WTB: MiniDSP Umik-1 and 2x4HD
Item: Umik-1 and 2X4HD
Item Condition: New or Used
I'm looking to get into room correction so I'm looking for a Umik-1 and a 2X4HD, ideally together in a bundle. Located in Melbourne. Cheers!
The 2x4HD doesn’t appear to have digital outputs, so it essentially becomes your DAC, correct?
  •      The specs
  • ADSP21489 400MHz Sharc DSP floating point engine
  • XMOS Xcore200 for USB control and bidirectional audio streaming
  • 24 bit ADC/DAC resolution
  • Unbalanced inputs switchable with a jumper between 4Vrms and 2Vrms
  • Toslink digital input
  • Unbalanced outputs: Max 2Vrms
  • USB Audio Class 2 Bidirectional streaming with ASIO drivers, driverless under MAC OSx
  • 4 preset configuration, recallable via IR, Software
  • Plug&Play USB driver and real time Software configuration using miniDSP plug-ins
  • Device does not required a PC once configured
  • External single 12V supply
Correct. You can choose USB (digital) input, Toslink or RCA (analog) input. As a DAC is OK but not great. Depends how fussy you are on DAC quality.
1 hour ago, Bill125812 said:
I tried the same thing.  Hard to come across here in aus.  I order direct from MiniDSP.  Took a week and it was here.  Good exchange rate at the moment to
https://www.minidsp.com/products/minidsp-in-a-box/minidsp-2x4-hd
Thanks Bill. I found a 2X4HD for a good price but the issue is tracking down a UMIK-1. Seems that people aren't willing to let them go, which is understandable. Might have to just order one.
I'll most likely be inserting the 2X4 inbetween the pre out and main in of my system. It's a shame that the 2X4's DAC is not as competent as my own, but my thinking is that the improvements the DSP will bring to my system outweigh the negatives.
I think I brought my UMIK-1  in from the US for $138 Aust delivered
Is that the one currently on Gumtree for $80 ?
If not I will buy it!
Yes, I've sent the seller a message so we'll see what happens.
It depends on what signal levels you feed it.     If they are too small it has low performance
My DAC outputs 2V so there should be no issues if I run from DAC -> Minidsp -> Amplifier.
Yes, and as long as you run the output of the miniDSP high too.
  • Thanks 1
Sorry I beat you all to it :(
hahaha its ok, i justed started looking and was tossing up if I should buy new from the us or wait when this thread came up.
Edited by judge25
Or I thought I had - I sent the money and now he wants to refund it because he tested the unit and found it wasn't working and has thrown it in the bin !!
I reckon somebody offered him more money and he stooged me.........................😡
Edited by niterida
