hififan 72 Posted January 16 Share Posted January 16 (edited) Item Condition: Used 9/10 Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Elanora Heights State: NSW Payment Method: Cash, Bank Transfer Reason for selling: Surplus Bought this from a fellow SNA'er Last year as an upgrade from my Musical Fidelity M6i... In brief it is superb, Huge power reserves and will drive a 2ohm load, beautifully refined and brings bag of detail and grip to the mix. A considerable step up from the MF IMHO Some links to reviews https://www.monoandstereo.com/2018/01/audio-analogue-puccini-anniversary.html https://www.whathifi.com/au/audio-analogue/puccini-anniversary/review https://daviddenyerpr.co.uk/2020/02/18/gloriously-open-sound-hi-fi-world-reviews-audio-analogues-puccini-anniversary-amplifier/ Beautifully built with a solid remote as Pictured Technical Description Heavy metal chassis, aluminum front panel with 14mm thickness, remote control. Volume control with an encoder that communicates with the four digital high precision Analog Devices potentiometers(two per channel). Volume with four possible curves selectable according to the sensitivity of the speakers. Indications of volume level and selected input, thanks white LEDs with brightness adjustable on two levels, or switched off. Inputs with high-quality gold-plated RCA connectors with Teflon insulation, soldered directly to the input's board and activated via signal relays. All stages of the amplifier on separate boards. Printed circuit boards have golden copper footprints with double thikness compared to standard PCBs in order to increase the electrical conductivity. Fully dual-mono circuitry. Transformer power 700VA, six pairs of ON-Semiconductor power transistors (three per channel). All internal wiring with pure solid 7N OCC copper conductors, military standard resistors, audiograde polypropylene capacitors, copper binding posts gold plated. Specs Channels 2 RCA inputs 4 XLR inputs 1 Input impedance 47KOhm Power on 8Ω load 80W @ 1% THD + N Power on 4Ω load 160W @ 1% THD + N Power on 2Ω load 300W @ 1% THD + N Sensitivity(8Ω output nominal power) 490mVRMS Frequency Response(Att. 0dB, -3dB band) 80KHz Output resistance(2Ω nominal power and 1kHz) 0.17Ω Input Noise(Band limits 0Hz-80kHz/A-weighted) =30µV/=10µV SNR =110 dB Standby power consumption(230VAC) 0.7W Dimensions(HxWxD) 120x445x390 mm Weight 15.5 Kg PLEASE READ If you include any reference to pricing whatsoever in this section (excluding RRP), your ad will not be approved If you are advertising multiple items, you must post one bulk price only, or post seperate ads for each item If you don't include photographs of the actual item being sold, your ad will not be approved You understand that a reasonable donation for selling fees is expected upon successful sale of your item Edited January 16 by hififan trying to fix images Link to post Share on other sites
hififan 72 Posted January 17 Author Share Posted January 17 Sorry about the inverted pics, have no idea how to fix it Link to post Share on other sites
JulesOz 131 Posted January 17 Share Posted January 17 My very first system was Audio Analogue with Dali Ikon and I loved it. Amazing Italian brand, GLWTS 😃 Link to post Share on other sites
hififan 72 Posted January 17 Author Share Posted January 17 21 minutes ago, JulesOz said: My very first system was Audio Analogue with Dali Ikon and I loved it. Amazing Italian brand, GLWTS 😃 Someone should buy this and your Epicons for a superb system 1 Link to post Share on other sites
Electrovoice Interface. 205 Posted January 17 Share Posted January 17 Stand on your head Worx 4 me😄 1 Link to post Share on other sites
