MOOV 108 Posted February 10 Share Posted February 10 (edited) Hi Guys, Can anyone help me does changing the speaker jumper can elevate the speaker performance? Any good jumper cable recommendations if it has positive impact? Thanks in advance Edited February 10 by Drunken Monk Link to post Share on other sites
Bill125812 3,717 Posted February 10 Share Posted February 10 (edited) Canare 4S11 make a great jumper Edited February 10 by Bill125812 1 1 Link to post Share on other sites
rantan 10,265 Posted February 10 Share Posted February 10 (edited) 13 minutes ago, Drunken Monk said: Can anyone help me does changing the speaker jumper can elevate the speaker performance? Definitely. 13 minutes ago, Drunken Monk said: Any good jumper cable recommendations if it has positive impact? @Bill125812 OR Geoff at Aurealis audio. for the famous Litz jumpers. ( Best jumpers EVER ) Edited February 10 by rantan 1 1 Link to post Share on other sites
Bill125812 3,717 Posted February 10 Share Posted February 10 Or Western Electric jumpers. End Game 2 1 Link to post Share on other sites
MOOV 108 Posted February 10 Author Share Posted February 10 2 hours ago, Bill125812 said: Thanks @Bill125812 @rantan Much appreciated your time. As I already use Aurealis IC and SC ,I will go with Aurealis. 3 Link to post Share on other sites
MOOV 108 Posted February 11 Author Share Posted February 11 (edited) Why the speaker manufacturers do not give importance to simple things like a quality Jumpers!!! Edited February 11 by Drunken Monk Link to post Share on other sites
muon* 3,302 Posted February 11 Share Posted February 11 The way I see it is as follows... Ideally you use the same cables as your speaker cables, and that is unpredictable for the speaker manufacturers naturally. It wouldn't make a lot of sense for them to use something better when a lot of owners will discard them to bi-wire and a lot of others will discard them to use the same cable as what their speaker cable is. 2 1 Link to post Share on other sites
aussievintage 4,068 Posted February 11 Share Posted February 11 4 hours ago, muon* said: It wouldn't make a lot of sense for them to use something better when a lot of owners will discard them to bi-wire and a lot of others will discard them to use the same cable as what their speaker cable is. and even more will realise that with the short distance, it does not matter 😜 4 1 Link to post Share on other sites
mloutfie 1,031 Posted February 11 Share Posted February 11 (edited) On 10/02/2021 at 7:20 PM, Bill125812 said: Canare 4S11 make a great jumper Just bought one last week and I found it to be bright on a metal tweeter. I'm thinking to get Duelund 12 GA Edited February 11 by mloutfie Link to post Share on other sites
MOOV 108 Posted February 11 Author Share Posted February 11 (edited) On 12/02/2021 at 7:03 AM, mloutfie said: Just bought one last and I found it to be bright on a metal tweeter. I'm thinking to get Duelund 12 GA Give atleast 50hrs for the jumpers to break-in as it's a new ..... Edited March 6 by Drunken Monk Link to post Share on other sites
mloutfie 1,031 Posted February 11 Share Posted February 11 13 minutes ago, Drunken Monk said: Give at least 50hrs for the jumpers to break-in as it's a new .....after if you do not like then you can change Yep that's what I'm doing now might wait longer than a month just to be sure before jumping to another cable. details is awesome compare to 12 awg jaycar cable just the harshness Link to post Share on other sites
Bill125812 3,717 Posted February 12 Share Posted February 12 1 hour ago, mloutfie said: Yep that's what I'm doing now might wait longer than a month just to be sure before jumping to another cable. details is awesome compare to 12 awg jaycar cable just the harshness The Canare 4s11 shouldn’t be harsh at all. 99.9i% pure quality copper. Give it some burnin time. I think it will calm dawn then Link to post Share on other sites
075Congo 338 Posted March 1 Share Posted March 1 Bought a set of KEF R3's and had Geoff Maloney (Aurealis Audio) make a set of 20 cm Litz 303 Jumpers to go with my 3 m Litz 303 Speaker cables. Look excellent and seemed to be an improvement over the R3 Linking mechanism. Considering the Atlas Cables Hyper 3.5 Speaker cables with the Hyper 3.5 Jumper cables they make. Cheers 1 Link to post Share on other sites
MOOV 108 Posted March 6 Author Share Posted March 6 On 01/03/2021 at 11:27 AM, 075Congo said: Considering the Atlas Cables Hyper 3.5 Speaker cables with the Hyper 3.5 Jumper cables they make Please share your experiences with Atlas....once you have... Link to post Share on other sites
075Congo 338 Posted March 6 Share Posted March 6 Will do they have just left Futureshop UK in London; not sure when they'll be delivered. 1 Link to post Share on other sites
075Congo 338 Posted April 2 Share Posted April 2 The Atlas Cables Hyper 3.5 Jumper cables arrived safely from the UK. Beautiful construction and finish. Just changed to a pair of Wilson Benesch Vectors (bought on SNA) which have their own Jumper Cables; so I'll put the Atlas Cables Hyper 3.5 Jumper cables up for grabs in the Classifieds. Cheers Link to post Share on other sites
