FS: L.K.S Audio LKS MH-DA004 Dual ES9038pro DAC (Modded)
Item Condition: Excellent
Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost.
Suburb or Town: Adelaide Hills
State: SA
Payment Method: Paypal, EFT, Cash on Pickup
Reason for selling: Lack of use
Price: $1325
Item Condition: As new
Shipping Options: Pickup available and you can audition.,Shipping is included in price.
State: South Australia
Payment Method: PayPal, EFT, Cash
Reason for selling: NLR
Further information:
Bought off another member in October 2020 and have since modded it with Copper around both Power Supplies and twisting the cables.
Will throw in a pair of 80cm Swamp balanced XLR cables
Below is copy and paste from the original post.
Purchased from ShenzhenAudio in July 2020 -
Current price for the upgraded usb model is $2200 I believe.
Free shipping included but buyer pays insurance if wanted.
Not particularly well known in Oz I don't think but absolutely packed with features - a full dual mono design with dual ES9038pro chips.  This version features the optional upgraded USB interface which includes an upgraded power supply and 2 x Crystek CCHD-957 active clock and supports DSD up to 512k.  Comes in original box, has remote and will throw in a free unopened Supra 2m USB cable so the new owner can enjoy the amazing sound.
Two-chip ES9038pro decoding method.
Two high-quality toroidal transformers, a total of 13 groups of linear power supply.
Built-in specially designed Italian Amanero USB module, original license license. USB module added to isolate the chip, you can isolate the computer to the audio system interference signal.
Supports USB, I2S / DSD single-ended signal (RJ45), I2S / DSD balanced signal (HDMI), oaxial, BNC, AES / EBU balance, Optical total seven-way source input, all ports support DSD input.
Analog audio output port includes standard RCA single-ended output and XLR balanced output pair.
Display with VFD display, the display exceptionally outstanding.
 Use physical key operation.
Support 0dB ~ -127dB digital volume adjustment, 0.5dB level. But also has a remote key to skip the volume adjustment function.
Support a variety of digital filter mode settings (see user manual). Can be arbitrarily selected, different filter mode, the digital filter attenuation characteristics are different.
Supports decoding of internal digital phase-locked loop bandwidth settings (see user's manual for details).
Support Deemphasis to increase or turn off.
The display has 4 levels of brightness adjustable. Adjusted by remote control.
Remote start, standby function.
Most of the settings with memory function, turn off the opportunity to automatically save the settings, restart the settings.
Dynamic range> 135dB
Distortion <0.0002%
Stereo resolution> 120dB
RCA unbalanced port output amplitude 2Vrms, XLR balanced port output amplitude 5Vrms.
Machine size 430 * 320 * 90mm
Machine weight 7.0kg
You can read the full specs here
https://shenzhenaudio.com/products/l-k-s-audio-lks-mh-da004-dual-es9038pro-flagship-dac-dsd-input-i2s-coaxial-bnc-aes-ebu-for-dop-usb-i2s-optical-audio-decoder?variant=29703030833212
Lots of reviews on various forums such as
https://www.head-fi.org/threads/l-k-s-audio-mh-da004-dual-es9038pro-dac-van-dammes-double-impact.840938/
https://theaudiostandard.net/thread/4743/lks-mh-da004-dac
https://audiophilestyle.com/forums/topic/31270-lks-audio-mh-da004/
A quote from one user review
"OK, so the nitty gritty. I have TWO of them in two systems and could not be happier. I had foolishly jumped in and paid even more for a Schiit YGGDRASIL until I received an LKS MH-DA004 and the difference in audio quality was obvious. So I sold the YGGDRASIL and purchased a second LKS. Note, the YGGDRASIL DAC is a fine unit, but the LKS is better. Cleaner reproduction generally on classical music, particularly with larger ensembles where the LKS reveals more detail of the individual instruments playing, has more air and delicacy and eliminates traces of digital harshness"
May I know why would someone put copper plate around the transformer?
Shields the EM and EF sensitive electronics from the Transformers.
Edited by Gbickle
Hmm..... copper is a non-magnetic material and it won't shield any electromagnetic induction, you need a ferrous metal for that like iron sheet.
Copper is the most reliable material of choice when shielding from radio frequencies because of its ability to absorb both magnetic and radio waves. It is also highly effective in attenuating magnetic and electrical waves.
Of all the metals in EMI shielding, copper is the most reliable because it works best at reducing both magnetic and electrical waves. You can find copper in just about any place needing EMI shielding from hospital equipment to basic home computers.
Copper costs more than other alloys or pre-tin plated steel. It does, however, have a higher rate of conductivity, which makes it so effective as an EMI shield
Edited by Gbickle
Copper is completely diamagnetic, a static magnetic field will go through it like through air. However, it is a very good conductor, and a changing magnetic field (like from an AC transformer) will cause eddy currents in the copper and won’t be able to pass without substantial loss of energy.
    • By Maverick730
      Item Condition: Used Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Everton Hills State: QLD Payment Method: Paypal(as friend or fee), eft, cash Reason for selling: Surplus Further information:
      in good condition. Comes with a stock 3m and a focal 1.2m cable. Postage is $20 most city registered.
      PLEASE READ
    • By full_dp
      Item Condition: Very Good Shipping Options: Pickup available but audition is not available. Suburb or Town: Doonside State: NSW Payment Method: PayPal, Cash on Pickup Reason for selling: Need funds for upgrade Further information:
      Up for sale is my Kef R400B in very good condition.
      I use to pair this with my Kef LS50 which is sold here a couple months ago.
      Note: There are minor dents in the aluminum frame of the sub but doesn't affect performance.
      Pick up  preferred in 2767 NSW.
      for specs see here :https://www.digitalcinema.com.au/kef-r400b-9-subwoofer.html
      PLEASE READ
    • By Gibbsy88
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Sunbury State: VIC Payment Method: Paypal plus fees, EFT, Cash on Pickup Reason for selling: Moved house and no longer have a dedicated room. Further information: Regretfully selling my HT setup as I have moved into a new house with no dedicated room. This post is for 2 x Emotiva Gen 1 XPA-1 power monoblock amplifiers. Both are in excellent condition and come with their original boxes.
      XPA-1 Differential Reference Mono-block Power Amplifier 500 watts RMS x 1 into 8 ohms, 1,000 watts RMS x 1 into 4 ohms. It's all about control, and the XPA-1 is a control freak. 500 watts RMS into 8 ohms, 1,000 watts RMS into 4 ohms. All the performance you'd expect to see from an audiophile reference level amplifier. But what about the sound? Big...expansive...powerful...and yet very refined...and defined. This is what you get when you have control.
      Open to reasonable offers.
      Other items for sale:
      - Paradigm Studio 100 V5 floorstands in Black Ash.
      - Paradigm Studio ADP-590 V5 3-way surround speakers.
      PLEASE READ
    • By full_dp
      Item Condition: Excellent Condition Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Woodcroft State: NSW Payment Method: Reason for selling: Need funds for upgrade
      SB Acoustic ARA Bookshelf Speakers in excellent condition – I bought this stand mount speakers from SNA’er last October 2020.  The pair is in white high gloss with genuine SB Acoustic crossovers and the famous Satori Ring Radiator Tweeter which been used by high end speakers manufacturers such as the Von Schweikert and Hulgich Audio to name a few. The mid woofer also uses is SB Acoustic ARA papyrus reed cone which is also found in the Wilson Audio Sasha.
      These speakers are only available in kit form in Australia and sell for $xxxx from Wagner Online, if these are sold ready made expect to pay twice or thrice the price. The ARA bookshelf speakers are also very similar to the Hulgich Audio NINA (same drivers but different cabinet) which is more than triple the price that I’am asking.
       SB Acoustic drivers were designed in Denmark by ex Scan-Speak engineers.
      DRIVERS used:
      SATORI TW29R (29mm soft ring dome) 6.5inch SATORI MW16P-4 mid woofer.
      Frequency Response: 45-25000Hz /-3dB
      Sensitivity: 87dB
      Impedance: 4ohm
      Recommended amplifier: 50 to 150 watt
       2 Way Bass Reflex Port tuned to 36.5Hz
       Facets on top of the paired cabinets for reduced high frequency diffraction
      Inclined baffle for correct time alignment of drivers
      Wedge shaped inner rear walls behind mid woofer for reduced direct reflection.
      Internal bracing to reduce and distribute vibrations, hence lower sound colouration.
       Approx. 391mm high x 340mm deep 190mm wide ( These are quite large for stand mount speakers)
      Note: There is a small hole in one of the tweeter cloth covers but will provide spare cloth to fix this.
      PLEASE READ
    • By kngrus
      Item Condition: Excellent Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Kingscliff State: NSW Payment Method: Direct debit, Paypal, cash Reason for selling: Financial hardship Further information:
      For sale is this Modwright LS 36.5 line stage (pre amp).
      A high end unit used for digital & analogue playing. It requires an external phono stage for vinyl.
      The line stage being a combination solid state & tube valve.
      It is in great condition as early last year I flew this unit back home to the USA as Dan Wright agreed to service it for me.
      It has upgraded hard to find Reflector 6H30 tubes used mostly on reference equipment that I purchased separately & have 2 spare new ones if purchaser also wants them at for a third  of their purchase cost.  also comes with a custom top quality power lead.
      This unit retails for 8K new.
      A big shout out to Dan Wright from Modwright Instruments who has provided above & beyond customer care for his product Thank you Dan!
