PicoWattson 430 Posted January 19 Share Posted January 19 I'm currently using a Lyra Delos which has an internal impedance of 6.3 Ohms. I would like to try something even lower, say below 5 Ohms but in a similar price range to the Delos. I realise lower internal impedance usually equates to higher prices but I'm hoping someone may have experience with something of equivalent price. This will be fed into highly acclaimed current injection phono stage of which I'm keen to get optimum results from. Link to post Share on other sites
andyr 5,874 Posted January 19 Share Posted January 19 (edited) Howsabout this? FS: Murasakino Sumile Reference Moving Coil Cartridge - Classifieds - Commercial - StereoNET Coil impedance of 1.2 ohms! (I doubt you can get lower! ) Andy Edited January 19 by andyr Link to post Share on other sites
Wimbo 2,404 Posted January 19 Share Posted January 19 9 hours ago, PicoWattson said: I'm currently using a Lyra Delos which has an internal impedance of 6.3 Ohms. I would like to try something even lower, say below 5 Ohms but in a similar price range to the Delos. I realise lower internal impedance usually equates to higher prices but I'm hoping someone may have experience with something of equivalent price. This will be fed into highly acclaimed current injection phono stage of which I'm keen to get optimum results from. I think Delta 667 on Vinyl Engine can do this. Give him a Hoi. Link to post Share on other sites
denimhunter 249 Posted January 20 Share Posted January 20 6 hours ago, andyr said: Howsabout this? FS: Murasakino Sumile Reference Moving Coil Cartridge - Classifieds - Commercial - StereoNET Coil impedance of 1.2 ohms! (I doubt you can get lower! ) Andy My Sonic Lab series of cartridges! They range from 0.6 ohm to 1.8 ohm with output of 0.3 to 0.5mv. They also made the Murasakino Sumile and AirTight etc cartridges. . I am running one of their signature cartridges at present. Very agile, transparent yet balanced cartridge. 1 Link to post Share on other sites
PicoWattson 430 Posted January 20 Author Share Posted January 20 Thanks for those recommendations. The My Sonic Lab range will be investigated more thoroughly. Link to post Share on other sites
Martykt 2,711 Posted January 20 Share Posted January 20 23 hours ago, andyr said: Coil impedance of 1.2 ohms! (I doubt you can get lower! ) Yes I can confirm @denimhunteris completely correct. My Sonic Lab Ultra Eminent EX cart has a impedance of 0.6 ohms. Link to post Share on other sites
Martykt 2,711 Posted January 20 Share Posted January 20 8 hours ago, PicoWattson said: Thanks for those recommendations. The My Sonic Lab range will be investigated more thoroughly. I can definitely recommend the My Sonic Lab carts, they sound absolutely amazing. Though I should point out that price-wise they are a fair step up from the price of a Delos. If indeed that Sumile is made by Mr. Yoshio Matsudaira then that FS is very much a bargain if you can afford it. Link to post Share on other sites
andyr 5,874 Posted January 20 Share Posted January 20 10 hours ago, PicoWattson said: Thanks for those recommendations. The My Sonic Lab range will be investigated more thoroughly. You might well find that as that Sumile cart I referenced is going for 50% off ... it is cheaper than a 'My Sonic Lab' cart? Andy Link to post Share on other sites
