gat474 1,604 Posted January 31 Share Posted January 31 Item: Logitech THC 2 ch comOuter speakers with 8” sub Price Range: How does a $10 donation to the charity of your choice sound? Item Condition: New or Used Extra Info: Located for pick up only in Moonee Ponds. Logitech computer speakers. About ten years old. Still works fine and actually sounds acceptable on music and would be terrific for gaming with loads of volume and power from the sub. Not sure how much sub it does, probably best called a woofer. Just need to buy yourself a 3.5 mm Female stereo plug to what ever you are plugging it into. I was using 3.5 mm to 3.5 from the computer sound card. I was using this at work for years and the test and tag people even tagged it. Some marks, residual stickers on the back of the speakers but it will clean off with some chemical cleaner or elbow grease. PM me for pick up. No need to show proof of donation, your word is good enough for me. Please don't forget to report your post as FOUND when possible. (You can now delete this text). Link to post Share on other sites
Moderators wolster 4,848 Posted February 28 Moderators Share Posted February 28 And picked up. More SNA generosity 👍 Link to post Share on other sites
