Quick question about power cables.
Just a quicky. What do you think you should put your best power cable on? Amps or dac/source?
  • Replies 315
Popular Posts
FWIW, I’m a firm believer in cables. I tried my stereo without them once, didn’t do it for me.   Cables – you gotta have’em!
Power cable quick question?  Lol.
And now I see again, why I don't venture outside of the classifieds......
Source in my limited* experiments.
*Not blind testing and with power cables under $250.
From technical point of view, definitely power amp.
A source, such as DAC or CD player consumes 15W of steady power. Neither do its requirements change nor is it great amount of power.
Anything really could be used for source.
If you are fanatical, get DeOxit and clean both sockets in equipment and pins on power cable. This should give more improvement than any exotic power snakes...
Power amp on the other hand uses a lot more power and it is changing depending on volume and music.
Power supply matters to the power amp a lot.
Starve it of power and you will loose slam.
From reading other subjective experience on here over time, I'd say it is components and cable dependent.
Indeed....:popcorn: 😎
  • Haha 2
Given that their other senses are often enhanced, how good would blind people be at blind testing audio equipment. And how much easier would it be to conduct the testing.
The question is quick, it's the answer that's guaranteed to be protracted...
  • Like 4
Edited by rantan
  • Haha 2
I read somewhere this is a myth.
Depends. Need more info on your type of cable. Silver or copper? Multi strand or solid core?
Solid-core power cords?  In theory that would be great but solid-core wire is not available in a large enough guage to be usable as a power cable.
Plus there's the issue of stranded cable being resistant to being flexed ... solid core will weaken with flexing and eventually break - ie. it's fine inside a case but not as an external cable.
I seem to recall reading somewhere that solid core power cables are not legal in Australia
If they can play Blind Cricket, I imagine they're like Superman 😎🦸
Solid core "twin and earth" mains cable (used for house wiring) was a popular speaker cable in the UK for a while in the 1980s. I experimented with it for all of a couple of days.
https://www.diy.com/departments/prysmian-6242y-3-core-2-5mm-twin-earth-cable-50m/33842_BQ.prd looks like the stuff but judging by the one-star review even this stuff is made cheap and nasty these days.
There was a college for the blind near where I used to live that trained blind people to be piano tuners on that basis - they took as long to learn as anyone else. It was a good trade though.
As it happens, the job has reverted, somewhat, to sighted people who can see the screen on the iPad app :sad:
My recent purchases came with moulded cables, so nothing too "special", but were different construction and presumably chosen for source and amp respectively. No, I didn't try them the other way round. And no, I'm not converted to expensive power cables because of that.
But it does suggest that a particular power lead may suit a particular product more.
If your "best" cable (or indeed the others) aren't specified for particular items, just switch them round and see which combination sounds best to you. Though if any of them get hot when used with your power amp use a different one there.
Perhaps that's why you can no longer buy the wire to make such cables?  :)
You used to be able to buy it in Oz - over 20 years ago.  This however, was for use inside wall cavities - where it is not moved around - not as a power cord which might get flexed from time to time.
However, you will no longer find it at places like Middies or Lawrence & Hansen ... possibly because it is now illegal to be used?
they are out there though and they do make a difference to the sound 🙂 you have to match the build of the cable to the components carefully to extract the best performance out of them
That wasn't the opening poster's question.
he asked where best to put a power cable in - that answer will depend on how the cable is build and with what materials. simple answer
Oh I see. I thought you were just praising power cables in general. Can you answer his question then if you knew the materials?
Edited by Ittaku
no, you need to know what you are buying . knowing the construct and metallurgy means you know where best to place the cable. don;t get bowled over by appearances externally, know your cables and whats in there...thats the most important thing.
And which ones suit source and which ones amps?
..and streamers/DACs/phono stages/power boards. If done properly, one could have seven or eight different power cords so the unique demands of the various components could be maximised and true synergy achieved.
Apparently so, which is why I'm curious to hear what this wonderful synergy of metallurgy and components is.
Yes.
Pease count me me in as well.
This could be groundbreaking.
  • Haha 1
not here to get into a catfight 🙂 let me know what you have and i will suggest
Well I don't have any, so what would I buy for say my MSB Reference DAC versus my ARC Ref250SE power amps?
Go get a siltect tc for the msb and a goebel or stage 3 kraken for your amps.
you using kettle cords for your audio gear?????🤪
Of course not. I use kettle cords for my tea kettle.  I use the power cords that came with my audio electronics of course.
well they dont use kettle cords inside the msb reference dac:-) so if you want to maximise the performance of the gear why use something basic to hook it up? short of shindo gear , i have not found any other gear that doesn't respond to the use of better power cords. But this is something you have to try before you believe in  ittaku. where in melbourne are you? might be happy to lend you a cord to try.
Because that's what it came with, meaning that manufacturers decided that's what was required for it to work optimally.  The manual said nothing about aftermarkert power cords so they're clearly recommending against using them by giving me one with the device.
As do I.
 The term "kettle cords" is just the vernacular term for a standard power cord supplied with  components.
  • Thanks 1
Oh I see, so does that mean I could use one of these higher quality power cords to make my kettle boil faster too?
  • Haha 2
ittaku....if you like i can open your eyes to whats out there. whats supplied there is  like what you get with a printer. you can use it and yes it will supply power but a msb reference dac is not a printer. and if you are happy to pay 120k for a msb reference dac with simple copper in there - you need to reexamine the purchase pathway. as  i said i might be happy to lend you a cord if i can be satisfied i will get it back
i think you don;t like eggs itttaku, which is fine but know that i am not here to convince you otherwise if you are a skeptic. I will suggest that you dont spend 120k on a msb reference if you compromise on the most important part of the system which is power.. Power and isolation are the bases to building a great system
