Boon54 Posted March 16, 2021 Share Posted March 16, 2021 (edited) SOLD SOLD Item Condition: Mint but used Shipping Options: Pickup available but audition is not available. Suburb or Town: Berwick State: VIC Payment Method: EFT or Cash on Pickup Reason for selling: Retiring from Hifi Hobby Further information: Note: Both Aesthetix Atlas Poweramp & Calyspo Preamp will be sold as a combo. Will not be for sale separately. These units were purchased locally from Aesthetix authorised dealer. Made specifically for AUSTRALIA POWER 240 voltage. Aesthetix Calypso Preamp The Aesthetix Calypso is a high quality tube linestage suitable for audio and home cinema systems. Fully balanced circuitry from input to output, including internal balancing of single-ended inputs, results in common mode signal rejection and a very clean sound. The innovative discrete switched resistor volume control maximises resolution at any listening level. Every input is both single-ended and balanced for greater versatility. Home theatre bypass mode, absolute phase setting and full function remote are added conveniences. The aluminium chassis is rigid, acoustically inert and simply beautiful Fully balanced differential circuitry with ability to internally balance a single ended input signal. Zero feedback. Discrete switched resistor volume control with 88 1dB steps. All tube amplification and output (4 tubes total). Two sets of XLR and two sets of RCA outputs per channel. Bypass mode for home theatre processor throughput. Absolute phase, selectable via front panel or remote control. Full function remote included. Aesthetix Atlas Power Amp ATLAS amplifiers are capable of driving virtually any high quality speaker. An innovative hybrid design incorporates a bipolar output stage, bipolar driver stage, and vacuum tube input gain stage. They stand alone as the only hybrid amplifiers with zero feedback, essential for maintaining harmonic integrity, air, space and coherence. The Atlas provides your choice of full range or high-pass inputs. This unique built-in filter is ideal for speakers featuring powered woofers, such as Vandersteen, or for audio and home cinema systems using outboard powered sub-woofers. Saturn Series design themes are evidenced in the specialized all-aluminum chassis construction and elaborate power supply design. Power Output: 200wpc channel into 8, 400wpc into 4 Input Sensitivity: 60mV (1 watt), 2.3V (full power) Zero feedback, fully differential amplifier with complementary balanced bridge design for open sound. Tube gain stage using one 6SN7 tube per channel provides harmonic accuracy and soundstage layering. This single gain stage provides all of the voltage gain for the entire amplifier. Stereo amplifier: 200 watts per channel into 8 ohms; 400 watts per channel into 4 ohms Amplifier has a built-in high-pass crossover: 6 dB / octave, 16 settings from 40 Hz to 200 Hz in approximate 10 Hz increments. Single-ended and balanced inputs provide extended compatibility. Direct input bypasses all crossovers and switching for ultimate purity. Bus technology reduces power supply impedance between output devices for more instantaneous current. Power supply uses two transformers and three chokes. The high current section uses a dedicated transformer and choke input power supply. The vacuum tube B+ power supply has choke input and is discretely regulated. The result is unequalled clarity and control. Cardas patented rhodium-plated binding post with single knob lockdown. All aluminum chassis construction assures durability. Stainless steel cover for transformers prevents magnetic fields from interacting with sensitive audio circuitry, preserving low level musical nuances. Photos: PLEASE READ If you include any reference to pricing whatsoever in this section (excluding RRP), your ad will not be approved If you are advertising multiple items, you must post one bulk price only, or post seperate ads for each item If you don't include photographs of the actual item being sold, your ad will not be approved You understand that a reasonable donation for selling fees is expected upon successful sale of your item - if you have previously sold items and not made a donation, your advertisement may not be approved. Edited March 23, 2021 by Boon54 Link to comment Share on other sites More sharing options...
steven365 Posted March 17, 2021 Share Posted March 17, 2021 Having owned a full set Aesthetix (DAC, Pre, Amp) and still have the Atlas monos in my system. I can attest that this is a combo that produces the most emotional connection to the music! Fitting in some good NOS tubes, the SQ can be easily brought up to another level. You will not regret! Link to comment Share on other sites More sharing options...
Boon54 Posted March 17, 2021 Author Share Posted March 17, 2021 12 minutes ago, steven365 said: Having owned a full set Aesthetix (DAC, Pre, Amp) and still have the Atlas monos in my system. I can attest that this is a combo that produces the most emotional connection to the music! Fitting in some good NOS tubes, the SQ can be easily brought up to another level. You will not regret! Steven365, thanks and fully agreed with you. Link to comment Share on other sites More sharing options...
ikhuong Posted March 17, 2021 Share Posted March 17, 2021 What speakers do you recommend for those for Nivara sound? Link to comment Share on other sites More sharing options...
Boon54 Posted March 17, 2021 Author Share Posted March 17, 2021 1 hour ago, ikhuong said: What speakers do you recommend for those for Nivara sound? Was driving a pair of Tannoy turnberry GR prestige and they sounded fabulous. 1 Link to comment Share on other sites More sharing options...
DMax Posted March 17, 2021 Share Posted March 17, 2021 @srms... Oh my goodness! Link to comment Share on other sites More sharing options...
DMax Posted March 19, 2021 Share Posted March 19, 2021 I'd be very interested in the preamp if someone else wants the power amp. Link to comment Share on other sites More sharing options...
marinemania2002 Posted March 20, 2021 Share Posted March 20, 2021 I want the preamp lol if someone wants the power Link to comment Share on other sites More sharing options...
Boon54 Posted March 21, 2021 Author Share Posted March 21, 2021 Received many many enquries but still no taker. Come on, someone need to own this combo and you never regret at this price. Link to comment Share on other sites More sharing options...
Boon54 Posted March 23, 2021 Author Share Posted March 23, 2021 These units were purchased locally from Aesthetix authorised dealer. Made specifically for AUSTRALIA POWER 240 voltage. Link to comment Share on other sites More sharing options...
