SOLD: 1 pair of Martin Logan Odyssey electro static speakers, 1 x Pass Labs X35 1800 watt amplifier, 1 x Pass Labs pre-amplifier, two units Glass stereo cabinet
Recently Browsing 0 members
Similar Content
By peppy
Item Condition: Very Good Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Castle Hill , NSW 2154 State: NSW Payment Method: Cash, PayPal Reason for selling: Not needed Further information:
Martin logan 15i Speaker Pair Purchased May 2020. Receipt Warranty May 2020 Condition is Used Local Pick :Sydney Castle Hill NSW 2154 Dont have original box but can package it safely and post. Local sale and pick preferred Photos:
PLEASE READ
If you include any reference to pricing whatsoever in this section (excluding RRP), your ad will not be approved If you are advertising multiple items, you must post one bulk price only, or post seperate ads for each item If you don't include photographs of the actual item being sold, your ad will not be approved You understand that a reasonable donation for selling fees is expected upon successful sale of your item
By LukevanO
Item: Audio Research VSi60, Martin Logan EM-ESLs (pair), Auralic mini, power conditioning and all cabling
Price: $5000 for the lot (prefer no split)
Item Condition: Excellent all round, Auralic a bit yellowed from sun.
Reason for selling: Cashflow crisis
Payment Method: Pickup only - Cash, COD Only
Extra Info: Amp and speakers were listed separately, now throwing in the other items to get this sold, due to a cashflow crisis (still ongoing!) forcing me to part with the system I always dreamed of. It’s all boxed up now at my home for quick sale, all in perfectly sweet working order, looks as new - with the exception of the Auralic mini. Really can’t deal with organizing shipping but am happy for an intermediary to hand over cash and collect for a courier. Sorry- lots going on! The amp alone is worth the $5k 🤦🏼♂️
By Ants2me
Item: Martin Logan Motion 10 Floor Standing Speakers
Price: $700 ONO
Item Condition: good
Reason for selling: No Longer Required
Extra Info: missing 1 floor spike!
for additional info follow the link
https://www.martinlogan.com/en/product/motion-10
By coffee25
Item: Martin Logan Motion FX Surround Speakers Black (Pair)
Price: $775 ONO (Inc $25 Donation to SNA)
Item Condition: 9/10 - some light scuff on rear from sliding up and down to wall mount.
Reason for selling: Selling due to upgrade
Extra Info: Have original boxes and wall mounts.
Specifications:
Frequency Response70–25,000 Hz ±3dB
Dispersion160° x 80°
Sensitivity91 dB/2.83 volts/meter
Nominal Impedance4 Ohms. Compatible with 4, 6 or 8 ohm rated amplifiers.
Recommended Amplifier Power20-160 watts per channel
Crossover Frequency4500 Hz
Crossover ComponentsCustom air core coil inductors. Polyester film capacitors in series and low DF electrolytic capacitors in parallel. Overall system thermal/current protection.
High Frequency TransducerTwo 1" × 1.4" (2.6cm × 3.6cm) Folded Motion Transducer with 5.25" × 1.75" (13.3cm × 4.4cm) diaphragm
Low Frequency Driver5.25" (10.2cm) paper cone with cast aluminum basket. Non-resonant asymmetrical chamber format. Rigid structured dust cap to reduce cone break-up modes. Folded bass reflex port.
Binding PostsPush style with banana jacks
Weight9.5lbs. (4.4kg) each
Overall Dimensions
(HxWxD)11.1 x 12 x 6 (28.2cm x 30.5cm x 15.2cm)
By Rori
Item: Martin Logan Balanced Force 212 Subwoofer with Martin Logan PBK kit
Price: $4k ONO (RRP $8k not including PBK kit)
Item Condition: Excellent 9/10
Reason for selling: Not using and taking up space
Extra Info: 2.5 years old, purchased from Big Picture People Narre Warren.
Plenty of reviews online about this subwoofer. It has 2 x 12" drivers opposing each other to cancel out vibrations. The outcome is clear, low distortion and clean bass.
The customisation for best in room response from the amp is second to none with low pass filtering, phase alignment, gain and when measuring with the PBK kit can give close to flat frequency response.
This sub looks amazing especially in piano gloss black. Can ship however it does weigh 65kg's... I have all boxes and accessories for it.
See specs and pics below.
Specs:
BalancedForce 212
System Frequency Response 18–120 Hz ±3dB; Anechoic through LFE effects input 20–120 Hz ±3dB;
Low Pass Filter Frequencies 30 - 80Hz
Phase 0°, 90°, 180°, 270° 0°
25Hz Level Control ±10dB at 25Hz ±10dB at 25Hz
Power Control On, Auto (12V Trigger), Off On, Auto (12V Trigger), Off
Room Correction Perfect Bass Kit (PBK) Ready (Sold Separately)
Woofers Two 12" (30.5cm) cast-basket, highexcursion, aluminum cone with extended throw driver assembly, sealed non-resonant asymmetrical chamber format
Amplifiers 2 x 850 watts
(3,400 watts peak system total) 850 watts
(1,700 watts peak)
Inputs RCA: Left, Right and LFE.
XLR: Left, Right and LFE.
Speaker Level: Left and Right banana jacks.
12V Trigger: 3.5mm
Mini USB (for PBK)
USB (for crossover & firmware updates) RCA: Left, Right and LFE.
12V Trigger: 3.5mm
Mini USB (for PBK)
Output (RCA) Multi Out (for multi-sub connection) Multi Out (for multi-sub connection)
Input Impedance RCA: 10,000 Ohms
XLR: 15,000 Ohms per phase
Speaker Level: 10,000 Ohms per phase (20,000 Ohms red to black)
Power Draw Typical: 250 Watts
Idle: 30 Watts Typical: 125 Watts
Idle: 15 Watts
Weight 140lbs. (63.5kg) each 96lbs. (43.5kg) each
Overall Dimensions
HxWxD ( 57.4cm x 57.4cm x 58.2cm)
