What would be the best way to cut a notch in Jarrah ?
With circumstances being what they are, i have found myself with some free time and feel compelled to get a start on some of my audio projects.
I was thinking of creating something like this but am unsure as to the most effective way to cut the notch out.
The notch would be around 40mm x 30mm.
Any feedback would be appreciated.
Thanks.
I’m no expert, but seeing that the inner corners are rounded, I’d drill them at the required radius and cut the straights with a jigsaw. Clean up with a file.
Thanks for that Steffen.
The inner corners dont have to be rounded, but your suggestion has got the mental gears turning.
if you need a whole bunch, size a piece of wood using a thicknesser then route out the cutout, then chop to depth with a dropsaw.  if you only need a few, you can do the whole thing with just the dropsaw using the depth stop to hog out the cutout.
Thanks r3x.
I might not follow this all too well (the last time i worked with timber was in the early 90s) but i appreciate your input.
I think i'd better let someone professional handle this as i dont want to make a mess of things.  When i find some professional help, i'll have the text of your msg on the display.
