Andrew.Saxby 0 Posted January 26 Share Posted January 26 Hi guys, Has anyone got a list of the specs for a SVS-PB12 PLUS/2. I can't find a full list on the internet Thanks in advance Link to post Share on other sites
jamiebosco 344 Posted January 26 Share Posted January 26 Not a lot around on these, I'd contact Ed Mullen at SVS, he will surely have every piece of information for this sub Amp. Power: BASH High-efficiency 900W hybrid-class, digital-switching power amp Rated Impedance: 14 Ohms Impedance, (10 - 200 Hz) averaged for 16, 20 & 25 Hz tunings: 11.3 ± .1 to 58 +3, -4 Ohms Frequency Response (+/- 3 dB): 23 Hz (-3 dB) - 305 Hz (+ 3 dB) (25 Hz system tuning) 18 Hz (-3 dB) - 305 Hz (+ 3 dB) (20 Hz system tuning) 14 Hz (-3 dB) - 305 Hz (+ 3 dB) (16 Hz system tuning) Resonance Frequency: Variable: 16, 20 or 25 Hz Bass Principle: Bass reflex Shipping Weight: 74.8 kg (165 Lbs) Cabinet Dimensions (W x H x L): (19"x 26.5"x 28") Active Processors: Crossover: active lowpass filter, variable,40 - 120 Hz Variable phase (0 -180 degrees), and stepped highpass filter (Bypass, 16, 20 & 25 Hz) Connection: Line Level: RCA jacks; speaker level: 5-way binding post Recommended Placing: Manufacturer suggests corner placement. Link to post Share on other sites
Snoopy8 3,569 Posted January 26 Share Posted January 26 https://www.audioholics.com/subwoofer-reviews/svs-pb12-plus-2 There are some details when you expand the specs. Link to post Share on other sites
Andrew.Saxby 0 Posted January 26 Author Share Posted January 26 Does anyone have a idea on what this unit is worth ? No issues and has the upgraded 12.3in SVS drivers Thanks in advance Link to post Share on other sites
Snoopy8 3,569 Posted January 26 Share Posted January 26 Suggest you learn how to use search... https://www.stereo.net.au/forums/topic/292678-relist-svs-pb12-plus/ https://www.stereo.net.au/forums/topic/228022-2-x-svs-pb12-plus2-subwoofers/ Link to post Share on other sites
