RoHo 434 Posted January 22 Share Posted January 22 I have just replaced my old, original MiniDSP 2x4 crossover/processor with the newer 2x4 HD model. On of the main reasons is the new model has digital inputs, via Toslink optical or USB. My plan was to use the optical output on my elderly Rotel RCD991 CD player into the MiniDSP optical input. I've had the player since new, about 20 years, and never used the Toslink output. So I plugged it all in, started a CD playing and.....no input signal shown on the MiniDSP. I replaced the Rotel with my nearly as old Pioneer DVD player, which also has optical out, and it worked fine, so I figure the optical out on the Rotel is busted ☹️ I will open it and see if anything obvious is wrong but I'm not confident it's easily fixable. My Rotel does have a functional (last time I checked) S/PDIF co-ax output and a quick Google showed easily available, cheap converters that I could plug into the co-ax output on my CD player and convert it to optical to send to the MiniDSP. Is this likely to be a practical plug and play solution? Does the cheap price of these mean a crappy conversion? I could continue to use the Pioneer DVD player but it's operation as a CD player is really clunky and limited compared to the Rotel. And yes, I will probably end up using the MiniDSP's USB input from some sort of Raspberry Pi thingy but that's further down the track. Link to post Share on other sites
krebetman 304 Posted January 22 Share Posted January 22 before you get a converter, do you have a way to confirm whether the coaxial output on your Rotel is operating properly? Link to post Share on other sites
Kahuna 80 Posted January 22 Share Posted January 22 49 minutes ago, RoHo said: so I figure the optical out on the Rotel is busted ☹️ I will open it and see if anything obvious is wrong but I'm not confident it's easily fixable. This link mentions a switch on the back to enable digital output...............just sayin'. https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwiylNCa9q7uAhVQxTgGHVrdC3kQFjAAegQIAhAC&url=http%3A%2F%2Fwww.rotel.com%2Fsites%2Fdefault%2Ffiles%2Fproduct%2Fmanuals%2FRCD-991-OM.pdf&usg=AOvVaw0W2nCv4NB8OLnsLDtWm-dU Link to post Share on other sites
RoHo 434 Posted January 22 Author Share Posted January 22 1 hour ago, krebetman said: before you get a converter, do you have a way to confirm whether the coaxial output on your Rotel is operating properly? It has worked previously but, yes, I should confirm it is functional 51 minutes ago, Kahuna said: This link mentions a switch on the back to enable digital output...............just sayin'. https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwiylNCa9q7uAhVQxTgGHVrdC3kQFjAAegQIAhAC&url=http%3A%2F%2Fwww.rotel.com%2Fsites%2Fdefault%2Ffiles%2Fproduct%2Fmanuals%2FRCD-991-OM.pdf&usg=AOvVaw0W2nCv4NB8OLnsLDtWm-dU Yep, made sure it was on 1 Link to post Share on other sites
Gieseler Audio 2,476 Posted February 5 Share Posted February 5 It could just be the Toslink socket on the Rotel that needs to be replaced. That should be a minor repair for a tech & the Toslink sockets are very cheap. https://au.rs-online.com/web/p/fibre-optic-connectors/8051671/ Link to post Share on other sites
