SOLD: FS: Price Drop Audioquest Carbon USB Cable .75 metre Price Reduced
Item Condition: New
Shipping Options: Pickup available but audition is not available.,Shipping is included in price.
Suburb or Town: Perth
State: WA
Payment Method: PayPal, EFT, Cash on Pickup
Reason for selling: NLR
Further information:
New in Box - Unwanted Gift.
Shipping included within Australia.
Please add 3% if paying via PayPal.
PLEASE READ
  • You understand that a reasonable donation for selling fees is expected upon successful sale of your item
Edited by eostre23
Lower Price
  • eostre23 changed the title to FS: Price Drop Audioquest Carbon USB Cable .75 metre Price Reduced
    • By D’accordo
      Item Condition: Near New Shipping Options: Shipping is available at agreed cost. Suburb or Town: Oakleigh State: VIC Payment Method: Reason for selling: Need fund
      AudioQuest Firebird ZERO Speaker cables 8 feet( 2.5m) Space terminate current Australian RRP is 26700AUD.
      https://www.ambertech.com.au/3m-firebird-zero-spk-cable-banana-to-banana-(-silver)-audioquest
      The second top of the new Mythical Creature range. The cables is in excellent condition only used for a few time.
      Features
        ZERO: NO CHARACTERISTIC IMPEDANCE FOR UNCOMPRESSED CURRENT TRANSFER
      The integrity of any audio transient (instantaneous peak-to-peak voltage swing and current) delivered from a power amplifier to a loudspeaker has always been compromised. Whether the amplifier is valve or transistor, regardless of class of operation, the amplifier’s source impedance and loudspeaker’s load impedance are never critically matched. The speaker cable’s characteristic impedance is yet another culprit in a highly compromised non-linear electrical circuit. AudioQuest has always stated that all cables cause damage because the output is never as good as the input. However, by eliminating a speaker cable’s characteristic impedance, AQ’s ZERO Technology is an unprecedented step towards reducing that damage. The result is greater dynamic contrast, better audio transient response, and bass slam that are rendered seemingly without effort because the cable is not electrically restricting (strangling) the music.   FIREBIRD CONDUCTORS: SOLID PERFECT-SURFACE SILVER (PSS) AND SOLID PERFECT-SURFACE COPPER+ (PSC+)
      Solid conductors prevent electrical strand-to-strand interaction, major sources of distortion. Surface quality is critical because a conductor can be considered as a rail-guide for both the fields within a conductor, and for the magnetic fields that extend outside the conductor. The astonishingly smooth and pure surface of all AudioQuest’s Perfect-Surface metals nearly eliminates harshness and greatly increases clarity compared to lesser materials. The careful choice of the sizes of the PSS and PSC+ conductors ensures that FireBird’s performance is close to using all PSS Silver, but at a much lower cost.   GROUND-NOISE DISSIPATION (GND)
      This extremely effective patented common-mode noise-rejection technology is deployed on the ground path in almost all AQ AC Power cables, in addition to in AQ Bass & Midrange model speaker cables. The effectiveness of GND compromises audio above 10,000Hz, preventing the dedicated Bass & Midrange cable from being ideal for Full-Range use.   CARBON-BASED LINEARIZED NOISE-DISSIPATION SYSTEM (NDS)
      Today’s environment is saturated with radio-frequency noise that is extremely difficult to filter or reject. The frequencies of this noise from satellites, cellular towers, and Bluetooth, etc., are so extremely narrow that a conventional shield, or a series or shunt filter, is wholly inadequate. Much of the low-level signal that carries the harmonics and spatial cues that define high-resolution audio is masked by induced radio-frequency noise. AQ’s comprehensive Linearized Noise-Dissipation System combines multiple shields and a carbon-based linearized resistive network that turns most of this noise into heat. By "linearized," we mean that the system is equally effective across extremely wide bandwidth, rather than at selected frequencies only, as is more common. The remaining bad energy is effectively drained away from the sensitive amplifier circuits via directionally controlled signal and shield conductors.   DIELECTRIC-BIAS SYSTEM WITH CARBON-LEVEL RADIO-FREQUENCY TRAP (DBS)
      All insulation is also a dielectric whose electrical properties affect the integrity of the signal. When the insulation is unbiased, dielectric-involvement (absorption and non-linear release of energy back into the signal flow) causes different amounts of time delay (phase shift) for different frequencies and energy levels, which is a significant problem for very time-sensitive multi-octave audio. AudioQuest’s multi-patented DBS creates a strong, stable electrostatic field which saturates and polarizes (organizes) the molecules of the insulation. This minimizes the nonlinear time delays, resulting in clearer sound emerging from a “blacker” background. The inclusion of an RF Trap (a technology developed for AudioQuest’s Niagara Series of power products) in the DBS battery pack further reduces radio-frequency noise. The DBS battery packs will last for many years. A test button and LED allow for the occasional battery check.   FIREBIRD BIWIRING
      When possible, running separate cables to the treble and bass “halves” of a speaker considerably reduces distortion. BiWiring keeps the large magnetic fields associated with bass energy out of the treble cable, allowing the delicate upper frequencies to travel a less magnetically disturbed path, like taking the waves out of the water when you swim. The Rocket models of AQ speaker cable have two autonomous internal constructions, facilitating proper BiWiring within a single cable. The Type models of AQ speaker cable can be doubled-up, using one for treble and one for bass. However, doubling-up AQ’s ZERO Technology cables can be less of an improvement because of ZERO’s unrestricted wide bandwidth – using two ZERO Full-Range cables can actually allow more RF energy into the amplifier, whereas using a BASS with GND Bass & Midrange cable in combination with a ZERO cable for Treble significantly reduces total RF Noise. The BASS cable’s patented Ground-Noise Dissipation (GND) drains RF energy away from the amplifier’s output. When properly implemented, BiWiring has always been a way to get better performance for the same or less money. With GND, the improvements from BiWiring are considerably more dramatic. FireBird BASS with GND is an ideal cable for the Bass and Midrange inputs of a BiWirable or TriWireable loudspeaker when used in combination with FireBird ZERO or Dragon ZERO Full-Range cable on the treble input. FireBird ZERO can also be used with ThunderBird BASS as excellent cost-effective alternative.   MYTHICAL CREATURE COLD-WELDED TERMINATIONS
      Mythical Creature cables are Cold-Welded to AudioQuest’s extremely pure Red Copper Spades or Bananas. The bare copper is submerged (hung) in a vat of pure silver instead of being tumbled in a lower-grade solution. AudioQuest speaker breakouts and plug casings are not metal in order to not disrupt the signal’s magnetic field, and to not induce RF Noise into the conductors.
    • By Neo
      Item Condition: 9/10 Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Lane Cove State: NSW Payment Method: Cash Reason for selling: Upgrade Further information:
      Have all the packaging and tax invoice from Len Wallis audio, confirming that they are genuine.
      Length of the cable is 1.5m.  RRP is $2700 for that length
      Perfect for monoblock amplifiers, although how I had the Naim nap200dr placed in relation to the speakers, that was the perfect length.
    • By MAXXX
      Item Condition: Used, excellent Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Kardinya State: WA Payment Method: Reason for selling: bit short for current setup Further information:  As new, boxed USB cable 1.5m Audioquest Cinnamon.
      Product Description: AudioQuest Cinnamon USB 2.0 Type A To Type B Data Cable Terminations: Gold-plated for maximum signal transfer. Fitted with a USB type-A connector on one end and a USB type-B connector on the other end. Conductors: Solid Long Grain Copper Solid conductors eliminate strand-interaction distortion and reduce jitter. Silver-plated conductors are excellent for very high-frequency applications, like USB audio. The Cinnamon contains 1.25%. Insulation: The USB cable's solid Polyethylene insulation ensures critical signal-pair geometry. USB 2.0: This cable exceeds USB 2.0 data rate specifications. AudioQuest Product Code: AQ-CINNAMONUSB/1.5
      Postage for Australia $12 (Aus. Post satchel with tracking).
    • By Neo
      Item Condition: 9/10 Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Lane Cove State: NSW Payment Method: Cash, PayPal Reason for selling: Upgrade  Further information: Have all the packaging and tax invoice from Len Wallis audio. Length of the cable is 1.5m.  RRP is $2700 for that length
    • By Neo
      Item Condition: 9.5/10 Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Lane Cove State: NSW Payment Method: Cash Reason for selling: Upgrade Further information: have all the packaging and purchase receipt from Len Wallis. They are currently in use in the system but present as new. The DBS Black packs are $170rrp each just by themselves if you want to buy them separately.
      Length is 3 meters
      PLEASE READ
