Item Condition: Excellent
Shipping Options: Shipping is available at agreed cost.
Suburb or Town: Sydney
State: NSW
Payment Method: Cash, EFT or Paypal (buyer pays fee)
Reason for selling: NLR
"A superbly made product that produces superb sound" - Michael Fremer, Stereophile
Stereophile Class A Recommended Component
  • Current model - rrp  $7990
  • The manual, alternative impedance cards and extra high quality resistors are included.
  • Use the preselected impedance jumpers or make your own custom jumpers with supplied cards and resistors.
Review:
"The Audia Flight Phono combined pitch-black backgrounds and world-class dynamic presentation with a clean, ultrafast top end and a taut, well-extended bottom end." Stereophile Class A Recommended Component
"...nothing but sonic pleasure... the Flight Phono produced music out of what subjectively sounded like an even blacker backdrop, and probably partly because of that, its soundstage presentation was among the most transparent, deep, and three-dimensional I've heard from any phono stage."
MF - Stereophile
A separate power supply, dedicated input preamplifier boards, high gain (74dB maximum) and low noise are only a few of its characteristics.
The separate power supply was chosen to improve the shield of the preamp and to reduce the vibrations and resonance from the transformers to zero.
Power supply
The Audia Flight Phono Preamp's power supply is separate from the preamp chassis. A 50VA toroidal transformer supplies the analogue stages. On it is placed the first power supply (+/- 38V).
Inside the separate power supply there is a 15VA toroidal transformer as well, to supply the relays and logic control. Previous user selections are stored in memory. To receive the commands from the pushbutton of the preamp chassis without electrical connections, several opto-isolators are used.
There is also a low noise MOSFET power supply (+/-28V) on the preamp chassis for the second gain stage and another power supply for the first gain stage (+/- 15V). Thus, there are six power supplies in total!
Preamp
The Audia Flight Phono Preamp is based on Audia Flight's current feedback philosophy. The MC and MM input preamp boards are different, because MC and MM cartridges have different electrical characteristics. The MC preamp board is a transistor input preamp with 64 dB of gain. The MM preamp board is a differential transistor input stage with 40dB of gain. Both have low noise and low offset output. On both input boards, the impedance selectors are close to the input stage and are made by professional gold jumpers. Custom resistors can also be used for precise cartridge matching from the rear panel.
After the first gain stage is the input selector, which is made with gold contact relays. Following this is the RIAA filter in passive configuration. It is made with 1% polypropylene and polystyrene capacitors. In this position, it's possible to select a subsonic IEC filter as well.
The second gain output stage, which is completely redesigned, has improved speed and signal-to-noise (S/N) ratio. The second gain stage is switchable from 24 dB to 34 dB and has a balanced XLR output.
A mono selector is an important element in achieving the best sound while using a stereo cartridge to play a mono record. The Audia Flight Preamp's mono selector sums the left and right channels together in the same manner as a mono cartridge would, which provides improved sonic performance.
The Preamp board features DC offset protection; if there is an offset voltage, this feature will protect the unit and all others connected to it.
Information:
  • Gain MC 64 dB + 10 dB (74 dB in total) / MM 44 dB + 10 dB (54 dB in total)
  • Frequency response (1Wrsm, -3db) 5Hz - 120 KHz
  • THD <0.05%
  • S/N ratio >90dB “A” weighted
  • RIAA accuracy +/- 0.1 dB
  • Channel Unbalance <0.04 dB
  • Stereo separation >95 dB @ 10 KHzMC input impedance from 7 ohm to 980 ohm in eight steps plus a custom resistor value
  • MM input impedance from 47pF to 600 pF in twelve steps plus a custom capacitor value
  • Output impedance All outputs 500 ohm
  • Phase Non inverted
  • Maximum consumption 65WDimensions and weight 420x92x330mm (WxHxD), 10.5 Kg
  • Original Box not included
  • Edited December 29, 2020 by Doctor Faustus .
Edited by Doctor Faustus
  • Doctor Faustus changed the title to FS: Audia Flight Phono Preamplifier - Silver
    • By KYK
      Item Condition: Used, very good condition Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Brighton East State: VIC Payment Method: Cash on pickup Reason for selling: Spare Further information:
      Audioquest's classic Digital Pro coaxial 75 OHM digital cable, factory terminated with silver plated RCA connectors. This was a top Audioquest digital cable and features pure silver conductors. Print on the mesh jackets says AudioQuest Pro Double Balanced FPS Solid Silver. Very good condition, some wear marks on the connectors.
    • By cambam007
      Item Condition: Mint Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Newport State: VIC Payment Method: Cash, EFT Reason for selling: No longer required Further information:
      : I am selling off what is left of my collection and will be listing them over the next week or so.
      All in perfect condition and only played a couple of times (some never)
      A lot of vmp exclusives in there
      Happy to post for the standard $12.50
      Not on the list is an original sex pistols from 1977 that I am unsure of price but pm if interested
      PLEASE READ
    • By 075Congo
      Item Condition: Very Good Used Condition Shipping Options: Shipping is included in price. Suburb or Town: Buderim State: QLD Payment Method: PayPal as a Friend Reason for selling: Buying a Scotty Cameron Newport 2.5 Further information: The Scotty Cameron Fastback with 2 x 20gram weights was released onto the US Tour in 2008. One of this design went to the Scotty Cameron Custom Shop in California and was called "Americana" when it emerged. Typically the putter is decked out in Red, White and Blue colours. The putter is 34 inches long and Right Handed. The only non-original addition is the Scoytty Cameron Grey Pistol Grip I added recently; the original had the Black and Red Pistolini grip. The putter comes with an Original Custom Shop Grip (unused) and another Scotty grip used when playing. The putter is in great shape ...no rust (WD40) and some paint wear on the sole of the club. A Scotty Cameron Oil Cloth and a Club Cameron Divot Tool are included. Please contact me for other information. The putter can be posted by Courier in bubble-wrap inside a cardboard box included in the price. Price is NEGOTIABLE.
      SNA Donation if sold on this site.
      PLEASE READ
    • By 075Congo
      Item Condition: Very Good Used Condition Shipping Options: Shipping is included in price. Suburb or Town: BUDERIM State: QLD Payment Method: PayPal as a Friend Reason for selling: NLR Further information: Selling a G.Gerlach "MS BATTORY" Automatic Watch (with BIG DATE). G.Gerlach is a Polish Watchmaking firm which dates back to 1845. The original G.Gerlach factory was destroyed in 1944 and the present watchmaking sit dates from that time. The watch is "automatic" with no battery and relies on shaking your wrist to keep it in action for 48 hours. Watchbands, leather watch pouches can be bought online from G.Gerlach.com if needed. This is a beautiful time piece is currently priced at $510 AUD plus postage from Poland. SNA Donation
      PLEASE READ
    • By LWA Staff
      Item Condition: Excellent Secondhand Condition Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Lane Cove State: NSW Payment Method: Bank Transfer, Credit Cards, Cash, PayPal Reason for selling: Retailer Further information:  Look at these magnificent Focal Viva Utopia with stands. Originally sold by us as brand new in October 2016, these current model units are in excellent secondhand condition. They retail new for $59,900 as new, so we've priced to sell quickly at 15K. We can arrange freight if required but this will be at an additional cost AND we do not have the original packing crates.
      Note: the bases have their original packing plastic on them, no damage here!
      Focal says: Viva Utopia  is a 3-way audiophile loudspeaker dedicated to the most sophisticated multichannel configurations. Vertical (Viva Utopia) or horizontal (Viva Center Utopia), either in Home Theatre or Stereo configuration, it’s always efficient. Advantages: extreme clarity of the midrange, high efficiency and power handling and very low directivity on the horizontal axis for perfect control of phase and 3D image.
      Specifications:
      Recommended power > 50W - 600W
      Efficiency > 92 dB
      Impedance > 8 ohm
      Bandwidth > 39 Hz - 40 kHz
      Dimensions > Height 942 mm x Width 322 mm x Depth 510 mm
      Weight > 57 kg
