Item Condition: Very good
Shipping Options: Pickup available and you can audition.
Suburb or Town: Melbourne
State: VIC
Payment Method: Cash on Pickup
Reason for selling: Downgrade
Further information:
Paid $12500, one owner, like new, no scratches, all papers
One speaker terminal screw is not very tight but I use banana plugs.
Klipsch  Palladiums P-F37's are a small brother of the famous P-F39F's.
The speakers are high sensitivity so that a 10 - 15W amplifier  will work fine.
https://www.areadvd.de/hardware/2008/klipsch_palladium.shtm
Klipsch Palladium P-37F Floorstanding Speakers (Natural)
As the ``smallest`` floorstanding loudspeaker in our high-end luxury Palladium Series, the P-37F features the flagship P-39F`s technology and gallery-like appearance in a slightly more compact but equally stunning package.
The P-37F’s carbon-infused, thermoset composite dual-horn configuration is unique to the Palladium family. It consists of a proprietary tweeter design, combining a chambered phase plug and Tractrix® Horn for extended high-frequency response; a second 90º by 60º acoustically damped Tractrix Horn is coupled to the midrange driver, resulting in precise performances.
Features:
·                           Modern design, incomparable craftsmanship and proprietary technologies
·                           Exotic zebra-grain Linia wood veneer cabinet
·                           0.75-inch horn-loaded tweeter, 4.5-inch midrange and triple 7-inch woofers
·                           Bass-reflex design via triple rear-firing ports
Specifications:
·                           Frequency Response:43Hz-24kHz +/-3dB
·                           Low Frequency Extension:31Hz
·                           High Frequency Extension:30kHz
·                           Power Handling: 275W continuous / 1100W peak
·                           Recommended Amplifier Power: 50 - 600W
·                           Sensitvity: 96dB @ 2.83V / 1m
·                           Nominal Impedance: 4 ohms
·                           Mid-Frequency Crossover: 550HZ
·                           High Frequency Crossover: 3400Hz
·                           Maximum Acoustic Output: 120dB (2 speakers in-room)
·                           High Frequency Driver:0.75`` (1.9cm) (titanium diaphragm compression driver mated to 90° x 60° Tractrix® Horn)
·                           Mid-Frequency Driver:4.5`` (11.4cm) (aluminum diaphragm compression driver mated to 90° x 60° Tractrix® Horn)
·                           Low Frequency Drivers: Three 7`` (17.8cm) (high-output, aluminum / Rohacell® /woven synthetic fiber hybrid cone woofers)
·                           Enclosure Material:Constrained layer MDF(medium density fiberboard)
·                           Dimensions (H x W x D): 118.1 x 50.2 x 49.5 cm EA
·                           Weight: 44.5kg EA
·                           Enclousure Type:Bass-reflex via triple rear-firing ports
PLEASE READ
  • You understand that a reasonable donation for selling fees is expected upon successful sale of your item
    • By sum1
      Item Condition: As New Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: BEVERLY HILLS State: NSW Payment Method: EFT, Cash on Pickup, Paypal with fees on the buyer unless sent as a personal payment Reason for selling: No Longer Used Further information:
      As New Condition.
      Complete with the original box, receipt and warranty.
      Purchased locally from Digital Cinema at 26/06/2020 so the local warranty still have a long validity on them.
      As far as I can tell there is no local store that stocked this speaker as i think the PSB brand is not popular in Australia even though its predecessor the Alpha B1 was popular worldwide and so is this new Alpha P5 .
      So ended up having to do an order in on them, used it for a short time after which I went to a smaller sized speaker.
      Supposedly PSB have great synergy with NAD amplifiers since they belong under the same parent company.
      Further Reviews
      https://www.stereophile.com/content/psb-alpha-p5-loudspeaker
      https://www.soundstagehifi.com/index.php/reference-components/1390-recommended-reference-component-psb-alpha-p5-loudspeakers)
    • By Davidbigeye
      Item Condition: As new Shipping Options: Pickup available but audition is not available. Suburb or Town: Dalkeith State: VIC Payment Method: Cash, EFT, Paypal confirmed Reason for selling: Not using, and want to buy a MV Agusta! Further information: DEQX unit, can act as digital premap too!
      I bought 2 of these, with the intention of building a system comprising of 3 main speakers, triamped horn setup for home theatre (and hifi), so I needed 2 DEQX units.
      I experimented with some other speakers (2 channel only) and triamped those with 1 DEQX unit, which I am still using.
      The horn setup never got off the ground, so I have an unused DEQX unit available.
      Today was the first time it has ever been turned on, just to verify it works!  It's brand new.
      This one was kitted out with the full digital in - digital out capability so you can go as far as having a seperate DAC on each speaker driver if you choose!
      It also has the balanced XLR output if you like to use it's internal dac(s).
      This one does the lot!
      If you are looking for an active crossover for an insanely good system; looking to time align drivers; and/or looking for room correction, etc...then this is a great unit.
      I am happy to assist in setting up for Perth based purchaser.  I am very familiar with DEQX.
      PLEASE READ
    • By candyflip
      Item Condition: As described below Shipping Options: Shipping is available at agreed cost. Suburb or Town: Bulleen State: VIC Payment Method: Paypal, EFT, Credit cards Reason for selling: latest finds
      The Corrs – Jupiter Calling
      2017 gatefold 2LP pressing
      NM/NM - BRAND NEW and SEALED.
      The album was primarily recorded live, with minimal overdubbing.
      While working on the album, producer T-Bone Burnett made use of 40 spools of two-inch tape and a Ludwig drum kit for the fullest analog sound.
      It works.
    • By dan-m9
      Item Condition: As New Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: Postmans Ridge or Toowoomba State: QLD Payment Method: Paypal (Buyer pays 2.6% fees or F&F with no fees), EFT, Cash on Pickup Reason for selling: NLR - Too many AMPs Further information:
      Fantastic sounding EL34 Tube AMP for the price and a perfect decent entry level for tubes.
      Little use and just barely burnt in, selling as I got two and change of plans for the second one.
      Comes with upgraded tubes. 2X Psvane EL34 and 1X Vintage RCA 12AX7 (long plate round getter). Happy to sell with no tubes for $60 less if wanted.
      Free Postage AU wide to Sendle/CouriersPlease locations.
      Paid nearly $500 AUD new after shipping/tax and before tube upgrade a month ago (took nearly a month to arrive/ship):
      Also a Drop link for more specs/reviews:
      https://drop.com/buy/appj-el34-tube-stereo-amplifier
      Thanks.
    • By Davidbigeye
      Item Condition: Mint Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: DALKEITH State: WA Payment Method: Reason for selling: Extra Info: JBL made 4 pairs of these in gloss black as special demo speakers, this is one of those pairs!  There are only 3 other sets in the world!
      They are the Special Edition models, in fantastic condition, lightly used, always with the best amps etc driving them (Goldmund, Krell...)
      These are amazing speakers, I thought I would keep them forever, but circumstances have changed...
      Give me a yell if you would like to see/hear them.
      David.
      Pictures: attached
