Item Condition: Great
Shipping Options: Pickup available and you can audition.
Suburb or Town: Pyrmont
State: NSW
Payment Method: Cash on pickup
Reason for selling: Downsizing
For sale a pair of KEF Q100 bookshelf speakers in white finish, and stands. Both were purchased in new by be in 2016, and I'm selling because I have downsized.
These are great speakers, both in sound and looks. I would say they are still in new condition, no blemishes or scratches.
The stands are "TransDeco" branded. I don't know anything about them other than the fact I bought them off Amazon and they look good with the KEFs.
Unfortunately I don't have the original packaging for either speakers or stands, but I don have the original accessories pack including manual and spare baffles, etc.
    • By Doctor Faustus
      Item Condition: Excellent Shipping Options: Shipping is available at agreed cost. Suburb or Town: Sydney State: NSW Payment Method: Cash, EFT or Paypal (buyer pays fee) Reason for selling: NLR
      "A superbly made product that produces superb sound" - Michael Fremer, Stereophile
      Stereophile Class A Recommended Component
      Current model - rrp  $7990 The manual, alternative impedance cards and extra high quality resistors are included. Use the preselected impedance jumpers or make your own custom jumpers with supplied cards and resistors.
      Review:
      "The Audia Flight Phono combined pitch-black backgrounds and world-class dynamic presentation with a clean, ultrafast top end and a taut, well-extended bottom end." Stereophile Class A Recommended Component
      "...nothing but sonic pleasure... the Flight Phono produced music out of what subjectively sounded like an even blacker backdrop, and probably partly because of that, its soundstage presentation was among the most transparent, deep, and three-dimensional I've heard from any phono stage."
      MF - Stereophile
      A separate power supply, dedicated input preamplifier boards, high gain (74dB maximum) and low noise are only a few of its characteristics.
      The separate power supply was chosen to improve the shield of the preamp and to reduce the vibrations and resonance from the transformers to zero.
      Power supply
      The Audia Flight Phono Preamp's power supply is separate from the preamp chassis. A 50VA toroidal transformer supplies the analogue stages. On it is placed the first power supply (+/- 38V).
      Inside the separate power supply there is a 15VA toroidal transformer as well, to supply the relays and logic control. Previous user selections are stored in memory. To receive the commands from the pushbutton of the preamp chassis without electrical connections, several opto-isolators are used.
      There is also a low noise MOSFET power supply (+/-28V) on the preamp chassis for the second gain stage and another power supply for the first gain stage (+/- 15V). Thus, there are six power supplies in total!
      Preamp
      The Audia Flight Phono Preamp is based on Audia Flight's current feedback philosophy. The MC and MM input preamp boards are different, because MC and MM cartridges have different electrical characteristics. The MC preamp board is a transistor input preamp with 64 dB of gain. The MM preamp board is a differential transistor input stage with 40dB of gain. Both have low noise and low offset output. On both input boards, the impedance selectors are close to the input stage and are made by professional gold jumpers. Custom resistors can also be used for precise cartridge matching from the rear panel.
      After the first gain stage is the input selector, which is made with gold contact relays. Following this is the RIAA filter in passive configuration. It is made with 1% polypropylene and polystyrene capacitors. In this position, it's possible to select a subsonic IEC filter as well.
      The second gain output stage, which is completely redesigned, has improved speed and signal-to-noise (S/N) ratio. The second gain stage is switchable from 24 dB to 34 dB and has a balanced XLR output.
      A mono selector is an important element in achieving the best sound while using a stereo cartridge to play a mono record. The Audia Flight Preamp's mono selector sums the left and right channels together in the same manner as a mono cartridge would, which provides improved sonic performance.
      The Preamp board features DC offset protection; if there is an offset voltage, this feature will protect the unit and all others connected to it.
      Information:
      Gain MC 64 dB + 10 dB (74 dB in total) / MM 44 dB + 10 dB (54 dB in total) Frequency response (1Wrsm, -3db) 5Hz - 120 KHz THD <0.05% S/N ratio >90dB “A” weighted RIAA accuracy +/- 0.1 dB Channel Unbalance <0.04 dB Stereo separation >95 dB @ 10 KHzMC input impedance from 7 ohm to 980 ohm in eight steps plus a custom resistor value MM input impedance from 47pF to 600 pF in twelve steps plus a custom capacitor value Output impedance All outputs 500 ohm Phase Non inverted Maximum consumption 65WDimensions and weight 420x92x330mm (WxHxD), 10.5 Kg Original Box not included
      Edited December 29, 2020 by Doctor Faustus .
    • By jdh500
      Item Condition: Original owner Used but works as new Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: West Ryde metro Sydney 2114 State: NSW Payment Method: Cash on pickup, EFT, Paypal Reason for selling: NLR upgraded to Bel canto DAC 3.5 mk2 Further information:
      Message me with any questions, purchased locally from Sydney HiFi dealer, comes supplied with original packaging, remote, power cord and user manual. Designed and Manufactured in the USA.
      This is roon tested, works perfectly with all digital sources upto 24/192, also has a 24/96 usb input, true analogue input that can be set as a handy HT bypass to allow seamless integration with Home theatre receivers for better 2ch music, comes equiped with optical Tos link, 2x coax digital inputs, AES xlr style digital input and usb and analogue input.
      Both balanced and unbalanced output for connection to power amp or high end pre-amp, the DAC 2.5 can be set for fixed or variable output.
      The current Bel canto DAC 2.7 is near identical other than the usb input higher 24/192 bit rate but retails for over $4000.
      Pickup available, otherwise can ship at buyers cost probably $30 to $40.
      link to manual:
      https://belcantodesign.com/pdfs/UG_DAC2_5v1.pdf
      PLEASE READ
    • By Luke1811
      Item Condition: Excellent Shipping Options: Shipping is available at agreed cost. Suburb or Town: Brunswick East State: VIC Payment Method: Paypal EFT, Cash Reason for selling: Upgrade Further information:
       I am selling my Cambridge CX80 it has been a great amp. I purchased it from Carlton AV 24 months ago.
      The reason I am selling is having recently upgraded to a Devialet integrated.
      The CX80 has minor marks shown in the photo apart from that it is a awesome bit of kit.   i don't have the original box unfortunately.
      PLEASE READ
    • By VTo
      Item Condition: immaculate Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: St Kilda State: VIC Payment Method: EFT, Cash on Pickup Reason for selling: nine sets of speakers - all but one must go Further information:
      The Arcona 40s have had a good life so far, with light use over the few years. I am their first owner and they are in immaculate condition. Grilles were never mounted as I believe they look far better without them.
      Their original boxes are available for packing. Happy to negotiate shipping however, and as always, pick up is preferred.
      Very heavy, powder coated metal stands are also available at a negotiated price.
      I will take offers however, no lowballing please.
      Donation will be made according to guidelines.
       “The ARCONA 40’s cabinet, when viewed from above, has the now familiar, diffraction busting parabolic shape; a truncated teardrop tapering toward the rear. It’s constructed of CNC-milled MDF, and is built up from thin, 22 mm slices vertically stacked in sequence. The sheep’s wool damping material is reassuringly old school. On the rear is a recessed flat, on which the WBT Nextgen binding posts are mounted. Height is 14.2″ or 36 cm, width is 8.3″ or 21 cm, and its depth is 13″ or 33 cm. Each speaker weighs just shy of 27 pounds.”
      PLEASE READ
    • By VTo
      Item Condition: Good condition for its age Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: St Kilda State: VIC Payment Method: EFT, Cash on Pickup Reason for selling: Further information:
       This tuner has spent the last 5 years in storage. According to the HiFi gods' rules, if it is not in use it has to go.
      PLEASE READ
