Maurice Colley 8 Posted January 14 Share Posted January 14 I'm just after some advice on buying active speakers. I don't have a big budget for buying speakers or sound bars and my own research has lead me to believe that Edifiers would be good value. However I've just read that they make a hissing noise. I've chosen the r2000DB because it will link up to my old telly ok and they are within my budget. I'm just a beginner when it comes to this sort of stuff. I'm just looking for something to boost the sound on the telly when I listen to music DVD's . Surely there's something I can do without spending mega bucks and not too complicated. Quote Link to post Share on other sites
Moderators proftournesol 8,460 Posted January 14 Moderators Share Posted January 14 Hi Maurice, welcome to SNA. I suggest asking your question again in the beginners forum 1 Quote Link to post Share on other sites
surprisetech 1,045 Posted January 14 Share Posted January 14 4 hours ago, Maurice Colley said: I'm just after some advice on buying active speakers. I don't have a big budget for buying speakers or sound bars and my own research has lead me to believe that Edifiers would be good value. However I've just read that they make a hissing noise. I've chosen the r2000DB because it will link up to my old telly ok and they are within my budget. I'm just a beginner when it comes to this sort of stuff. I'm just looking for something to boost the sound on the telly when I listen to music DVD's . Surely there's something I can do without spending mega bucks and not too complicated. Welcome Maurice. Active speakers from the Pro Audio suppliers can offer really good value. There are a few models on the linked webpage in the same price range as the Edifiers that might be worth looking into depending on what features you need. Since your main purpose will be listening to music DVDs, don't look at anything less than a 5" woofer and decent sized cabinets. https://www.storedj.com.au/studio-gear/studio-monitors/active-studio-monitors?SortProduct=PriceValue&PageProduct=1 1 Quote Link to post Share on other sites
Maurice Colley 8 Posted January 14 Author Share Posted January 14 Thank you very much "surprise tech" for the welcome and assistance. I neglected to mention that my TV is very limited with it's audio out features, I attached a picture, in that it only has an SPDIF connection. and no RCA output unfortunately. The Edifier r2000DB is one of the few speakers that has the required ODT connection. I've only learned all this terminology following all the enquiries I've made. To go to five inch speakers would increase the cost to a level which I can't afford. I wish I could because I understand your advice on the value of such speakers when it comes to listening to music DVDs. I'll try and contact the people at the website you gave me and put my case to them. Again I thank you for putting me on to such a great website and your generous assistance. Cheers. 1 Quote Link to post Share on other sites
sakabatou 278 Posted January 15 Share Posted January 15 If I may add 2 things: 1) there's no optical interface in that pic. If you want to use optical into the Edifier, you may need a spdif to toslink converter of some description 2) often digital outputs from TV will be unaffected by their volume control, which will mean using the Edifier's remote for volume. 1 Quote Link to post Share on other sites
Snoopy8 3,559 Posted January 15 Share Posted January 15 Suggest getting a used soundbar. You will have access to the Classifieds after a few more posts. Soundbars are easy to set up and connect, ideal for a beginner. You do not have worry about getting adaptors, converters and will handle all the different sound formats. And they will be a big improvement over your TV. 1 Quote Link to post Share on other sites
Maurice Colley 8 Posted January 15 Author Share Posted January 15 Thanks for your help Snoopy but speakers suit my TV surroundings and the connections available on it. I already have a set top box and video player connected, both using up my HDMI's. 1 Quote Link to post Share on other sites
Maurice Colley 8 Posted January 15 Author Share Posted January 15 Thank you sakabatou. I only just found out about the optical to analogue converters which I will look at. There's a much wider range of speakers that I want using RCA cabling? I'm still looking for advice from somebody who may have experience with Edifier speakers and their 5" base unit. I'm starting to think that I might be disappointed by the bass on any powered, active, monitor(?) speakers. 1 Quote Link to post Share on other sites
niss_man 623 Posted January 15 Share Posted January 15 I just purchased some Edifier R1700BT for my wife to use on the tv as an upgrade to the crap tv sound you get these days. They don't hiss. I use the analogue inputs though. Using bluetooth gives slightly worse sound quality. They are fantastic for $140. Had to turn the high frequency dial down to its lowest setting and the bass down slightly to get the sound I was after. 1 Quote Link to post Share on other sites
Maurice Colley 8 Posted January 15 Author Share Posted January 15 Thank you niss_man, that's what I wanted to hear. I'm thinking I'll spend a bitsy more money and get the r2ooo because the bass is supposed to be a bit better I read somewhere. I agree with you about the TV sound, it doesn't take a lot to beat that. Quote Link to post Share on other sites
Moderators proftournesol 8,460 Posted January 15 Moderators Share Posted January 15 I'd suggest that you also listen to some active ADAM speakers if they are within your budget, they'll shift your expectations of what is possible from a TV 1 Quote Link to post Share on other sites
Maurice Colley 8 Posted January 16 Author Share Posted January 16 I've decided to buy the Edifier r2000DBs and they're on their way. They're purpose built for what I want, the revues are pretty good and so is the price. Fingers crossed. Thanks for your input, I'll keep you posted. I know I'll be tearing my hair out in setting them up. That's what I do! 😬 1 Quote Link to post Share on other sites
petetherock 1,323 Posted January 17 Share Posted January 17 IMO the Klipsch RPM 41 powered speakers are pretty good.. Quote Link to post Share on other sites
surprisetech 1,045 Posted January 19 Share Posted January 19 On 16/01/2021 at 11:48 AM, Maurice Colley said: I've decided to buy the Edifier r2000DBs and they're on their way. They're purpose built for what I want, the revues are pretty good and so is the price. Fingers crossed. Thanks for your input, I'll keep you posted. I know I'll be tearing my hair out in setting them up. That's what I do! 😬 I'm sure you'll manage the setup now that you've done the research, but if any issues, you now know where to come for assistance! Happy listening. Down the track you might want to keep any eye on the Stereonet classifieds for a compact Subwoofer to take it to the next level. Quote Link to post Share on other sites
Maurice Colley 8 Posted January 29 Author Share Posted January 29 I received the speakers today and have already incurred a problem. The optical cable that Edifier supplied that plugs into the main speaker doesn't plug into the back of my TV. I attached a photo on the 15th of Jan showing the TV connections and I've attached photo today of the Optical cable plug. It's bigger and square rather than round. Could it be anything to do with age of the TV or is an adapter required? Any assistance would be great thanks. Quote Link to post Share on other sites
pete_mac 4,087 Posted January 29 Share Posted January 29 (edited) 21 minutes ago, Maurice Colley said: I received the speakers today and have already incurred a problem. The optical cable that Edifier supplied that plugs into the main speaker doesn't plug into the back of my TV. I attached a photo on the 15th of Jan showing the TV connections and I've attached photo today of the Optical cable plug. It's bigger and square rather than round. Could it be anything to do with age of the TV or is an adapter required? Any assistance would be great thanks. The incompatibility of your TV with an optical connection was noted by an earlier poster in this thread: On 15/01/2021 at 11:00 AM, sakabatou said: If I may add 2 things: 1) there's no optical interface in that pic. If you want to use optical into the Edifier, you may need a spdif to toslink converter of some description 2) often digital outputs from TV will be unaffected by their volume control, which will mean using the Edifier's remote for volume. You will need a device similar to this one, which is capable of converting coaxial digital to optical/toslink digital. https://www.amazon.com.au/Digital-Converter-Optical-Dolby-AC3-Amplifier/dp/B08B89D3T2/ref=sr_1_7?dchild=1&keywords=spdif+to+optical&qid=1611908228&sr=8-7 Alternatively... looking at the image of your TV, it would would be useful if we can confirm what the yellow 'AV OUT' connection is. I wonder if it is a 3.5mm analogue output, as this would enable the use of the supplied 3.5mm to RCA cable to connect your speakers. Can you advise the brand and model of your TV, as this would help to clarity the outputs (or if you have the user manual, please consult this and let us know). I'm sure we'll get to the bottom of this and get your speaker singing sweetly, one way or another! Edited January 29 by pete_mac 2 Quote Link to post Share on other sites
Maurice Colley 8 Posted January 29 Author Share Posted January 29 Thanks so much for your encouraging advice sakabatou. I've been feeling a bit down in the doldrums thinking I was stuck with an impossible situation. I thought that connecting my TV to the speakers via my SPDIF connection was the way to go on advice from Edifier who I also contacted prior to yourselves. I'm not familiar with a lot of the technical terms and it was my understanding that SPDIF was optical (?) and the cable supplied by Edifier to connect to the ODT input on the speakers could be used. My television is a TCL model L40D2700F. I have the manual and I've attached a copy of what I think is the relevant information. It doesn't make much sense to me I'm sorry. TCL TV manual (1).pdf Quote Link to post Share on other sites
sakabatou 278 Posted January 29 Share Posted January 29 8 minutes ago, Maurice Colley said: Thanks so much for your encouraging advice sakabatou. I've been feeling a bit down in the doldrums thinking I was stuck with an impossible situation. I thought that connecting my TV to the speakers via my SPDIF connection was the way to go on advice from Edifier who I also contacted prior to yourselves. I'm not familiar with a lot of the technical terms and it was my understanding that SPDIF was optical (?) and the cable supplied by Edifier to connect to the ODT input on the speakers could be used. I can't take credit for @pete_mac's encouragement His suggestion about checking the yellow socket is a good idea. If it is an anolog output, you will be able to use your TV's internal volume control instead of the Edifiers' Optical (also called toslink in this format) and Coax both use the spdif protocol, but optical uses light and coax uses voltage to transmit it. Converters are usually fairly cheap The manual is not that much help, as it is not model-specific, or maybe there was a revision Quote Link to post Share on other sites
pete_mac 4,087 Posted January 29 Share Posted January 29 4 minutes ago, sakabatou said: I can't take credit for @pete_mac's encouragement His suggestion about checking the yellow socket is a good idea. If it is an anolog output, you will be able to use your TV's internal volume control instead of the Edifiers' Optical (also called toslink in this format) and Coax both use the spdif protocol, but optical uses light and coax uses voltage to transmit it. Converters are usually fairly cheap The manual is not that much help, as it is not model-specific, or maybe there was a revision Thanks @sakabatou and yes, the info in the manual is not as clear as I would have liked due to not being model-specific. I get a sneaking suspicion that the yellow connection is indeed a 3.5mm "TRRS" connection which provides for both 2 channel audio and also video output - like this kind of cable: https://www.cablechick.com.au/cables/1m-avencore-crystal-series-4-pole-trrs-35mm-to-3rca-composite-av-cable.html?gclid=CjwKCAiAgc-ABhA7EiwAjev-jzew8rnM3VZ_gR3UrBd8LtyVsfw3BJRUMk9LfgV4PAzL3l9ad1UD-xoCIq8QAvD_BwE @Maurice Colley I'd suggest inspecting the yellow connection a bit more closely if possible. If it does appear to be your 'typical' 3.5mm headphone socket, connect the RCA inputs on the Edifiers to the TV with the suppled 3.5mm to RCA cable and see if you have any luck. 2 Quote Link to post Share on other sites
Maurice Colley 8 Posted January 30 Author Share Posted January 30 Thanks Pete, sorry about the mix up. I've checked and Edifier supplied two lots of RCA cable. One has 2x dual cables and the other is a 3.5 single (black) and a dual. They don't give much information in these manuals and I presume the black one takes the place of two? . I've attached a picture. I have plugged it into the yellow connection as you suggested on the TV and it seems to fit quite well, fingers crossed. You asked me to see if I have any luck? I guess that means I plug everything in, turn it on and see what happens? I presume? 😳😎 Quote Link to post Share on other sites
chaddy 49 Posted January 30 Share Posted January 30 (edited) 27 minutes ago, Maurice Colley said: Thanks Pete, sorry about the mix up. I've checked and Edifier supplied two lots of RCA cable. One has 2x dual cables and the other is a 3.5 single (black) and a dual. They don't give much information in these manuals and I presume the black one takes the place of two? . I've attached a picture. I have plugged it into the yellow connection as you suggested on the TV and it seems to fit quite well, fingers crossed. You asked me to see if I have any luck? I guess that means I plug everything in, turn it on and see what happens? I presume? 😳😎 That should do it. You may have to go into your TV settings to make sure the sound is going to AV Out or Headphone out. (other options would be TV Speakers or Digital Out). Edit: looking at the manual it looks like there is no setting. Might have to turn the TV volume down to minimum so you don't have both playing at same time Edited January 30 by chaddy 1 Quote Link to post Share on other sites
pete_mac 4,087 Posted January 30 Share Posted January 30 (edited) No worries Maurice! Yes, on the 3.5mm TRS connection, there's a left channel, right channel, and summed/joined ground connection which carries the same signal as the 2 x RCA connectors on the other end, but in a different form factor and connection type. There's more info on TRS and TRRS connections here: https://www.cablechick.com.au/blog/understanding-trrs-and-audio-jacks/ The challenge will be whether or not the connector on the TV matches the wiring of your cable, as there can be variations as noted above. I've had no luck uncovering any info on the configuration of TV's 3.5mm socket. If you have no luck and get no output, unplug the cable and we'll need to look at other options. 7 minutes ago, chaddy said: That should do it. You may have to go into your TV settings to make sure the sound is going to AV Out or Headphone out. (other options would be TV Speakers or Digital Out). Good point!! Edited January 30 by pete_mac 1 Quote Link to post Share on other sites
chaddy 49 Posted January 30 Share Posted January 30 I've set up a couple of my kid's TVs this way. 3.5mm TRS headphone sockets to RCAs on Active Speakers. Dead easy for them to use and if the Active speakers are Bluetooth enabled they can stream from their phones. Quote Link to post Share on other sites
Maurice Colley 8 Posted January 30 Author Share Posted January 30 (edited) Thanks guys but I'm still scratching my head about all this. I don't do too much of this sort of stuff, I'm a baby boomer, what can I stay. The way I look at I've got an AV out with a socket underneath on the back of the TV that we're not 100% sure will work (headphone socket?) and that's the only thing I have to transfer sound to the speaker. I can't test anything because I don't have anything on the TV to connect to the other RCA plugs on the back of the speaker? or do they all have to be connected to the TV ? Edited January 30 by Maurice Colley Quote Link to post Share on other sites
Maurice Colley 8 Posted January 30 Author Share Posted January 30 Do I just plug in the left and right for one of the speakers and see what happens Quote Link to post Share on other sites
Decky 1,316 Posted January 30 Share Posted January 30 (edited) Your only two options for taking the audio out of the TV are: SPDIF and AV out. AV out is usually a TRRS connector which carries composite video out together with L/R analogue audio. You might find a cable like that in Jaycar. A better option (maybe) would be to get a SPDIF to Toslink converter from Jaycar, which will allow you to use your speaker optical input. I can bet that a DAC in your speakers is way better than the one in your TV. https://www.jaycar.com.au/digital-audio-converter-repeater/p/AC1592?utm_campaign=redirect&utm_source=AC1592r&utm_medium=web Edited January 30 by Decky Quote Link to post Share on other sites
Maurice Colley 8 Posted January 30 Author Share Posted January 30 (edited) Thanks Decky. Going with the Toslink converter would be blowing out my budget a bit. It looks to me like I'd need extra cabling to get the signal out of the SPDIF socket as well? I can see the benefit of using that option though. Truthfully Decky I don't understand all this stuff. I don't even understand all the cabling that came with the speakers. I need an easier option and it looks like that's not going to be forthcoming. I might contact TCL, put my case to them and see what they have to say. I might even contact Edifier as well. You win some, you loose some! Edited January 30 by Maurice Colley spelling error Quote Link to post Share on other sites
Maurice Colley 8 Posted January 31 Author Share Posted January 31 (edited) I've just done a bit more of my own research and came across this "1M/2M For Toslink to Mini Plug Jack 3.5mm Digital Optical SPDIF Audio Cable Cord" on Ebay. It looks like it would plug into my TV and the other end looks just like the ODT cable that supplied with the speakers? One of the problems is that the ODT connection on the speakers might not be exactly the same. Looks pretty close though. Worth a chance for $10 bucks? Any comments please? Edited January 31 by Maurice Colley extra comment Quote Link to post Share on other sites
sakabatou 278 Posted January 31 Share Posted January 31 6 minutes ago, Maurice Colley said: It looks like it would plug into my TV and the other end looks just like the ODT cable that supplied with the speakers? One of the problems is that the ODT connection on the speakers might not be exactly the same. Looks pretty close though. Worth a chance for $10 bucks? Don’t waste your time/money. that cable requires “mini-Toslink” which is the same size as 3.5mm analog, but is still optical. I’ve never seen nor heard of that connector on a non-portable device. If a TV has optical, it will have the full size almost square socket that you see on your speakers 1 Quote Link to post Share on other sites
pete_mac 4,087 Posted January 31 Share Posted January 31 17 hours ago, Maurice Colley said: Thanks guys but I'm still scratching my head about all this. I don't do too much of this sort of stuff, I'm a baby boomer, what can I stay. The way I look at I've got an AV out with a socket underneath on the back of the TV that we're not 100% sure will work (headphone socket?) and that's the only thing I have to transfer sound to the speaker. I can't test anything because I don't have anything on the TV to connect to the other RCA plugs on the back of the speaker? or do they all have to be connected to the TV ? Maurice, you have everything on-hand. To test the 3.5mm to 2 x RCA plug cable that was supplied with your speakers, you need to connect the RCA plugs to either the Line In 1 or Line in 2 inputs on the Edifier speakers. 6 minutes ago, Maurice Colley said: I've just done a bit more of my own research and came across this "1M/2M For Toslink to Mini Plug Jack 3.5mm Digital Optical SPDIF Audio Cable Cord" on Ebay. It looks like it would plug into my TV and the other end looks just like the ODT cable that supplied with the speakers? One of the problems is that the ODT connection on the speakers might not be exactly the same. Looks pretty close though. Worth a chance for $10 bucks? Any comments please? Some devices feature a multi-function 3.5mm output with both analogue and optical digital outputs. Your TV does not feature this. This cable will not work. Quote Link to post Share on other sites
chaddy 49 Posted January 31 Share Posted January 31 If the supplied cable which is audio only doesn't work you may need one of these: https://www.jaycar.com.au/3-x-rca-plugs-to-4-pin-3-5mm-av-cable-1-5m/p/WV7345 in which case you would leave the video plug (yellow RCA) unconnected Quote Link to post Share on other sites
Maurice Colley 8 Posted January 31 Author Share Posted January 31 20 minutes ago, pete_mac said: Maurice, you have everything on-hand. To test the 3.5mm to 2 x RCA plug cable that was supplied with your speakers, you need to connect the RCA plugs to either the Line In 1 or Line in 2 inputs on the Edifier speakers. Some devices feature a multi-function 3.5mm output with both analogue and optical digital outputs. Your TV does not feature this. This cable will not work. Thanks Pete for some more clarification and I'd like a bit more if that's ok. So when I do as you suggest and use the 3.5mm to 2xRCA plug cable and it works I won't need the other set of RCA plugs? That's what was confusing me 9it doesn't take much). I don't need to use both Line 1 and 2 ?. Can't do it right now, the wife's sleeping in the next room. I'll get back to you. 😊 I even get confused about finding replies. I didn't see them all until a couple of hours ago sorry. Did I mention that you're dealing with a grumpy 71 year old? Quote Link to post Share on other sites
pete_mac 4,087 Posted January 31 Share Posted January 31 18 minutes ago, Maurice Colley said: Thanks Pete for some more clarification and I'd like a bit more if that's ok. So when I do as you suggest and use the 3.5mm to 2xRCA plug cable and it works I won't need the other set of RCA plugs? That's what was confusing me 9it doesn't take much). I don't need to use both Line 1 and 2 ?. Can't do it right now, the wife's sleeping in the next room. I'll get back to you. 😊 I even get confused about finding replies. I didn't see them all until a couple of hours ago sorry. Did I mention that you're dealing with a grumpy 71 year old? No problem at all Maurice - we are here to help! No need to apologise. Your speakers have four possible input options - two sets of 'line level' RCA inputs (Line In 1 and Line in 2), an optical digital connection, and a wireless bluetooth connection. You only need to use one of these inputs for you TV, and you select the input via the supplied remote control (line 1, line 2, OPT or bluetooth): Later on, you also have the option of connecting other audio sources to the speakers if you want, and you can switch between them via the remote control. For example, a CD player, radio tuner, phone or the like. 1 Quote Link to post Share on other sites
Maurice Colley 8 Posted January 31 Author Share Posted January 31 13 minutes ago, pete_mac said: No problem at all Maurice - we are here to help! No need to apologise. Your speakers have four possible input options - two sets of 'line level' RCA inputs (Line In 1 and Line in 2), an optical digital connection, and a wireless bluetooth connection. You only need to use one of these inputs for you TV, and you select the input via the supplied remote control (line 1, line 2, OPT or bluetooth): Later on, you also have the option of connecting other audio sources to the speakers if you want, and you can switch between them via the remote control. For example, a CD player, radio tuner, phone or the like. Just to let you know IT WORKED!! I've got a music DVD on right now and it's magic! Can't thank you guys enough! I know who to come to if there's a next time. 4 Quote Link to post Share on other sites
pete_mac 4,087 Posted January 31 Share Posted January 31 47 minutes ago, Maurice Colley said: Just to let you know IT WORKED!! I've got a music DVD on right now and it's magic! Can't thank you guys enough! I know who to come to if there's a next time. Yes yes yes!!! Enjoy the fruits of your labour and persistence. 1 Quote Link to post Share on other sites
