EXPIRED: FS: IsoTek EVO3 Sequel Power Cable 2M (AU Plug C13) New In Box
Recently Browsing 0 members
Similar Content
By QT- kWang
Item Condition: very good Shipping Options: Pickup available but audition is not available. Suburb or Town: Doncaster State: VIC Payment Method: cash Reason for selling: NLR
Dear All Stereonet members.
i am listing for sale Marklevinson 20.5 Mono block Power Amplifier. It pure 100w class A. If you want more detail of these amp please Pm. I will response as soon as i can
https://www.stereophile.com/content/mark-levinson-no26-preamplifier-no20-monoblock-power-amplifier-no205-measurements
Photos
PLEASE READ
If you include any reference to pricing whatsoever in this section (excluding RRP), your ad will not be approved If you are advertising multiple items, you must post one bulk price only, or post seperate ads for each item If you don't include photographs of the actual item being sold, your ad will not be approved You understand that a reasonable donation for selling fees is expected upon successful sale of your item
- if you have previously sold items and not made a donation, your advertisement may not be approved. -
By olegau
Item Condition: Very good Shipping Options: Pickup available and you can audition. Suburb or Town: Melbourne State: VIC Payment Method: Cash on Pickup Reason for selling: Downgrade Further information:
Paid $12500, one owner, like new, no scratches, all papers
One speaker terminal screw is not very tight but I use banana plugs.
Klipsch Palladiums P-F37's are a small brother of the famous P-F39F's.
The speakers are high sensitivity so that a 10 - 15W amplifier will work fine.
https://www.areadvd.de/hardware/2008/klipsch_palladium.shtm
Klipsch Palladium P-37F Floorstanding Speakers (Natural)
As the ``smallest`` floorstanding loudspeaker in our high-end luxury Palladium Series, the P-37F features the flagship P-39F`s technology and gallery-like appearance in a slightly more compact but equally stunning package.
The P-37F’s carbon-infused, thermoset composite dual-horn configuration is unique to the Palladium family. It consists of a proprietary tweeter design, combining a chambered phase plug and Tractrix® Horn for extended high-frequency response; a second 90º by 60º acoustically damped Tractrix Horn is coupled to the midrange driver, resulting in precise performances.
Features:
· Modern design, incomparable craftsmanship and proprietary technologies
· Exotic zebra-grain Linia wood veneer cabinet
· 0.75-inch horn-loaded tweeter, 4.5-inch midrange and triple 7-inch woofers
· Bass-reflex design via triple rear-firing ports
Specifications:
· Frequency Response:43Hz-24kHz +/-3dB
· Low Frequency Extension:31Hz
· High Frequency Extension:30kHz
· Power Handling: 275W continuous / 1100W peak
· Recommended Amplifier Power: 50 - 600W
· Sensitvity: 96dB @ 2.83V / 1m
· Nominal Impedance: 4 ohms
· Mid-Frequency Crossover: 550HZ
· High Frequency Crossover: 3400Hz
· Maximum Acoustic Output: 120dB (2 speakers in-room)
· High Frequency Driver:0.75`` (1.9cm) (titanium diaphragm compression driver mated to 90° x 60° Tractrix® Horn)
· Mid-Frequency Driver:4.5`` (11.4cm) (aluminum diaphragm compression driver mated to 90° x 60° Tractrix® Horn)
· Low Frequency Drivers: Three 7`` (17.8cm) (high-output, aluminum / Rohacell® /woven synthetic fiber hybrid cone woofers)
· Enclosure Material:Constrained layer MDF(medium density fiberboard)
· Dimensions (H x W x D): 118.1 x 50.2 x 49.5 cm EA
· Weight: 44.5kg EA
· Enclousure Type:Bass-reflex via triple rear-firing ports
PLEASE READ
By QT- kWang
Item Condition: used but very good condition Shipping Options: Pickup available but audition is not available. Suburb or Town: Doncaster State: VIC Payment Method: Cash Reason for selling: Upgraded Hi all. I am listing for sale Manley Neo Classic 250 power amplifier. These mono block in excellence condition, come with original box
If you are interested please inbox i will response as soon as i can.
PLEASE READ
By SssJedi
Item Condition: Mint Shipping Options: Pickup available but audition is not available. Suburb or Town: Tarneit State: VIC Payment Method: Paypal with fees, EFT Reason for selling: No longer needed DLS Ultimate Tube Amplifier TA2.
I have 2 amps - this is for 1.
Excellent condition.
ULTIMATE series TA2 is a HiFi two-channel amplifier with 2 x 100 Watts output power. This is an extremely well-sounding amplifier for car use. We did not compromize in any section of the construction when we designed the electronic circuits.
The TA2 is using the very best components in all sections of the amplifier, from the input circuitry, through the whole amplifier to the final output stage. Two pieces of CV4010 pentodes is used in the signal path. These tubes are made by VALVE Electronics in England during 1982 - 1984. The Valve Electronics company produced best sounding tubes in the tube industry before they closed. The tubes are spare parts for military equipment so they fulfil military specifications.
We use silver wire Capacitors in signal path and power supply for a focused sound image. Special designed DLS Audio capacitors in key points and WIMA polypropylene capacitors. Four pieces of 4700 uF on each channel for a deep and wide sound stage. Dual mono power system design plus separate power supply for tube and pre-amp stage for clear sound reproduction.
- RMS output per channel @ 13,8 volts, 20 Hz - 20 kHz ,
Separate level controls for each channel.
Specifications
Number of channels 2
Amplifier class AB
Output power in 2 ohm 2 x 200 W RMS
Output power in 4 ohm 2 x 100 W RMS
Damping factor >240
S/N ratio, A-weighted >102 dB
Frequency range 10 Hz - 50 kHz
Input sensitivity 0,5 - 7V
Input impedance > 10 kohm
High pass filter 20 - 200 Hz, 12 dB slope
Low level output No
Remote bass level control No
Remote phase shift control No
High level input with auto start No
Integrated fan No
Power consumption (idle) 1,5 A
Power consumption (max) 40 A
Rec. power cable Minimum 5AWG / 16 mm2 for each channel / kanal
Dimension (W x D x H) 410 x 240 x 73 mm (16,15 x 9,45 x 2,87 inch)
PLEASE READ
By SssJedi
Item Condition: Brand new Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Tarneit State: VIC Payment Method: Paypal with fees, EFT Reason for selling: No longer needed Box bit battered but component set completely new!!
Hybrid Audio Technologies Legatia L1 Pro R2 / L6SE - Two way 6.5" Car Audio Component Speaker Set.
http://hybrid-audio.com/speakers/legatia-se/
PLEASE READ
