anewmission Posted February 28, 2021 Share Posted February 28, 2021 Trying to remove some of the high pitch buzz and static coming from my streamer pc. I have an art pb 4x4 which cleans up a fair bit. But I noticed most of the noise is coming from the ethernet plug, and usb plug. I think I should also get a dc blocker Any recommendations? Link to comment Share on other sites More sharing options...
stereo coffee Posted February 28, 2021 Share Posted February 28, 2021 1 hour ago, anewmission said: Trying to remove some of the high pitch buzz and static coming from my streamer pc. I have an art pb 4x4 which cleans up a fair bit. But I noticed most of the noise is coming from the ethernet plug, and usb plug. I think I should also get a dc blocker Any recommendations? There is some good advice for isolation of USB style interfaces here : https://www.digikey.co.nz/en/articles/techniques-and-solutions-for-usb-power-and-data-isolation Link to comment Share on other sites More sharing options...
anewmission Posted February 28, 2021 Author Share Posted February 28, 2021 Haha quite abit to read through, though I skimmed through and I will read it when I hop onto the computer. I was googling these today https://addictedtoaudio.com.au/products/ifi-ipurifier3-noise-isolator?variant=8748012372085&utm_medium=cpc&utm_source=google&utm_campaign=Google Shopping¤cy=AUD?utm_source=google&utm_medium=organic&utm_campaign=surfaces&utm_content=surfaces_across_google&gclid=EAIaIQobChMIzYbd7M2M7wIVN51LBR1JkQ7JEAQYASABEgJO0PD_BwE https://addictedtoaudio.com.au/products/ifi-ac-ipurifier-noise-isolator?variant=8743100547189&utm_medium=cpc&utm_source=google&utm_campaign=Google Shopping¤cy=AUD?utm_source=google&utm_medium=organic&utm_campaign=surfaces&utm_content=surfaces_across_google&gclid=EAIaIQobChMInveWkc6M7wIV2Q0rCh0qqwPCEAQYAyABEgJyLfD_BwE I probably don't need the second with my art pb, can anyone recommend a dc blocker? Link to comment Share on other sites More sharing options...
Guest Eggcup the Dafter Posted March 1, 2021 Share Posted March 1, 2021 I'm misreading this. Are you saying the PC is noisy, or that there is noise coming from the speakers? Link to comment Share on other sites More sharing options...
anewmission Posted March 1, 2021 Author Share Posted March 1, 2021 Haha quite abit to read through, though I skimmed through and I will read it when I hop onto the computer. I was googling these today https://addictedtoaudio.com.au/products/ifi-ipurifier3-noise-isolator?variant=8748012372085&utm_medium=cpc&utm_source=google&utm_campaign=Google Shopping¤cy=AUD?utm_source=google&utm_medium=organic&utm_campaign=surfaces&utm_content=surfaces_across_google&gclid=EAIaIQobChMIzYbd7M2M7wIVN51LBR1JkQ7JEAQYASABEgJO0PD_BwE https://addictedtoaudio.com.au/products/ifi-ac-ipurifier-noise-isolator?variant=8743100547189&utm_medium=cpc&utm_source=google&utm_campaign=Google Shopping¤cy=AUD?utm_source=google&utm_medium=organic&utm_campaign=surfaces&utm_content=surfaces_across_google&gclid=EAIaIQobChMInveWkc6M7wIV2Q0rCh0qqwPCEAQYAyABEgJyLfD_BwE I probably don't need the second with my art pb, can anyone recommend a dc blocker? My pc or dac is noisy Link to comment Share on other sites More sharing options...
Guest Eggcup the Dafter Posted March 1, 2021 Share Posted March 1, 2021 Difficult to diagnose that remotely. It wouldn't be fan noise from the PC would it? Link to comment Share on other sites More sharing options...
anewmission Posted March 1, 2021 Author Share Posted March 1, 2021 4 hours ago, Eggcup the Dafter said: Difficult to diagnose that remotely. It wouldn't be fan noise from the PC would it? I'm using ethernet over power line. So that is more than likely the problem. Even before turning on the pc, if the usb is going to the dac I can hear a high pitch buzz just from the ethernet cable. When I unplug it. The buzz goes away. Doesn't matter if the pc is on or not. When I go to stream music I hear about 1 second of static but once music starts playing. All buzzing disappears.. very strange Link to comment Share on other sites More sharing options...
Pim Posted March 1, 2021 Share Posted March 1, 2021 Sounds to me like you have a problem in your DAC. A decent DAC should isolate any buzzing on the cables feeding it signal. Link to comment Share on other sites More sharing options...
Ittaku Posted March 1, 2021 Share Posted March 1, 2021 Good old fashioned Toslink Optical connections don't transmit buzz. Link to comment Share on other sites More sharing options...
andyr Posted March 1, 2021 Share Posted March 1, 2021 2 hours ago, anewmission said: I'm using ethernet over power line. So that is more than likely the problem. Absolutely, it is! FFS - power lines and ethernet together ... are an oxymoron! Andy Link to comment Share on other sites More sharing options...
anewmission Posted March 1, 2021 Author Share Posted March 1, 2021 11 hours ago, andyr said: Absolutely, it is! FFS - power lines and ethernet together ... are an oxymoron! Andy So I would actually be better using WiFi? Unfortunately no easy way of getting an ethernet plug to the listening room Link to comment Share on other sites More sharing options...
Guest Eggcup the Dafter Posted March 1, 2021 Share Posted March 1, 2021 You have two issues. FIrstly, if the power line adaptor is causing buzz at the computer, that is a mains or earth leak, or if the adaptors do power over ethernet (PoE) it's doing it very badly indeed. Secondly, it sounds as if something is happening that shouldn't when streaming is started. I suspect the power line adaptor is doing that as well. At the very east, one or both of the power line adaptors are badly designed or faulty. I would investigate using wifi in the first instance and if you have problems with that, replace the power line adaptors. I don't think treating the computer or DAC is the way to go here. Link to comment Share on other sites More sharing options...
andyr Posted March 2, 2021 Share Posted March 2, 2021 1 hour ago, anewmission said: Unfortunately no easy way of getting an ethernet plug to the listening room Yes it can be difficult, sometimes, to retrofit. 1 hour ago, anewmission said: So I would actually be better using WiFi? I would say ... YES! Andy 1 Link to comment Share on other sites More sharing options...
aussievintage Posted March 2, 2021 Share Posted March 2, 2021 1 hour ago, anewmission said: So I would actually be better using WiFi? Despite all the stories, a decent Wifi connection works extremely well. I have stopped using nearly all my ethernet cabling, as it just isn't necessary. Even an old 2.4GHz wifi connection has plenty of bandwidth for music, it will even do Netflix 1 Link to comment Share on other sites More sharing options...
Pim Posted March 2, 2021 Share Posted March 2, 2021 10 minutes ago, aussievintage said: Despite all the stories, a decent Wifi connection works extremely well. I have stopped using nearly all my ethernet cabling, as it just isn't necessary. Even an old 2.4GHz wifi connection has plenty of bandwidth for music, it will even do Netflix You have a point there. I wired my whole house up with Cat 6A SFTP and as it turns out, I use very little of it. As someone who used to install phone and alarm systems I used to live by the motto 'wireless is useless' because of all the issues we had with it, but those days are long gone. WIFI is very stable nowadays. 2 Link to comment Share on other sites More sharing options...
Guest Eggcup the Dafter Posted March 2, 2021 Share Posted March 2, 2021 33 minutes ago, aussievintage said: Despite all the stories, a decent Wifi connection works extremely well. I have stopped using nearly all my ethernet cabling, as it just isn't necessary. Even an old 2.4GHz wifi connection has plenty of bandwidth for music, it will even do Netflix Generally yes, but there are two situations where Wifi becomes an issue. In some buildings the walls are simply too thick, and unless you are prepared to use multiple boosters and hope for the best, or run cables at least part of the way, it won't work. The other situation arises in some unit blocks, where everyone and their pet goldfish has their own network set up. This shouldn't stop you getting something but I've known it happen. You can havc a combination of the two issues as well, where 5GHz doesn't work well and 2.4 is congested. In those situations ethernet over the mains can make sense. Linn even used to recommend it. However, I really don't like what it's doing to equipment here. Link to comment Share on other sites More sharing options...
aussievintage Posted March 2, 2021 Share Posted March 2, 2021 1 hour ago, Eggcup the Dafter said: Generally yes, but there are two situations where Wifi becomes an issue. In some buildings the walls are simply too thick, and unless you are prepared to use multiple boosters and hope for the best, or run cables at least part of the way, it won't work. The other situation arises in some unit blocks, where everyone and their pet goldfish has their own network set up. This shouldn't stop you getting something but I've known it happen. You can havc a combination of the two issues as well, where 5GHz doesn't work well and 2.4 is congested. In those situations ethernet over the mains can make sense. Linn even used to recommend it. However, I really don't like what it's doing to equipment here. Yes, it all boils down to whether you a decent Wifi connection or not - just as I said. The trouble is, people in a typical domestic situation in their own house, in the suburbs, are still being told by people on line, that Wifi is no good and they must use cables. I have heard of ethernet over the mains working well, but I suspect it will fail more often in the same situations you mention that have Wifi problems, simply because of the way multi-dwellings are supplied their power. Link to comment Share on other sites More sharing options...
Guest Eggcup the Dafter Posted March 2, 2021 Share Posted March 2, 2021 (edited) 45 minutes ago, aussievintage said: Yes, it all boils down to whether you a decent Wifi connection or not - just as I said. The trouble is, people in a typical domestic situation in their own house, in the suburbs, are still being told by people on line, that Wifi is no good and they must use cables. I have heard of ethernet over the mains working well, but I suspect it will fail more often in the same situations you mention that have Wifi problems, simply because of the way multi-dwellings are supplied their power. Yes in part to that last statement - and they'll also fail if you have dedicated mains wiring to your hifi and are trying to reach it from another line. It's not the dwelling type but the way they are wired, though. I remember something else about them causing problems to radio enthusiasts in the same building or nearby (they turn the mains wiring into a large source of RFI). That may also interfere with hifi equipment of course... Edited March 2, 2021 by Eggcup the Dafter Link to comment Share on other sites More sharing options...
anewmission Posted March 2, 2021 Author Share Posted March 2, 2021 7 hours ago, Eggcup the Dafter said: Yes in part to that last statement - and they'll also fail if you have dedicated mains wiring to your hifi and are trying to reach it from another line. It's not the dwelling type but the way they are wired, though. I remember something else about them causing problems to radio enthusiasts in the same building or nearby (they turn the mains wiring into a large source of RFI). That may also interfere with hifi equipment of course... And as the only source not passing through the art 4x4 rfi filter that makes complete sense Link to comment Share on other sites More sharing options...
jbpstereo Posted March 4, 2021 Share Posted March 4, 2021 Just to add my 2c: today I finally sorted out the buzzing and popping I've been hearing via USB DAC(s) connected to my PC for the past 12 months by ditching the ethernet-over-power adapter I had been using and switching to Wifi. I had tried lots of USB filters and purifiers and tried isolating the USB data and power legs with an expensive split USB cable and feeding the DAC power from a battery or linear supply, but the noise was coming through the USB data link whatever I tried. I almost bought a replacement motherboard figuring it must be the culprit. But today, having unplugged the EoP adapter and adding a USB Wifi adapter to the PC, I have a completely black background from my USB DAC at last. @anewmission I hope your fix is as simple! Jason 1 Link to comment Share on other sites More sharing options...
Ittaku Posted March 4, 2021 Share Posted March 4, 2021 (edited) Like I said, just try toslink optical... Edited March 4, 2021 by Ittaku 1 Link to comment Share on other sites More sharing options...
Jventer Posted March 4, 2021 Share Posted March 4, 2021 (edited) I have used several methods for ethernet as in: Ethernet over Power Cat 5 WiFi But, nowadays I am just on WiFi - so much easier and less hassles. @anewmission I agree that your cheapest and easiest possible solutions will be to just use WiFi and or optical connections. If that works you may even be in front as you may be able to sell your ethernet over power connectors . Edited March 13, 2021 by Jventer Link to comment Share on other sites More sharing options...
anewmission Posted March 13, 2021 Author Share Posted March 13, 2021 On 05/03/2021 at 7:02 AM, Ittaku said: Like I said, just try toslink optical... Unfortunately the pc doesn't have optical. I have used optical before but it sounds thinner, to me anyway. I think hdmi even sounds better than optical. I bought a wifi card, going to install that today. What I'd really like to try is i2s. Instead of usb. All in due time I guess Link to comment Share on other sites More sharing options...
Ittaku Posted March 13, 2021 Share Posted March 13, 2021 5 minutes ago, anewmission said: Unfortunately the pc doesn't have optical. I have used optical before but it sounds thinner, to me anyway. I think hdmi even sounds better than optical. I bought a wifi card, going to install that today. What I'd really like to try is i2s. Instead of usb. All in due time I guess Okay. A usb to spdif converter is an option as they tend to act as noise filters. My personal experience with optical is very different to everyone that poopoos it; it sounds pretty much identical to coaxial in both my expensive and cheap DACs. Obviously your mileage may vary. I2S is a tricky communication medium not really designed to be used external and isn't a guaranteed improvement because of that. Link to comment Share on other sites More sharing options...
anewmission Posted March 14, 2021 Author Share Posted March 14, 2021 On 13/03/2021 at 12:14 PM, Ittaku said: Okay. A usb to spdif converter is an option as they tend to act as noise filters. My personal experience with optical is very different to everyone that poopoos it; it sounds pretty much identical to coaxial in both my expensive and cheap DACs. Obviously your mileage may vary. I2S is a tricky communication medium not really designed to be used external and isn't a guaranteed improvement because of that. It seems like more dacs and streamer/cd players are using i2s more often now. Ps audio, topping, gustard. I need to read more about whether any of the rpi models do i2s straight from the board. Hdmi cables can be alot nicer than optical coax or usb. Link to comment Share on other sites More sharing options...
