DLS TA2 Tube Amplifier - Audiophile, Rare
Item Condition: Mint
Shipping Options: Pickup available but audition is not available.
Suburb or Town: Tarneit
State: VIC
Payment Method: Paypal with fees, EFT
DLS Ultimate Tube Amplifier TA2.
I have 2 amps - this is for 1.
Excellent condition.
ULTIMATE series TA2 is a HiFi two-channel amplifier with 2 x 100 Watts output power. This is an extremely well-sounding amplifier for car use. We did not compromize in any section of the construction when we designed the electronic circuits.
The TA2 is using the very best components in all sections of the amplifier, from the input circuitry, through the whole amplifier to the final output stage. Two pieces of CV4010 pentodes is used in the signal path. These tubes are made by VALVE Electronics in England during 1982 - 1984. The Valve Electronics company produced best sounding tubes in the tube industry before they closed. The tubes are spare parts for military equipment so they fulfil military specifications.
We use silver wire Capacitors in signal path and power supply for a focused sound image. Special designed DLS Audio capacitors in key points and WIMA polypropylene capacitors. Four pieces of 4700 uF on each channel for a deep and wide sound stage. Dual mono power system design plus separate power supply for tube and pre-amp stage for clear sound reproduction.
- RMS output per channel @ 13,8 volts, 20 Hz - 20 kHz ,
Separate level controls for each channel.
Specifications
Number of channels 2
Amplifier class AB
Output power in 2 ohm 2 x 200 W RMS
Output power in 4 ohm 2 x 100 W RMS
Damping factor >240
S/N ratio, A-weighted >102 dB
Frequency range 10 Hz - 50 kHz
Input sensitivity 0,5 - 7V
Input impedance > 10 kohm
High pass filter 20 - 200 Hz, 12 dB slope
Low level output No
Remote bass level control No
Remote phase shift control No
High level input with auto start No
Integrated fan No
Power consumption (idle) 1,5 A
Power consumption (max) 40 A
Rec. power cable Minimum 5AWG / 16 mm2 for each channel / kanal
Dimension (W x D x H) 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
PLEASE READ
  • You understand that a reasonable donation for selling fees is expected upon successful sale of your item
