JimmT 2 Posted February 24 Share Posted February 24 Hi all, Does anyone know anywhere/anyone that can repair gloss black speaker cabinets? Cheers James Link to post Share on other sites
DEANO23 408 Posted February 24 Share Posted February 24 Might help if you put up a picture of the damaged speaker Link to post Share on other sites
GregWormald 1,836 Posted February 27 Share Posted February 27 Any high class spray painter potentially could do the job. It will depend on the damage, the type of paint/polish required, etc. Link to post Share on other sites
qwerter 658 Posted February 27 Share Posted February 27 If it is a polyester finish, it can be spot repaired. Link to post Share on other sites
JimmT 2 Posted February 27 Author Share Posted February 27 They originally were dragged along the floor by a ‘courier’ I had them repaired. The filling of the deep cracks were fixed up but the paint used was wrong and it cracked. The new paint can be removed by spirits or by sanding, but underneath is a sanded back clear coat and the repair work. I need someone who can remove the new paint, sand and re finish in 2 pack. Speakers can be removed from the cabinet, apart from the decoupled tweeter (they are B&w cm10 s2) Link to post Share on other sites
qwerter 658 Posted February 27 Share Posted February 27 Looks like a sand and polish job. Link to post Share on other sites
JimmT 2 Posted February 27 Author Share Posted February 27 Very helpful. Needs someone who knows what there doing to repair it Link to post Share on other sites
qwerter 658 Posted February 27 Share Posted February 27 Yes, make sure they use flat blocks while sanding Link to post Share on other sites
cheekyboy 4,379 Posted February 27 Share Posted February 27 (edited) 9 hours ago, JimmT said: They originally were dragged along the floor by a ‘courier’ I had them repaired. The filling of the deep cracks were fixed up but the paint used was wrong and it cracked. The new paint can be removed by spirits or by sanding, but underneath is a sanded back clear coat and the repair work. I need someone who can remove the new paint, sand and re finish in 2 pack. Speakers can be removed from the cabinet, apart from the decoupled tweeter (they are B&w cm10 s2) Hello James, Get some recommendations near to you for a panel repair shop that has a good painter and then see if they’re interested in quoting a small job for you. The damaged surface will need to go back to the substrate, primed and the 2 pack poly applied. The other surfaces may just need to be prepared and an intermediate coat applied prior to the 2 pack finish coat. Cheers, Keith Edited February 27 by cheekyboy 1 Link to post Share on other sites
Paul R 100 Posted February 28 Share Posted February 28 Get in touch with Mike Kontor. Mike had a guy do incredible work on his Note Perfect Speakers, who was as I recall, was a panel beater? Link to post Share on other sites
JimmT 2 Posted February 28 Author Share Posted February 28 Hi Paul, thanks for that, do you have Mikes details so I can give him a shout? cheers james Link to post Share on other sites
