SOLD: XINDAK XA8800MN Monoblock Class A Power Amplifier Pair NSW
Item Condition: Very Good
Shipping Options: Pickup available but audition is not available.
Suburb or Town: Ryde
State: NSW
Payment Method: Cash on pickup
Reason for selling: Downsizing
Further information:
I am the second owner. These were purchased from another SNA member about 6 years ago.  Recently serviced by Chris at Kimil Electronics to check all OK and the bias was reset. These are two heavy buggers to lug around but they sound sweet as.
Very dynamic sounding with 200W power into 8 ohms, but Class A operating for finesse.  Ideal amp for many diamond or Beryllium tweeter speakers as well as ESLs and ribbon speakers.
Can be shipped as are in the original double boxes, but prefer personal pickup
From the Xindak website
The circuit features of XA8800MNE
Designed as a separate mono-channel structure, XA8800MNE is a full symmetrical current negative feedback Class A amplifier.
The input buffering amplifying stage adopts fast and wide-frequency amplifying circuit with cross coupling compensatory structure.
Darlington complex structure on the Voltage amplifying stage not only ensures enough voltage gain but also raises the input impedance to reach excellent match between the different stages. Besides, the adoption of Cascode circuit offers a good solution of the effect on the high frequency by the transistor junction capacitance. Thus the frequency width could be raised, the output characteristic curve of the bipolar transistor could be improved, the distortion of this stage could be reduced and high stabilization could be achieved.
On the current drive stage, it adopts high power FET to supply drive current for the end stage. The parallel output transistors on the end stage could reduce the output impedance, increase the output power, and improve the load capability with low resistor.
The static working current of 6 pairs high power transistors on the end stage as parallel output is about 300mA and each transistor works in the special linear area where current is higher. This could eliminate crossover distortion and switch distortion efficiently and reduce the output impedance. Equipped with impedance compensatory network including L、Rs、Rz and C on the output terminal, the load of this unit will be closer to pure resistor and difficult to cause self-excitation. Meanwhile, it could afford bigger damp to enhance the controlling ability of this unit to the loudspeaker.
In order to ensure the middle point voltage of this unit approximately to be zero, high quality operating amplifying components, high frequency non-inductance resistor, silver in glass capacitance and so on are put to good use to the loop current servo feedback circuit.
As for the power supply for the complete unit, each channel adopts 600W high quality annular transformer while the other parts adopts winding group on the power supply separately. Additionally the power supply for the power amplifying, voltage amplifying and protecting circuit are separated: the power supply for the power amplifying part is equipped with 50A bridge rectifier and 60,000MF filtering capacitance and supplies power directly after commutating and filtering; the power supply for the voltage amplifying adopts stable power supply with fast speed, low noisy, low impedance and strong ability to avoid the “ripple” to avoid the modulating disturbance caused by fluctuation of the power on the following stage and make the sound purer.
Additionally, this unit adds protection functions, including power-on delay concussion protection, zero point floating on the output terminal, over current and over voltage of the power transistor protection. In order to avoid the noisy when power-off, this circuit adds transient release circuit, power-on delay circuit and glittering indicating circuit for protection to make this unit more intellective.
Parameter Name Parameter Values
S/N Ratio ≥110dB
THD ≤0.025%
Input Impedance 47K ohms
Number of Channels 1
Output One Pair Gold Plated Binding Posts
Input Sensitivity 1.7V
Frequency Response 5Hz~150KHz (±0.5dB)
Input RCA*1, XLR*1
Rated Output Power 200W(8ohms),400W(4ohms)
Net Weight 24Kg
Dimensions (W*H*D) 305mm*202mm*427mm
PLEASE READ
  • You understand that a reasonable donation for selling fees is expected upon successful sale of your item
  • Like 5
Great amps.  Will drive just about anything. Lovely non fatiguing  sound. I used to have a pair.
You won’t do better for the money.
GLWTS.
  • Thanks 1
5 hours ago, kefacurus said:
I have the preamp to match these if anyone is interested. It is a very solid unit with remote.
So do I but not really for sale and it’s extremely clear and detailed, well made.
Hi Tom,
Good Nick.
Box size is 55 x 45 x 38cm.  Deadweight is 25kg per box.  there are 2 boxes.
Have original double boxes for each monoblock.
Russ
7 hours ago, Headbanger said:
Hi Tom,
Good Nick.
Russ
Thanks Russ, I'll grab them please mate. First time buying thru SNA so I'll message you again with my phone number and go from there if that's ok. Cheers
    • By jimmy.kl
      Item Condition: Good Shipping Options: Shipping is included in price. Suburb or Town: Dunedin State: New Zealand Payment Method: PayPal (or bank transfer if buyer covers intl. fee) Reason for selling: NLR Further information:
      A pair of Atsah NC500 NCore Class D monoblock amplifiers in carbonesque finish.
      These are very good. They barely sip angry pixies and won't heat your room while driving almost anything with lots of headroom to spare.   Located in New Zealand. Price is in Australian dollars and includes courier delivery estimated at 2-6 days. Will ship in original boxes.   A blurb:
      Building on the strong heritage of the UcD design of Class D amplifiers, NCore takes the things UcD does well and does them ten times better. Coupled with a dedicated switch mode power supply made specifically to work with the Class D design, this  amplifier not only nudges at the performance of the best linear amplifiers, but surpasses them in every aspect of sound quality. Efficiency is over 90% and under normal operating conditions they radiate only small amounts of heat, thus negating the need for large external heatsinks.   Some reviews: https://docs.wixstatic.com/ugd/c888f1_88e9dee135de4de5bd6b87436df40a2d.pdf http://v2.stereotimes.com/post/acoustic-imagery-atsah-nc500-monoblock-amplifiers   From the NCore designer Bruno Putzeys: "In terms of value, I think the Acoustic Imagery Atsah 500 monoblock is a really good implementation of the Ncore." https://www.soundstagexperience.com/index.php/wesworld-menu/feature-articles-reviews-menu/720-bruno-putzeys-navigates-toward-the-state-of-the-art
      Specs:                               400 Watts into 8Ω Output power:  700 Watts into 4Ω                               550 Watts into 2Ω THD + N, IMD:  0.001% Frequency response: 0Hz – 50kHz +0/-3dB all loads Gain: 26dB Efficiency @ full power: 93%   Mains input: 230V/50Hz via IEC switched fused socket Signal input: max ±15V via Neutrik® XLR socket Loudspeaker connection: pole terminal binding posts - accept banana plugs, spades or bare wire Dimensions: 200mm width 220mm depth 65mm high Weight: 2 Kg   Photos:
      PLEASE READ
    • By RAF13
      Item Condition: Excellent 9/10 Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Perth State: Western Australia Payment Method: Paypal (+ Fees or F&F), Bank Deposit, Cash on Pickup. Reason for selling: Upgrade Further information:
      These amplifiers have hardly been used and are in excellent condition.
      They come complete with all original factory accessories and packaging.
      Current RRP $4995.00
      Enjoy an unheard of level of control and command from your loudspeakers with the Stellar™ M700, one of the most extraordinary under $5,000 power amplifier pair ever crafted. The M700 combines the slam, linearity, control and pacing of a Class D output stage with the warmth, grace, and rich inner detail of Stellar’s Class A Analog Cell. The results are nothing short of breath-taking. Liberate all the toe-tapping energy trapped in your media library. Plumb music’s subterranean depths as your system gives you more bottom end than you thought possible. Revel in rich layers of fine, full detail. Marvel at the deep, extraordinary, wall-to-wall soundstage. Control your loudspeakers as never before. Effortless. Lush. Stellar.
      The problems faced when crafting a new power amplifier are many—delivering sufficient power, control, frequency extension, and dynamics while maintaining a perfectly layered soundstage under the most complex musical passages.
      All amplifiers sound different. What determines sound quality are the components and topologies of the amp’s input voltage stage and output current stage. Each section should complement the other. Between them, the amp develops its sound.
      Stellar’s design imperatives—affordable pricing, uncompromised sonics—were major challenges solved by the invention of a unique new circuit christened the Analog Cell™.
      Stellar engineer Darren Myers had planned from the outset to take advantage of Class D’s high current, low distortion, ruler flat linearity for the output stage—knowing full well it is the input stage that determines sonic character. This critical interface between preamplifier and power amplifier is where Stellar’s magic would be unveiled; where Myers could lavish upon the music the sweet, tube-like quality of Class A biased MOSFETs. His challenge was to synergistically marry both input and output topologies, for which he invented Stellar’s Analog Cell.
      The Analog Cell is the heart of the M700’s musicality, where richly overlayed layers of music’s inner details are preserved even in the most complex orchestral crescendos. The Analog Cell is a proprietary, fully differential, zero feedback, discrete, Class A MOSFET circuit, hand-tuned to capture the smallest micro dynamics without sacrificing the loudest macro dynamics music has to offer.
      Features
      Mono power amplifier pair Zero-loss Analog Cell input stage Powerful MOSFET balanced output stage RCA Single ended input XLR “true” balanced input 350 watts into 8Ω 700 watts rms into 4Ω 2Ω stable Less than 0.1% thd 20Hz to 20kHz at rated power Damping factor 1100 for excellent loudspeaker control Front panel standby button Efficient operation with very little heat Dual, solid copper, plated, output binding posts 27 pounds Input 12-volt trigger
      PLEASE READ
    • By Batty57
      Item Condition: Used but excellent Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Albany State: Western Australia Payment Method: Paypal, EFT, Cash Reason for selling: Not being used Further information:
      Supratek Mondeuse Monoblocks.
      Purchased direct from Mick Maloney, this pair were part of his personal collection.
      They are hand made to custom order and are in excellent condition.
      I have upgraded the speaker terminals to USA made silver terminals.
      Tube component:
      8 X KT88 Matched Octet Genalex Gold Lions. Produces 100 watts per channel.
      4 x GZ34 Matched Quad Telefunken Black Diamonds.
      2 x 6SN7 Matched Pair Electro-Harmonixs Gold Pins.
      2 x 6H30 Matched Pair Sovtec.
      Overall condition is excellent. No base plates are included, as Mick didn't use them.
      Housed in beautiful solid Sheoak cabinets.
      Can supply generic power cables, but highly recommend quality cables.
      These are simply superb and a very rare find. No known issues.
    • By Sledge
      Price: $2000 Item Condition: 9.5/10 (only as not new) Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: Canberra State: Australian Capital Territory Payment Method: COD or DD Reason for selling: Lack of use, downgrading. Further information:
      Original owner
      Flawless condition
      Done less than 100hrs
      RRP replacement $4,399.
      Review:
      http://www.hifi-review.com/152615-audiolab-8200mb.html
      Specs:
      Rated Power Output 250W rms into 8 ohm / 400W rms into 4 ohm
      Frequency Response 0.1Hz - 120kHz (-3dB)
      Input Sensitivity 1.63V rms
      Input Impedence 20kΩ balanced, 15kΩ unbalanced
      Gain 29.0dB at 1kHz
      Signal-to-Noise Ratio Better than 88dB
      Total Harmonic Distortion (THD) Less than 0.03%
      Inputs Balanced XLR and Single-ended RCA
      Dimensions (H x W x D) 150 x 216 x 379mm
      Weight 9kg each
      Colour Choice Black
    • By Audionutz
      Item: Nuforce Reference 9SE Rev3 Monoblocks
      Price: 2095.00
      Reason for selling: Retiring audiophile
      Payment Method: Pickup - Cash, Paypal plus fees, COD Only
      From the collection of a well known Sydney audiophile.
      Highly rated Audiophile monoblocks. Amazingly powerful & offer high end sound at a fraction of the size & cost of comparable linear amplifiers.
      Many reviews online - perfect match for Maggie’s especially, or so I’ve been told.
      Will ship Worldwide with packing & insurance at buyers cost.
