Graham75 0 Posted February 26 Share Posted February 26 Hi can anybody help with pairing some floorstanding speakers to my NAD C372 integrated amplifier? There are so many options out there and would like to narrow it down. I'm currently using Krix KDX-M speakers and while they are fantastic in the high end, I want something with more grunt in the mids and lows. I'm using a Velodyne 12 inch sub for the lows but would like to dispense with it if I could find speakers with ample bass. I listen to a lot of prog rock, metal, jazz fusion and occasional mellower music. My budget is around $2000. Cheers, Graham. Link to post Share on other sites
Graham75 0 Posted February 26 Author Share Posted February 26 Sorry, the Krix are bookshelf speakers Link to post Share on other sites
tripitaka 445 Posted February 26 Share Posted February 26 (edited) Some people have reported that Summoner speakers from Adelaide Speakers would do that sort of job pretty well at that price range Edited February 26 by tripitaka Link to post Share on other sites
rantan 10,302 Posted February 27 Share Posted February 27 There is a pair of Wharfedale EVO 4.3 in the classified section but I cannot get the link to work to the listing ( 20th January). ($1800 ) These are highly under rated and sound fantastic. 1 Link to post Share on other sites
Grant Slack 377 Posted February 27 Share Posted February 27 3 hours ago, Graham75 said: Hi can anybody help with pairing some floorstanding speakers to my NAD C372 integrated amplifier? There are so many options out there and would like to narrow it down. I'm currently using Krix KDX-M speakers and while they are fantastic in the high end, I want something with more grunt in the mids and lows. I'm using a Velodyne 12 inch sub for the lows but would like to dispense with it if I could find speakers with ample bass. I listen to a lot of prog rock, metal, jazz fusion and occasional mellower music. My budget is around $2000. Hello Graham, IMO you are better off keeping that Velodyne 12 than taking it out and putting in floorstanding speakers in your price range — especially with your music. The trick is to use the Velodyne optimally, I.e. with placement, EQ, time alignment, and crossover all sorted. Then you can spend on the main speakers optimally too. cheers Grant Link to post Share on other sites
warweary 787 Posted February 27 Share Posted February 27 Floorstanders + subs is best. Link to post Share on other sites
Graham75 0 Posted February 27 Author Share Posted February 27 Hi All, thanks for your replies. I will keep the sub as suggested and check out your recommendations for floor standers. Cheers, Graham. Link to post Share on other sites
KRSDarwin 2,419 Posted February 27 Share Posted February 27 Howdy Graham, These lists may give you some assistance but they don’t comment on whether they would partner well with your NAD. Link to post Share on other sites
Graham75 0 Posted February 27 Author Share Posted February 27 Thank you Link to post Share on other sites
Irek 603 Posted February 27 Share Posted February 27 I think you either need second subwoofer or better subwoofer. Active crossover might help as well. + the popular REW + Umik. Link to post Share on other sites
Graham75 0 Posted February 27 Author Share Posted February 27 Hi Irek, the subwoofer is more than capable; there is a gap in the mids that needs to be filled. I've adjusted the crossover on the sub but the 5 inch drivers in the bookshelf speakers cannot keep up. I appreciate your input. Link to post Share on other sites
