smart 180 Posted February 26 Share Posted February 26 (edited) Item Condition: MINT !! Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: PERTH State: WA Payment Method: CASH,EFT,Paypal Reason for selling: moved to KEF floorstanders Further information: LS50W acoustic design: featuring 5.25" Uni-Q driver, FEA designed cabinet, Constrained Layer Damping Bracing, Elliptical Flexible Port• KEF’s dedicated time correcting Digital Signal Processing (DSP) design• Three levels of customizable EQ settings• 192kHz/24bit high-resolution DAC decoding on each speaker• 2.4GHz/5GHz Dual-band Wi-Fi connectivity• Bluetooth 4.0 with aptX codec• Asynchronous USB connection• Digital input (TOSLINK)• L&R RCA Analogue inputs• Subwoofer output – controllable from iOS or Android app• Dedicated apps for iOS and Android• Touch-sensitive control panel with clear backlit display of inputs SpecificationsKEF reserves the right, in line with continuing research and development, to amend or change specifications. E&OE. Visit: KEF.COM for more about KEF and its products.ModelLS50 WirelessDrive unitsUni-Q driver array:HF: 25mm (1in.) vented aluminium domeLF/MF: 130mm (5.25in.) magnesium/aluminium alloy Frequency Range (-6dB)Measured at 85dB/1m40Hz – 47kHz (More bass extension)43Hz – 47kHz (Standard)46Hz – 47kHz (Less bass extension)Depending on speaker settingsFrequency Response (±3dB)Measured at 85dB/1m45Hz – 28kHz (More bass extension)50Hz – 28kHz (Standard)61Hz – 28kHz (Less bass extension)Depending on speaker settingsMax Output (SPL)106dBAmplifier Output PowerLF: 200W HF: 30WInputs2.4GHz/5GHz Dual-band Wi-Fi networkBluetooth 4.0 with aptX® codecUSB Type BTOSLINK OpticalRCA Analog Line Level Input10/100 Mbps RJ45 Ethernet (For network and service)OutputSubwoofer outputResolutionUp to 24bitDepending on source resolutionSampling RateUp to 192kHz (USB Type B)Up to 96kHz (TOSLINK Optical)Depending on source resolutionWi-Fi Network StandardIEEE 802.11a/b/g/nWi-Fi Network Frequency BandDual-band 2.4GHz/ 5 GHzBluetooth Range10mBluetooth Memory8 devicesDimension (H x W x D)300 x 200 x 308mm(11.8 x 7.9 x 12.1in.)WeightLeft Speaker 10.0kg (22.0lbs.)Right Speaker 10.2kg (22.5lbs.)Power Input100 – 240VAC 50/60Hz MINT CONDTION! with original box.manual.cables & remote Will ship eastern states at buyers cost. Photos: PLEASE READ If you include any reference to pricing whatsoever in this section (excluding RRP), your ad will not be approved If you are advertising multiple items, you must post one bulk price only, or post seperate ads for each item If you don't include photographs of the actual item being sold, your ad will not be approved You understand that a reasonable donation for selling fees is expected upon successful sale of your item - if you have previously sold items and not made a donation, your advertisement may not be approved. Edited March 5 by smart Info update Link to post Share on other sites
