FS: 3x Tannoy 12" Drivers + Crossovers Suit DIY Cheviot/Monitor Build - NEW
Item Condition: New
Shipping Options: Shipping is included in price.
Suburb or Town: Tasmania
State: TAS
Payment Method: PayPal, EFT, Cash
Reason for selling: NLR
I purchased these brand new with intentions to build cabinets like the Cheviot (but slightly larger volume of 79L) and use the others in a home theatre upgrade, but have since purchased some other speakers and no longer required. They cost over $1100 each to import and are brand new in box and come with complete crossovers. Ready to build cabinets and you have a fine set of Tannoys at a fraction of the cost of current retail models.
I have 3x drivers total I am willing to part with and the listed price is per speaker including shipping anywhere in AUS. If you are interested in all 3 in one lot I can discount a bit as shipping will be less, happy to sell a pair or single aswell.
Driver is a CMS1201DC installation speaker.
https://www.tannoy.com/product.html?modelCode=P0C1Y
Frequency Response (-3 dB) 60 Hz - 20 kHz
Frequency Range (-10 dB) 45 Hz - 30 kHz
System Sensitivity (1W @1m) 97 dB (1W = 2.83V for 8 Ohms)
Nominal Coverage Angle 90 Degrees Conical
Coverage Angle (1kHz to 6kHz) 90 Degrees Conical
Directivity Factor (Q) 8.9
Directivity Index (DI) 9.5
Rated Maximum SPL Average: 120 dB
Peak: 126 dB
With THP 60 - Average: 115 dB
Power Handling Average: 200W
Program: 400W
Peak: 800W
Recommended Amplifier Power 400W @ 8 ohms
Nominal Impedance 8 ohms
Transformer Taps 70V: 60W / 30W / 15W / 7.5W / OFF
100V: 60W / 30W / 15W / OFF
Crossover 1.6 kHz - 2nd order LF, 2nd order HF
Low Frequency 1 x 300 mm (12.00") Dual Concentric™ constant directivity driver with treated cone
High Frequency 34 mm (1.34") aluminium done with neodymium magnet system
Backcan 1.6 mm black powder coated steel, damped with 11 mm OSB board
Baffle 1.2 mm black powder coated steel
Grille 1.0 mm white powder coated perforated steel
Safety Features Safety ring located at rear of enclosure for load bearing safety bond
Cable Entry Options 20 mm and 28 mm on knockouts
Conduit Knockouts 4 sides + top
Connectors Terminal barrier strip inside the can, with loop thru capability
Dimensions (H x W x D) 13.03" (331 mm) x 28.54" (725 mm) 20.31" (516 mm)
Net Weight 17.4 lbs (7.6 kg)
Edited by 81Vintage
Price Drop
  • 81Vintage changed the title to FS: 3x Tannoy 12" Drivers + Crossovers Suit DIY Cheviot/Monitor Build - NEW
I also have plans for a compact ported cabinet that sits on short stand if you don't want floorstanders.
    • By Tobiwan
      Item Condition: Used - Near New 8 months Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Taylors lakes 3038 State: VIC Payment Method: Paypal, cash, EFT Reason for selling: Clearing music room Further information:
      Purchased April 2020 from Carlton AV, under warranty.
      Absolute beast of an amp.
      Please note the 851W is pictured with it's accompanying 861D DAC (both for sale)
      Here's the technical specs from the makers.
      CLASS XD
      Rather than use a Class A design, which is sonically brilliant but generates vast amounts of heat, or a Class AB design, which is efficient but sonically limited, we developed our own Class XD amplifier design which the 851W takes advantage of. This has the sonic purity of Class A and the efficiency of Class AB for the best of both worlds. For more information on our unique patented Class XD technology watch the video at the bottom of the page or click here for a full description.
      TERRAPIN BUFFERING
      When designing a stereo system, listeners are often encouraged to think about system matching, where components are handpicked to provide the best overall sound quality. People often assume this is due to the different audio characteristics, but frequently it is due to impedance (the relationship between voltage and current input/output) matching components. Products perform at their optimum when their input and output impedances match. This isn’t always possible though so we decided to develop our unique Terrapin impedance buffering module. This enables the 851W to be paired with a huge variety of audio sources and pre-amplifiers of varying impedance without risking any sacrifice in musicality or overall audio performance.
      POWER AND CONTROL
      To build the 851W to be the best toroidal transformers were essential. But rather than use one for everything we designated one for the sound amplification itself, and another for the input circuitry. This means the signal is unaffected by audio output volume, so always sounds fantastic. The primary toroidal transformer provides unrestricted power to the dual mono amplification blocks. It’s a true audiophile transformer that will operate without distortion and with no buzz, interference or hum. The second smaller toroidal transformer takes care of pre-amplification processes. View the videos below for an insight on why we use toroidal transformers.
      FLEXIBLE CONFIGURATION
      The 851W can be used in stereo, bi-amped or bridged mono configurations. In bridged mono mode into 8 Ohms the 851W is a 500W monoblock amplifier. Into 4 Ohms, this figure increases to an incredible 800W. It can be paired with our 851E pre-amp, any of our digital pre-amps such as the 851N or CXN, or any other analogue pre-amps, and thanks to our Terrapin buffering module it will always sound perfectly matched.
      CAP 5 PROTECTION
      Our proprietary CAP 5 protection system protects the 851W, plus any connected equipment and speakers, ensuring ultimate reliability and peace of mind. For more
      Specifications
      Power Output – Stereo/Mono:  200W per channel into 8 Ohms 350W per channel into 4 Ohms Power Output – Bridged Mono:  500W 8 Ohms 800W 4 Ohms THD (Unweighted):  < 0.001% 1 kHz < 0.005% 20 Hz – 20 kHz Frequency Response:  5Hz – 80kHz S/N Ratio (REF 1W / 8 OHN):  >90dB (unweighted) Sensitivity – Stereo or Mono:  1.5V rms unbalanced 1.5 + 1.5V rms balanced Sensitivity – Bridged Mono:  0.775V rms unbalanced 0.775V + 0.775V rms balanced Input Impedances:  Balanced input 38 kOhm Unbalanced input 68 kOhm Power AMP Damping Factor:  > 110 at 1 kHz Max. Power Consumption:  2400W Standby Power Consumption:  Standby <0.5W Dimensions:  Height 148mm (5.8″), Width 430mm (16.9″) and Depth 365mm (14.4″) Weight:  19.1kg (42.2lbs)
      PLEASE READ
    • By Tobiwan
      Item Condition: Used - Near New 8 months Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Taylors lakes 3038 State: VIC Payment Method: Paypal, cash, EFT Reason for selling: Upgraded speakers Further information:
      Purchased March 2020 from Rio Sound & Vision, Melb and still under warranty.
      If you don't know Canton you're welcome to test them out.
      Selling power and pre amp, also pictured.
      SPECIFICATIONS   Type Floorstanding speaker Engineering Principle 3-way bass reflex Nom. /Music power handling 120 / 200 watts SPL (1 watt/1m) 88 db Nominal Impedance 4...8 ohms Frequency response 23...40.000 Hz Crossover frequency 300 / 3.000 Hz Speaker Composition Woofer: 1 x 160 mm (6.3''), Titanium (Wave surround)
      Midrange: 1 x 180 mm (7''), Titanium (Wave surround)
      Tweeter: 1 x 25 mm (1''), Ceramic Special Features DC-technology
      Fabric grill with magnetic mount
      Gold plated bi-wiring/bi-amping screwclamp terminals Warranty 5 years Dimensions (WxHxD) 25 x 95 x 30 cm Weight 15 kg Carton Content Vento 876
      Equipment feet
      Equipment feet Spikes
      Manual
      PLEASE READ
    • By Tobiwan
      Item Condition: Used - Near New 8 months Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Taylors lakes 3038 State: VIC Payment Method: Paypal, cash, EFT Reason for selling: clearing out the music room Further information:
      Photo's include the 851W power amp (both are for sale)
      Digital inputs – Six digital inputs (including coaxial, Toslink optical, BNC coaxial and AES/EBU), plus asynchronous USB and optional Bluetooth wireless ensure that the widest possible range of digital sources are supported, with input source quality of up to 24-bit/192kHz.
      ATF2 audio up-sampling to 24-bit/384kHz Twin Analog Devices AD1955 24 bit DACs delivering superior sound-staging and stereo imaging Balanced XLR and unbalanced RCA analogue audio outputs Audiophile grade toroidal transformer delivering ultra-low low noise and distortion Selectable digital filters – linear phase, minimum phase, steep Full metal casework design with thick brushed aluminium front panel and dual layer damped feet, giving enhanced resonance control Eco-friendly <0.5W standby power consumption Azur Navigator remote control with Cambridge Audio 851 Series, Stream Magic Headphone output with high-end, low distortion amplifier Trigger out, control bus in/out for power syncing plus RS232 controllable
      DAC Dual Analog Devices AD1955 24-bit DACs Upsampling Analog Devices Black Fin ADSP-BF532 32-bit DSP performing 2nd
      Generation ATF2 up-sampling to 24-bit 384kHz
      Linear Phase, Minimum phase or Steep modes. Digital Inputs S/PDIF, Toslink optical, BNC, AES/EBU, BT100 Bluetooth USB Audio Input USB Type B conforming to Audio profile 1.0 or USB Audio profile
      2.0 (user 1.0 or USB Audio profile 2.0 (user selectable) Analogue audio outputs Balanced XLR and unbalanced RCA analogue audio outputs.
      1 ¼" / 6.35mm headphone output (supports 600 ohm headphones, however 300 ohms max recommended) Sample rates supported USB Audio1.0 16-24 bit, 32-96kHz
      USB Audio 2.0 16-24 bit, 32-192kHz
      Toslink 16-24 bit, 32-96kHz
      S/PDIF 16-24 bit, 32-192kHz
      BNC 16-24 bit, 32-192kHz
      AES/EBU 16-24 bit, 32-192kHz
      BT100 Bluetooth receiver: A2DP plus aptX Maximum power consumption 40W Dimensions (H x W x D) 115 x 430 x 360mm (4.5 x 16.9 x 14.7”) Weight 7.5kg (16.5lbs)
      PLEASE READ
    • By aba@rrg.com.au
      Item Condition: Excellent Shipping Options: Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Geelong 3216 State: VIC Payment Method: Paypal or cash on pickup Reason for selling: Now surplus to requirements Further information: The Venom PS8 is designed to be a high performance alternative to mass market power products with lack luster performance. The Venom Defender provides  noise reduction and transient protection to your system. The Venom Defender won the Abslute Sound's Editors award 2 years in a row. Price includes postage within Australia, if required. The unit has 7 input sockets, with an 8th accepting the Venom Defender. Inspection of unit and trial use is welcome. Ph Alan 0408296195
      PLEASE READ
    • By Prana69
      Item Condition: Excellent Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Mordialloc State: VIC Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: Rationalising Further information:
      I've owned this amp for a few years and it has always brought a smile to my face. It looks stunning and sounds amazing. Crazy amount of power on tap (110w into 8 ohms / 130 into 6).
      Side panels are custom made with high gloss Jarrah varnish - they really add to the presentation of this amp.
      There is a bit of pitting on the top of the amp, but a light sand and re-spray will make it look great. Minor marks on the faceplate include a small visible scratch to the top left of the Function Selector knob, and another scratch above and to the left of the Denon logo.
      It is a hefty 18kgs and includes coax and optical digital line inputs.
      MM and MC phono inputs.
      I've listened to this amp alongside the similar era and specced Sony TA-F700ES, and the Denon kills it for finesse, control and presentation.
      Pretty rare in Australia too. The original sale price in Japan was the equivalent of $1900 today.
      Happy to ship at your expense.
      Questions welcome.
      Audio Database entry
      DaveR
