philwill1971@gmail.com 15 Posted April 7 Share Posted April 7 Hi, I have purchased some silver cable which came with banana plugs pre soldered, which i removed to fit spade connections (usa amp). The cable has 20 strands and is coated in a thick rigid plastic, and it is dipped so cannot be simply cut, to remove/expose. i have heated with a lighter to expose and clamped tightly, but a, am wondering whether this is efficient and a solid connect, and b, how to remove the plastic properly. One idea was to solder the end with silver solder hence forcing the plastic out, , then clamp, ideas appreciated. Link to post Share on other sites
audiofeline 2,552 Posted April 7 Share Posted April 7 It's a bit hard to visualise without more details. - What is the cable brand/model (someone might be familiar with it)? - Can you post a close-up photo to show what you are describing? 1 Link to post Share on other sites
muon* 3,304 Posted April 7 Share Posted April 7 (edited) Well It's no good if you are not connecting bare wire to the spade, and the wire is covered in plastic/insulation between the wire and spade. If It's injection molded like I'm picturing it, maybe carefully cutting away the molded plastic with a Stanley knife. As AF suggests above....need pics 🙂 Edited April 7 by muon* 1 Link to post Share on other sites
philwill1971@gmail.com 15 Posted April 7 Author Share Posted April 7 Thanks for responding, cable is Wired world, photos attached. 1 Link to post Share on other sites
philwill1971@gmail.com 15 Posted April 8 Author Share Posted April 8 Zoomed in to actually see plastic melted around each strand. Link to post Share on other sites
pete_mac 4,117 Posted Thursday at 05:13 AM Share Posted Thursday at 05:13 AM It looks like Litz wire with individually insulated strands. There are a variety of ways to remove the insulation. Dipping the wire in a solder pot/bath is easiest, but most people won’t have one of these on hand. I’d suggest googling the other options, as you may find one which works best for you. Link to post Share on other sites
philwill1971@gmail.com 15 Posted Thursday at 11:55 AM Author Share Posted Thursday at 11:55 AM Solder pot a good idea. Anyone else? Link to post Share on other sites
Gryffles 971 Posted Thursday at 01:04 PM Share Posted Thursday at 01:04 PM 1 hour ago, philwill1971@gmail.com said: Solder pot a good idea. Anyone else? I don’t think Wire world cables are litz. Just individual wires moulded as you’ve suggested. Im not sure how successful a solder pot will be. Perhaps just scrape off what you can and heat shrink to hide it. Looks like you have nothing to lose Link to post Share on other sites
audiofeline 2,552 Posted Saturday at 10:52 AM Share Posted Saturday at 10:52 AM And I'd also suggest some heat shrink to tidy-up the open-weave techflex covering (for aesthetics only, won't influence the sound). Link to post Share on other sites
GregWormald 1,833 Posted Sunday at 03:19 PM Share Posted Sunday at 03:19 PM As long as you clean off the carbon from the burning plastic and bind the strands tightly or solder together then the lighter seems as good as anything. I suspect a solder pot of silver solder could get expensive. Link to post Share on other sites
philwill1971@gmail.com 15 Posted 18 hours ago Author Share Posted 18 hours ago Thanks all for responding, heat gun melted plastic enough for me to unravel and then plastic started sliding off taking all residue with it, yay 2 Link to post Share on other sites
