olegau Posted April 1, 2021 Share Posted April 1, 2021 Item Condition: Very good Shipping Options: Pickup available and you can audition. Suburb or Town: Melbourne State: VIC Payment Method: Cash on Pickup Reason for selling: Downgrade Further information: Paid $12500, one owner, like new, no scratches, all papers One speaker terminal screw is not very tight but I use banana plugs. Klipsch Palladiums P-F37's are a small brother of the famous P-F39F's. The speakers are high sensitivity so that a 10 - 15W amplifier will work fine. https://www.areadvd.de/hardware/2008/klipsch_palladium.shtm Klipsch Palladium P-37F Floorstanding Speakers (Natural) As the ``smallest`` floorstanding loudspeaker in our high-end luxury Palladium Series, the P-37F features the flagship P-39F`s technology and gallery-like appearance in a slightly more compact but equally stunning package. The P-37F’s carbon-infused, thermoset composite dual-horn configuration is unique to the Palladium family. It consists of a proprietary tweeter design, combining a chambered phase plug and Tractrix® Horn for extended high-frequency response; a second 90º by 60º acoustically damped Tractrix Horn is coupled to the midrange driver, resulting in precise performances. Features: · Modern design, incomparable craftsmanship and proprietary technologies · Exotic zebra-grain Linia wood veneer cabinet · 0.75-inch horn-loaded tweeter, 4.5-inch midrange and triple 7-inch woofers · Bass-reflex design via triple rear-firing ports Specifications: · Frequency Response:43Hz-24kHz +/-3dB · Low Frequency Extension:31Hz · High Frequency Extension:30kHz · Power Handling: 275W continuous / 1100W peak · Recommended Amplifier Power: 50 - 600W · Sensitvity: 96dB @ 2.83V / 1m · Nominal Impedance: 4 ohms · Mid-Frequency Crossover: 550HZ · High Frequency Crossover: 3400Hz · Maximum Acoustic Output: 120dB (2 speakers in-room) · High Frequency Driver:0.75`` (1.9cm) (titanium diaphragm compression driver mated to 90° x 60° Tractrix® Horn) · Mid-Frequency Driver:4.5`` (11.4cm) (aluminum diaphragm compression driver mated to 90° x 60° Tractrix® Horn) · Low Frequency Drivers: Three 7`` (17.8cm) (high-output, aluminum / Rohacell® /woven synthetic fiber hybrid cone woofers) · Enclosure Material:Constrained layer MDF(medium density fiberboard) · Dimensions (H x W x D): 118.1 x 50.2 x 49.5 cm EA · Weight: 44.5kg EA · Enclousure Type:Bass-reflex via triple rear-firing ports Photos: PLEASE READ If you include any reference to pricing whatsoever in this section (excluding RRP), your ad will not be approved If you are advertising multiple items, you must post one bulk price only, or post seperate ads for each item If you don't include photographs of the actual item being sold, your ad will not be approved You understand that a reasonable donation for selling fees is expected upon successful sale of your item 2 Link to comment Share on other sites More sharing options...
luke Cam Posted April 2, 2021 Share Posted April 2, 2021 Amazing speakers, what music do you listen to with these? Link to comment Share on other sites More sharing options...
olegau Posted April 2, 2021 Author Share Posted April 2, 2021 Mostly modern Jazz and classical. Link to comment Share on other sites More sharing options...
