Recommendations needed - 12ax7 / ECC83 for phonostage
Hi all, I am looking for some advice as to where best to source three (including a matched pair) of 12ax7 valves for my minimax phono preamp. It also takes a 6x4 rectifier but not sure if I need /want to replace this.
I have the stock valves that came with the amp from Eastern Electric and I’ve had it for 10 years now, just upgrading my main amp and want to try something better that will do the rest of my system justice. (Michell Gorbe/SME m2/9 / Lyra/ Sugden Masterclass/ Goodman Magnum K’s.)
I’m bit wary of eBay so would really appreciate some guidance for reputable resellers.
I’ve read a fair bit about different types, my budget is a few hundred dollars.
Thanks in advance !
This very much depends on whether you would like pursue new production tubes or vintage types. eBay is fine for both if you look at the previous feedback/score of the seller - the higher the better.
Low noise tubes would be something to think about in a phono stage. Vintage types such as the E83CC with triple mica construction would be a good starting point. Mullard or Brimar box plate square getters are also recommended.
Edit: Here is a nice pair for you to consider from a trusted seller that is also an SNA member:
https://www.ebay.com.au/itm/CSF-Thomson-France-early-1960s-12AX7S-ECC803S-strong-matched-tubes-/164316442919
Edited by xlr8or
Thanks Kirk, I am definitely more than happy to have a bit of fun trying vintage types.
I haven't heard of those CSF Thompson France ones before but I'll have a good look.
If I went for those CSF say (for the second stage and buffer stage of left/right channels - according to my manual)  do you have any recommendations for the centre position on my Minimax (first amplifier stage for both channels) and for the 6x4 voltage rectifier? The seller has a Telefunken 12AX7 ECC83 for $96 or Soviet 12ax7 triple mica grey plate at $20.
Another seller has a GEC 6x4 for sale here  https://www.ebay.com.au/itm/GEC-CV4005-6063-ruggedised-6X4-rectifier-tube-New-in-orig-Box/303886745866?hash=item46c10fc10a:g:Re4AAOSwp4ZgH00-
Any thoughts on these options. I guess Im trying to squeeze as much out of the preamp as I can within reason.
Edited by Shaunmaxr
For the first stage, I would recommend this one:
https://www.ebay.com.au/itm/VINTAGE-MULLARD-1957-12AX7-ECC83-BOX-PLATES-BRITISH-MADE-VALVE-TUBE-/193504004091
Regarding the 6X4 my vote goes towards this Genalex U78:
https://www.ebay.com.au/itm/303886745866
Edit: Here is another earlier vintage U78:
https://www.tubemonger.com/GEC_GENALEX_1958_59_CV4001_6X4WA_NIB_England_p/2060m.htm
Edited by xlr8or
I've been through a number of NOS tubes (GE 5 star, RCA Cleartops, Mullards etc), without spending a fortune I would try some new JJ Goldpins, you might be surprised.
9 hours ago, Shaunmaxr said:
Excellent work. Please report back with your listening impressions when received. You can then also invite me and others over to have a listen. 😁
😆 I might do that.
I have had the Minimax with stock EE tubes since circa 2010 but having just upgraded my integrated from a Sugden a21A to an Ia4 it got me thinking I should try and see what this thing is capable of.
I've also grabbed the British Mullard Box Plate, and the pair of the French CSF Thompson as well.  Hoping the French and the English get on well for a change.
Quite looking forward to the post arriving now. I'll let you know how it goes.
    • By Mr.Anderson
      Item: A Pair of Telefunken 12AX-7 Smooth Plate (selected tube if possible)
      Price Range: $250 - $300
      Item Condition: New or Used
      Extra Info: Looking for a pair of TFK 12AX7 Smooth plates, preferably selected tubes.
      Do let me know if anybody is willing to part with theirs.
      Cheers..
    • By Atmaj
      Item Condition: Used Shipping Options: Pickup available but audition is not available. Suburb or Town: NARRE WARREN State: Victoria Payment Method: Cash on Pickup Reason for selling: Upgrading Further information:
      Up for sale is Yaqin MC 100B Integrated tube/Valve amplifier in excellent working condition along with $300 worth of upgrade.
      This is a true duel mono block amp having 2 seperate power transformer for each channel (hence there are 4 transformer rather than 3 which are on most of tube amps).
      Pre-amp tubes have been upgraded to Electro Harmonix 12AX7
      Coupling Capacitors have been replaced with Mundorf MCap Supreme 1uf. Capacitors are so big that they had to be mounted on chassis rather than the PCB (check photos).
      These 2 upgrade make this amp comparable to high end tube amplifier.
      A great sounding amplifier, ready to drive any speakers even less efficient speakers.
      FEATURES:
      Preamplifier uses SRPP amplification circuit and Nagao-type inverter, Cathode output circuit to promote.
      TWO connection mode: Ultra Linear Amplifier (UL) and triode (TR).
      Duel Mode: INTEGRATED AMPLIFIER mode or pure Power AMPLIFIER mode.
      The output transformer use audio special alloy and high strength Anaerobic enamel-insulated wire. It uses special coiling process.
      This amplifier is made with audio special Enthusiast electrolytic capacitor (MKP), capacitive cross-linked and high quality metallic resistance.
      SPECIFICATIONS:
      Performance Index
      Output power: 30W×2 (8O) Triode (TR) connection
      60W×2 (8O) Ultralinear (UL) connection
      Distortion: =1.5%
      Signal noise ratio (SNR): =90dB (A)
      Frequency Response: 5Hz~80KHz (-2dB)
      Input sensitivity: INTEGRATED AMPLIFIER mode: 0.25V / Power AMPLIFIER mode: 0.6V
      Vacuum tubes: KT88×4 6SN7×4 12AX7×2 (You can also replace it with 6550EH×4 6N8P×4 6N4×2)
      Dimensions: 390mm x 490mm x 190mm
      Weight: 30kg
      I have original box. Pick up from Narre Warren. Happy to post with buyers expenses and arrangements.
      PLEASE READ
    • By qwerter
      Item: Matched Pair Psvane 12AX7-T Mark II
      Price: $80 + shipping
      Item Condition: As New
      Reason for selling: NLR
      As new, matched pair of Psvane 12AX7-T Mark II
    • By d_caruso
      Item:  Matched pair Telefunken 12ax7 tubes
      Price: $280
      Item Condition: excellent - test as new
      Reason for selling: surplus
      Payment Method: EFT to mobile
      Extra Info: Ribbed plates. Tested as new With matching results by previous owner. I had them as spares but they’re using up too much space in the house.  They sound clear, super detailed and quiet in my phono stage. Heaps of air and tons of seperation IMO.
    • By d_caruso
      Item: Trio of Electro-Harmonix gold pin 12ax7 tubes
      Price: $88
      Item Condition: New
      Extra Info: These are the gold pin version. Current production Russian made tubes. They came as the ‘upgraded’ tubes with my phono stage, but I had vintage tubes I wanted to use. These have never been used.
