FS: Garrard 301 Turntable with REED 2A GOLD 9.5” Red Cedar Wand Tonearm & Koetsu Rosewood Signature MC Cartridge
Item Condition: Mint but used
Shipping Options: Pickup available but audition is not available.
Suburb or Town: Berwick
State: VIC
Payment Method: EFT or cash on oickup
Reason for selling: Retiring from Hifi hobby
Further information:
Selling my Garrard 301 refurbished by Audio Grail UK fitted with REED 2A GOLD 9.5” Red Cedar Arm Wand Tonearm and Koetsu Rosewood Signature MC Cartridge. It is all setup and ready to PLUG AND PLAY.
This age of this Garrard turntable with tonearm and Koetsu cartridge is about 4.5 years old and hardly played no more than 500 hours. The Garrard 301 is mounted on a hand made Cheryl timber double plinth very nicely finished with danish oil varnish. A perspex lid is included.
My asking price is reasonable as I’ve paid more than $12,000 for everything you see on this pictures. Serious buyer interested to own this turntable please don’t hesitate to make me a reasonable offer but no low baller please. I’m retiring from hifi hobby so I would like to hand over this turntable to the next owner who will treasure this beautiful piece of design.
If no buyer I will break all components apart for sale individually at later stage.
Note:
For Victoria buyer - Due to the design of this turntable pickup is preferable.
For interstate buyer - CANNOT BE SHIPPED in its current configuration.
I can dismantle and repack in its original individual packaging and ship but you will have to reinstall the gears by yourself.
AudioGrail Hammertone Garrard 301
Audio Grail is an established professional company of 18 years standing dedicated to the finest detailed restorations of Garrard 301 turntables. – Our passion is for the unique heritage of the 301, our approach to restoration is a detailed labor of love
Audio Grail works in conjunction with artisan paint finishers (Six year Rolls Royce apprenticed) and antique plating companies to achieve authentic detailed restorations of the highest quality. In total, close to 120 years of combined professional experience is afforded to each of our Garrard 301 units.
This Audiograil Hammertone Edition 301 has been professionally stripped, measured and rebuilt by Audio Grail in their Devonshire workshop to achieve the highest possible standard of mechanical function. Audiograil use precision equipment, lubrication's, bespoke rivets and tooling alongside brand-new improved component parts where required.The dynamically balanced stroboscopic this edition 301 has been prepared in our bespoke satin finish –This elegant finish contrasts wonderfully with the textured chassis and face plates.
Linkages
To create the finest iridescent finish, each nut, bolt, washer, screw and associated linkage (Over 90 in total) have been ‘strung’ individually by hand prior to acid stripping and plating. Audio Grail linkages are not ‘tumbled’ (Produces an inferior dull scared finish). The stripped linkages and fixings are then electroplated uniformly with a ‘yellowed’ Zinc (This superior finish was chosen as the original Garrard Cadmium plating is poisonous) The results are spotlessly clean mechanical components that function perfectly, are factory fresh, and gleam in iridescence preserving for a further 50 years of function
Idler Wheel
One of the main sonic detractors of the 301’s is the problem of ‘Rumble’. A significant factor in the cause of rumble in the 301 is the deformation / distortion / drying of the idler wheel. A flat or warped idler wheel will ‘thud’ on the platter transferring the noise straight to the stylus that acts as a microphone.
The idler wheel of this 301 is a brand new ‘solid hub’ example with the flat rubber ring precision ground to very high standards. The idler wheel is accompanied with brand new sintered bushes ensuring a close tolerance and correct service. Having tested and measured every after-market idler wheel available over the years we are very happy with the performance of this new component.
Spindle / Bearing / Housing
New gasket, oil retaining felt washer and zinc plated bearing plate.
Motor strip and service
The Heart of the matter – The full title of the 301 is: “Garrard 301 MOTOR unit’ after 50 years these motors require heart surgery… The Garrard 301 shaded pole induction motors feature sintered bronze bushes secured by rivets and lubricated by felt oil reservoirs. It was by design the sintered (heat pressed bronze powder and oil) bushes would wear with use / time. The bushes were made to be self-centering however the direction of wear from the idler wheel’s ‘pinch’ effect between motor pulley and platter causes an ‘ovaling’ which in turn creates noise and vibration transferred to the platter via the pulley to the platter and in turn the stylus. In addition, vibration of the motor to the chassis and in turn the spindle housing and platter again translates to audible noise. Many have attempted to attend to the motor issue: PTFE, CNC Oilite etc bushes have all been used however due to costs (Set up bespoke mold costs & production requirements) No one has attempted to re-make Genuine Sintered bronze bushes which contain 20%+ oil – Until Now. The tolerances of the new bushes and their ability to correctly lubricate the Stator translate to significantly quieter running and audibly quieter noise floor.
Spring replacement
All of the delicate springs on the 301 are vital in terms of functionality. The motor springs isolate vibration coupled with rubber sleeves. Often these are stretched. The effect of this is a motor that is noisy in operation. (The motor will not hang correctly in its ‘cage’ causing uneven wear to the motor bushings and idler wheel bushes.) The idler wheel springs are critical in order to ensure correct engagement of the idler against the pulley. The pitch linkage features three small springs, which are often stretched causing difficulty with pitch control and vibration transference. The 301 available here features a completely new set of springs and rubber sleeves ensuring the finest possible function
Further works
All Audio Grail 301’s come replete with: A brand new brake pad, set of mounting bolts and idler housing grommets. All electrical connection points are cleaned and treated, many individual components are ultrasonically cleaned and bench polished. In addition, we faithfully restore and upgrade the original spark suppressor to ensures correct function whilst preserving the integrity and heritage of the unit.
The Koetsu Rosewood Signature is a 9gm stereo moving coil cartridge with a natural Rosewood body, copper coil wiring, a Samarium Cobalt magnet and Boron cantilever. It is known for its deep and wide soundstage, clarity and dynamically sparkling midrange. It has a full-bodied sound which makes it an excellent choice for all genres of music.
Fumihiko used higher performing and more tightly matched coil and core sets in the Rosewood Signature compared to the Rosewood which results in a more precise focus and a larger soundstage than the Rosewood Standard. Please note that this cartridge has also been known as the ‘Koetsu Red K Signature’.
Reviews
The Absolute Sound, Dick Olsher, 2019
Listening to the Rosewood Signature was an addictive experience. It became difficult to curtail a listening session as there was always one more album I had to spin. It’s the cartridge I could happily live with for years to come. This is one of the easiest recommendations I’ve ever made, in essence a gift for the music lover who would like to kick back at the end of a long day and just enjoy the music. I think this is what Sugano-san had in mind all along.
Hi-Fi News, Steve Harris and Paul Miller, 2009
Crisp and fast yet with a midrange able to wring every last drop of passion from a recording, the Koetsu legend lives on in the addictive sound of this ‘Signature’ MC.
Product Specification
Body
Natural Rosewood with clear lacquer
Type
Moving Coil
Coil Wiring
Copper
Magnet
Samarium Cobalt
Cantilever
Boron
Output Voltage
0.4 mV
Frequency Range
20Hz to 100kHz
Channel Separation
25db / 1kHz
Inner Impedance
5 Ohm
Channel Balance
0.5db / 1kHz
Recommended Impedance
30 Ohm
Weight
9g
Recommended Tracking Force
1.8 – 2.0g
Compliance
5 X 10-6cm / dyne at 100Hz
Recommended Load
80-1,000 ohm
REED 2A 9.5” Tonearm
The Reed 2A tonearm and is ideal for people who have a fixed audio setup and demand perfect sound. With a rigid and stable construction, the Reed 2A is the perfect market entry product by Reed, and promises the same sound quality as Reed 3Q model, albeit with fewer possibilities for adjustment.
Consisting of two parts, the Reed 2A has a massive stand and moving part, made of solid metal. It has a height (VTA) adjustment of 20 mm, with a fine tolerance of ±0.1 mm. After adjusting the tonearm height, it is then tightened to a stand. With ruby olive bombe bearings, the Reed 2A will keep mechanism friction to an absolute minimum, and has a down force range from 10 mN to 30 mN.
Tonearm is wired with Cardas wiring and WBT-0110 Cu RCA plugs (E37 + cryo)
Length - 9.5 inches
Red Cedar Arm Wand
Standard fixed headshell
PLEASE READ
  • You understand that a reasonable donation for selling fees is expected upon successful sale of your item
  • Like 8
  • Love 9
And to think................the ABC virtually threw these out!
1 hour ago, Gandra said:
Beautiful table and setup!
GLWTS
It certainly is, and the pictures don’t come close to doing it justice. I had the pleasure of auditioning Boon’s speakers when he still had his system intact. The TT performance is just sublime, the plinth is a work of art and gives the unit a commanding presence in any room.
Rohan.
  • Love 2
    • By candyflip
      Item Condition: As described below Shipping Options: Shipping is available at agreed cost. Suburb or Town: Bulleen State: VIC Payment Method: Paypal, EFT, Credit cards Reason for selling: latest finds
      The Corrs – Jupiter Calling
      2017 gatefold 2LP pressing
      NM/NM - BRAND NEW and SEALED.
      The album was primarily recorded live, with minimal overdubbing.
      While working on the album, producer T-Bone Burnett made use of 40 spools of two-inch tape and a Ludwig drum kit for the fullest analog sound.
      It works.
    • By dan-m9
      Item Condition: As New Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: Postmans Ridge or Toowoomba State: QLD Payment Method: Paypal (Buyer pays 2.6% fees or F&F with no fees), EFT, Cash on Pickup Reason for selling: NLR - Too many AMPs Further information:
      Fantastic sounding EL34 Tube AMP for the price and a perfect decent entry level for tubes.
      Little use and just barely burnt in, selling as I got two and change of plans for the second one.
      Comes with upgraded tubes. 2X Psvane EL34 and 1X Vintage RCA 12AX7 (long plate round getter). Happy to sell with no tubes for $60 less if wanted.
      Free Postage AU wide to Sendle/CouriersPlease locations.
      Paid nearly $500 AUD new after shipping/tax and before tube upgrade a month ago (took nearly a month to arrive/ship):
      Also a Drop link for more specs/reviews:
      https://drop.com/buy/appj-el34-tube-stereo-amplifier
      Thanks.
    • By Davidbigeye
      Item Condition: Mint Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: DALKEITH State: WA Payment Method: Reason for selling: Extra Info: JBL made 4 pairs of these in gloss black as special demo speakers, this is one of those pairs!  There are only 3 other sets in the world!
      They are the Special Edition models, in fantastic condition, lightly used, always with the best amps etc driving them (Goldmund, Krell...)
      These are amazing speakers, I thought I would keep them forever, but circumstances have changed...
      Give me a yell if you would like to see/hear them.
      David.
      Pictures: attached
    • By Pim
      Item Condition: 8/10 Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Tumbulgum State: NSW Payment Method: Bank transfer / Cash / Cheque Reason for selling: Planning to go passive LS50 Meta Further information: There is a pair of LS50 Meta's up for sale here and i own a Devialet amp. For a while i've been thinking of going passive with the Devialet amp so if I can sell these, I'll buy the LS50 Meta's.
      In 2017 I lost some speakers in a flood and because I was insured, the insurance company bought me these. They're not my main speakers so I hardly use them. They wouldn't have more that a few hundred hours on them.
      I don't have the boxes anymore but I have plenty of ply wood lying around and can build a crate for safe transport.
      PLEASE READ
    • By foryou
      Item Condition: used good condition Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Doncaster State: VIC Payment Method: Paypal (buyer need pay thr fees) , EFT, Cash on Pickup Reason for selling: bought new amp Further information:
       first densen pre amp and the current densen still use the same design . This amp are very musicality and natural , sound will get better after some warm up .
      amp has be serviced by ClassA audio recently .
      it still come with the owner manual and double box . So it can ship to anywhere and good for audio collection.
      Densen didn’t make many of DM20 preamp and this is one of the early one .
      well build and icon design
      Description :
      The Densen DM-20 is designed and built without compromises. It is a successful merger of extravagant sound, design, and usability. The design trademark compact aluminum case, is not only good-looking and easy to incorporate in any interior – it also dissipates heat and reduce magnetic distortion much more effectively than the large steel cases used by many manufacturers. In 1994 at the CES winter show, the Densen DM-20/DM-30 preamp/poweramplifier combination was named the “Highest airguitar factor and best affordable sound” at the CES. In later years, Densen has used the slogan “Life is too short for boring hifi” to describe the Densen sonic signature. Densen hints that the truth of sound is a combination of the Flat earthers focus on PRAT (Pace Rhythm and Timing), and the more classic audiophile focus on timbre, details, soundstage and tonal character. For several years now the phrase has been used by Densen to describe the ultimate goal for all Densen systems, namely that the performance is so good that the listener wants to stand up and play the airguitar, instead of passively letting himself be entertained. Engaging is perhaps the best word to describe the sound from the DM-20. The strong and quick music will breathe through the atmosphere and musicians' emotion can be felt in the sound. A discreetly elegant addition to any home, the Densen DM-20 provides with world-renowned musical experiences and family-friendly usability.
      Specifications :
      Input Sensitivity................................All inputs: 200mV
      Input Impedance...............................20k ohms
      Frequency Response........................2 to 400,000Hz. +0 -3dB
      Total Harmonic Distortion + Noise......Less than 0.01% at rated output
      Signal-to-Noise Ratio........................More than 95dB at rated output, "A-weighted"
      Power Consumption.........................Min(Idle): 10 watts
      ..........................Max: 10 watts
      Power Supply Size...........................Transformers: 2 x 14VA
      Amount Of Rectifiers........................4 (Also known as power supplies)
      Dimensions(w x d x h)......................44.5 x 43 x 8 cm
      Weight............................................5kg
      PLEASE READ
