Roller Cassette Blind
Item: Roller Cassette Blind
Price Range: free to a good home
Item Condition: Used
Hey Guys, I have just removed a roller cassette blind from my home theatre room. The cassette forms a frame around the blind and provides excellent light blocking, far superior to a normal roller blind. Its two separate blinds that came out of the same window, one being 2240mm and the other 1120mm, and 700mm height. Can be used together or in separate windows. You could modify to suit narrower and/or higher windows. Comes with all the mounting equipment, brackets etc. I am based in Adelaide. Suitable for pickup or drop off.
  • 2 weeks later...
