( not pro) in a very simple 2.1 home theatre system Dali concept 2 book shelves , the integrated is an older luxman integrated driving the sb1000 via pre-outs. Used mainly for movies and occasionally music works a treat and plenty of bass.
regards Dave
Edited by cafe67
  • Like 3
regards Dave
Excellent, thanks Dave. Looks good and somewhat similar to what I am considering in relation to positioning with sub near to the mains, albeit mine will be to the inside between the mains but close to one of them.
  • Like 3
I have the SVS SB 1000 Pro and it is excellent as a sub blended with my stand mounts. It has really tightened up the bass and I can confirm it adds weight and scale that you might not expect...
I connect mine by speaker cables at the amp. If you have Pre out on the integrated you could do that too. Opinions vary as to which method is best. My speakers are no slouch in the bass department and for a long time I didn't feel I needed a sub. I had forgotten what a good sub can do and I think the SVS is a bargain for its quality. It also has an app so you can adjust things from the chair.
Go for it :thumb:
I agree with @andyr's view that a low level signal to subs is a better option than high level speaker connections. to subs - given you have a low level/line level output on your pre-amp you should use it for input to your sub in preference to speaker/high level inputs.
If you chose this approach, you would only be supplying the bass signal to your sub from one channel, not both - not a huge deal, as at sub frequencies (say <80Hz) the signal is mostly mono anyway...but better to have the sub fed by a stereo input, which would be achieved using the line out on your pre-amp.
I agree with this - a well integrated sub is not noticeable - you should never be able to locate it by ear - it just adds "weight" and "depth" to the room sound.
You should only notice a lack in the bottom octave when the sub is turned off.
IMO, 1 or more subs when well integrated, will always improve the "in room" sound.
Main speakers need to be placed to get the best imaging - which is rarely the best placement for bass sources to achieve the smoothest "in room" bass.
Running a sub or subs allows placement of the subs to achieve the smoothest bass in the room.
But achieving great sub integration is not trivial
I agree with this
That's one solution, but another would be to have the sub augment the speakers' response where they naturally roll off.
Unfortunately you can't determine the best approach without a measurement rig to measure the room.
I would go with the SVS SB-1000 Pro connected via RCA from your pre-amp, and if you're keen to understand your room response get a measurement rig (Umike + mic stand + laptop running REW (free))
Mike
regards Dave
in my next life I may have a room that tidy...
Go for it :thumb:
Thanks for the confirmation, I  have an sb 1000 on the way!
I agree with this
Mike
Thanks Mike, I have taken advice to try the RCA from pre amp and have ordered appropriate cables from Bill.
Derek
You said this, Mike:
... but you didn't include the rest of my comment which explained why, IMO, "augmentation" is not the best ...
"There is, IMO, a better solution - which DrTF has not implemented - which is to roll off the mains at a frequency above their 'natural roll-off'.  This has several advantages:
However, you can't do this with your integrated amp."
As bass is a mono signal wouldn't you need only one RCA cable from the Pre out to your sub?
The preouts will output the left and right signals, not mono.  The sub should add the signals and convert to mono.
Thanks for that info, was having a heated discussion with a family member about this.
One last question, would adding a Y splitter after the Pre outs be a better solution?
1 hour ago, Snoopy8 said:
I assume you are trying to add the left and right signals to mono?
My family member thought that was the best method, but after reading your supplied link he has finally seen the light ...thanks for your help?
These generalisations about non-linear distortion aren't always true.
Sure... if the mains have distortion which is too high.... then high passing them can be a good idea.
Although with appropriate EQ.... "augmented" mains will be ~ -3dB anyways  ... and this is significant in the peak power and excursion department.  (as they'll have EQ to reduce the response where they're combined with the sub.... so the total frequency response would be the same as without the sub)
This assumes that all stereo recordings, have mono bass..... often this is true.... but not always.    Especially at the higher end of a subwoofers range.
Absolutely - for a setup with just 1 sub!  :thumb:
But if you have 2 subs - in a music system (ie. not HT) - then I suggest R pre out --> R sub and L pre out --> L sub.
For 2 subs, I prefer feeding to a DSP to sum (less 6dB) and provide mono to the subs.
I'm quoting Zaphod and he said...
"DO NOT EVER use a Y cable. Never ever for such a purpose. You are unlikely to blow anything up (though there is a remote possibility of damage to the preamp), but the sound quality will suffer.
You MUST use a cable equipped with resistors, as per Andy's cite.
Do not use a Y cable. "
2 hours ago, Rocketfrogs said:
Not trying to hijack the thread but opinions on 'ported' or 'sealed' subs?
Whoooaaa - you seem to like causing trouble, R!  xD
My view is that ported subs - or ported spkrs for that matter - are an attempt to "squeeze a quart out of a pint pot"!   iow, get more bass out of the box than the size of the cabinet would suggest.
The result, unfortunately ... is a compromise.  :(
Edited by andyr
FWIW, I have tried both line level and high level with time spent on each, the latter IMO is tighter, quicker and utilises the amps sound signature. Then enters Spatial M3 triode speakers 4 x 15" woofers and the rest is history!
I've taken Andy's advice about porting and added a SVS SB 1000 Pro which is a sealed enclosure with a 12" woofer and bluetooth connectivity.  First impressions are very favourable!  So go for it DT999!
:thumb:  :thumb:  :thumb:
Can I suggest a minor change to the situation you show in your pic?  The sub seems to be located outside of the L spkr ... therefore it is a bit further away from your ears than the L spkr is.
The ideal situation is for the sub to be time-aligned with the L spkr - can you move it forwards a bit ... so that the front of the cone-cover on the SB-1000 is the same distance away from your L ear as the top of the silver cone-cover on your L spkr?
Edited by andyr
Thanks, my new SB 1000 will hopefully arrive tomorrow but I have to wait for cables to be made before I can try it out.
Will do.  Thanks!
I'm sure you'll love it. Do you have any spare speaker cables?
No I don’t  have speaker cables, and I need 3m RCA cables to reach from my amp to where sub will be located.  I'll just have to wait a bit, hopefully not too long though before I can try it out. Have been listening today and can't help wonder what the sub will add.
