JOH1975 165 Posted January 13 Share Posted January 13 (edited) This is a bit long winded I’m sorry. TT = project RPM 5 Carbon My TT is playing left channel high and I’ve tried everything I can think of including a change of cartridge with no improvement. I’ve tried 2 different amps and 2 Different phono pre amps. Also tried several different RCA cables. I’ve switched the left and right wires on the cartridge and that simply reversed the problem and played right channel high. This happened on both cartridges. Also switching left and right RCAs also just reverses the issue. I have also tried the anti skate in every position. I even cleaned the contacts where the wires connect into the cartridge. As a last resort I’ve pulled the cover off the connections where the RCA cables go into the TT and the white wire (left) was squished by the screw down cover. The left isn't the problem though. I thought I could see a small imperfection in the red wire (right) but now i can’t see that. In this process I have found that the left channel is full of sparkle and detail where the right channel is dull like a blanket has been thrown over the speaker. So maybe it’s not softer it’s just not playing back with any detail. There is no issue with digital playback so it’s not the speaker. I’ve got an old pioneer TT that plays fine and balanced (but sounds pretty rubbish) I’m at a total loss to what is happening and at my wits end trying to find the problem. Any advice? The store I bought it from (Challenge HiFi) are 500 Kms away so taking it to them isn’t really an option. arrrgh. Help 😩 Edited January 13 by JOH1975 Link to post Share on other sites
Telecine 4,048 Posted January 13 Share Posted January 13 If you are lucky, it might need the cartridge tags re-soldered or replaced. If you are unlucky, you might need to have the arm rewired. 5 Link to post Share on other sites
JOH1975 165 Posted January 13 Author Share Posted January 13 (edited) By cartridge tags do you mean the pins on the cartridge or the sockets on the wires in the tone arm? Rewiring the tone arm doesn’t sound like fun. Probably not something to attempt myself I shouldn’t think? Edited January 13 by JOH1975 Link to post Share on other sites
JOH1975 165 Posted January 13 Author Share Posted January 13 What about something like this? https://www.ebay.com.au/itm/283502639474 Link to post Share on other sites
xlr8or 1,101 Posted January 13 Share Posted January 13 You may need get yourself a new tonearm. What's fitted on there at the moment? Is it the 9cc Evolution tonearm? Link to post Share on other sites
Telecine 4,048 Posted January 13 Share Posted January 13 7 hours ago, JOH1975 said: By cartridge tags do you mean the pins on the cartridge or the sockets on the wires in the tone arm? Rewiring the tone arm doesn’t sound like fun. Probably not something to attempt myself I shouldn’t think? The later: 2 Link to post Share on other sites
Telecine 4,048 Posted January 13 Share Posted January 13 7 hours ago, JOH1975 said: What about something like this? https://www.ebay.com.au/itm/283502639474 It is most likely to be the cartridge tags. Rewiring an arm is a significant endeavour, not to be undertaken lightly. If you can perform a continuity test on the wiring, it should give you the answer. 1 Link to post Share on other sites
audiofeline 2,588 Posted January 13 Share Posted January 13 I would think the tonearm rewire would be a worst-case scenario. The problem is more likely to be in the wire connections, soldering, plugs, headshell connection, etc. A lot of problem-solving to do, but I'm confident that the cause can be identified. Link to post Share on other sites
JOH1975 165 Posted January 13 Author Share Posted January 13 9 hours ago, xlr8or said: You may need get yourself a new tonearm. What's fitted on there at the moment? Is it the 9cc Evolution tonearm? It is the 9cc evolution tone arm. How can the arm have an effect on balance or detail from channel to channel - the wires just run down the middle of it don't they? Or am i missing something? Regards Jarrod Link to post Share on other sites
xlr8or 1,101 Posted January 13 Share Posted January 13 (edited) As @Telecine has eluded to the problem appears to be with the wiring at the cart end, internal wiring housed inside the tonearm/base assembly or the RCA end. I agree that you should test for continuity with a DVM at the cartridge end to determine if the cartridge tags are loose. You can also measure resistance. From there you can work back to determine where the problem is. I suspect this may have occurred through negligence of the seller or manufacturer fitting a new cart. They may have jerked the leads and loosened the tag connection. It sounds as if there is a single strand or 2 connected that is giving the inconsistency in channel output. The problem probably sounds worse as the cart coils warm up and the tag ends heat up and expand. Edited January 13 by xlr8or Link to post Share on other sites
JOH1975 165 Posted January 13 Author Share Posted January 13 3 minutes ago, xlr8or said: As @Telecine has eluded to the problem appears to be with the wiring at the cart end, internal wiring housed inside the tonearm/base assembly or the RCA end. I agree that you should test for continuity with a DVM at the cartridge end to determine if the cartridge tags are loose. You can also measure resistance. From there you can work back to determine where the problem is. I suspect this may have occurred through negligence of the seller or manufacturer fitting a new cart. They may have jerked the leads and loosened the tag connection. It sounds as if there is a single strand or 2 connected that is giving the inconsistency in channel output. The problem probably does not sound as obvious with warm up time. Ok. Now i'm gonna sound like a real dummy - DVM? I'm not sure i'll be able to solder such small wires. Link to post Share on other sites
Telecine 4,048 Posted January 13 Share Posted January 13 15 minutes ago, JOH1975 said: Ok. Now i'm gonna sound like a real dummy - DVM? I'm not sure i'll be able to solder such small wires. Digital Voltage Meter. Any competent turntable specialist will be able to effect the repair for little cost. Link to post Share on other sites
JOH1975 165 Posted January 13 Author Share Posted January 13 6 minutes ago, Telecine said: Digital Voltage Meter. Any competent turntable specialist will be able to effect the repair for little cost. Thanks - I'll go get a DVM (i'm all over the lingo ) No one here that is that competent except for @tagstrip who wasn't overly keen to work on a turntable. Maybe i'll be able to convince him to help with some soldering??? I wonder if just as a bit of a test just a bit of wiggling and clamping of the wire could help with the connection. DVM first though... oh and lean how to use and read it.... 1 Link to post Share on other sites
JOH1975 165 Posted January 13 Author Share Posted January 13 (edited) would either of these be suitable? https://www.supercheapauto.com.au/p/sca-sca-multimeter---digital-12v-automotive/4405.html?gclid=Cj0KCQiA0fr_BRDaARIsAABw4Esed9Lrpze1RmOoN8Rv8a7MqibBxi8U2d-JVfZOB2i3ZSGCPhjlYWcaAp36EALw_wcB&gclsrc=aw.ds https://www.bunnings.com.au/sidchrome-minimeter-multimeter_p0196362?gclid=Cj0KCQiA0fr_BRDaARIsAABw4Es_yDPIPk0_F1h8cHzmjXQJcEBlISm6vhz1wi-qXCfmOboA7vI6jCsaAmAnEALw_wcB&gclsrc=aw.ds Edited January 13 by JOH1975 Link to post Share on other sites
audiofeline 2,588 Posted January 14 Share Posted January 14 Both will be OK, you will use the ohm/resistance scale. The Supercheap looks similar to the Jaycar, and the Jaycar is half the cost, I have one and it's been OK for my basic use. https://www.jaycar.com.au/low-cost-digital-multimeter-dmm/p/QM1500 Anvil Electronics, 42 Margaret St, Mount Gambier, is a Jaycar reseller, phone them to see if they have them in stock Ph. 08 8725 3366 1 Link to post Share on other sites
JOH1975 165 Posted January 14 Author Share Posted January 14 14 minutes ago, audiofeline said: Both will be OK, you will use the ohm/resistance scale. The Supercheap looks similar to the Jaycar, and the Jaycar is half the cost, I have one and it's been OK for my basic use. https://www.jaycar.com.au/low-cost-digital-multimeter-dmm/p/QM1500 Anvil Electronics, 42 Margaret St, Mount Gambier, is a Jaycar reseller, phone them to see if they have them in stock Ph. 08 8725 3366 I bought a cheap one from bunnies. now to work out what I’m trying to read. That’s tonight’s job. Link to post Share on other sites
Mr Thorens 513 Posted January 14 Share Posted January 14 That will do the job. You are measuring resistance in ohms from end of the lead to the cartridge clips. Should all be zero. Link to post Share on other sites
audiofeline 2,588 Posted January 14 Share Posted January 14 Plug the leads into the meter. Set it to the ohm scale - Ω , it measures resistance. There are different scales of resistance, set it to a lower one. Put the two probes together, the resistance should be 0, this shows that there is continuity in the circuit (ie, there are no breaks in the cables). So if you put one probe on a headshell wire and the other probe on a RCA contact, you should be able to measure continuity. The standard headshell colours are (but sometimes these are not followed) - White: Left channel cartridge positive. Blue: Left channel cartridge negative. Red: Right channel cartridge positive. Green: Right channel cartridge negative. 1 Link to post Share on other sites
JOH1975 165 Posted January 14 Author Share Posted January 14 Wow. You’ve all been so helpful. I’ll report back 😬 fingers crossed I find the problem. 1 Link to post Share on other sites
JOH1975 165 Posted January 14 Author Share Posted January 14 (edited) Ok so when I test the white cable with the multimeter set to 20k ohms I get a reading of 1.16 and when I test the red I get a reading the same 1.160 im putting the probes from the multimeter on the connector at the stylus (still attached to the stylus) and on the outside rim of the rca socket at the other end. Edited January 14 by JOH1975 Link to post Share on other sites
JOH1975 165 Posted January 14 Author Share Posted January 14 (edited) If I remove the wires from the stylus then I cant get them to stay connected to that MM probe. But I think that’s what I need to do somehow. Edited January 14 by JOH1975 Link to post Share on other sites
JOH1975 165 Posted January 14 Author Share Posted January 14 (edited) Forget all of that. I can’t get a steady reading from anything. i really have no clue!!! just gonna get rid of the bloody thing. Chuck it in the bin. I don’t have the patience for **** that doesn’t work. totally infuriating. Edited January 14 by JOH1975 Link to post Share on other sites
JOH1975 165 Posted January 14 Author Share Posted January 14 There really isn’t much to it. I can see how it can go wrong. I did manage to get all wires to read zero on the MM. I assume this is the correct setting on the multi meter. Link to post Share on other sites
Mr Thorens 513 Posted January 14 Share Posted January 14 Select 200 ohms in the multimeter. Furtherest green number on the left. then measure red cartridge wire to inner red RCA. green red cartridge wire to outer red rca white cartridge wire to inner white rca blue cartridge wire to outer white rca. all should be around zero Link to post Share on other sites
JOH1975 165 Posted January 14 Author Share Posted January 14 thank you foe your input. Do I do this while they are still connected to the cartridge? Link to post Share on other sites
Mr Thorens 513 Posted January 14 Share Posted January 14 Yes you can Link to post Share on other sites
JOH1975 165 Posted January 14 Author Share Posted January 14 Oh man you’ve been a big help the green wire jumps around a bit but is between 12 and 15. all others just over 1 Link to post Share on other sites
Mr Thorens 513 Posted January 14 Share Posted January 14 And is the problem the Right channel? Link to post Share on other sites
JOH1975 165 Posted January 14 Author Share Posted January 14 Yes it is. So I’ve thinking it’s left channel hugh but in fact it’s right channel low. Link to post Share on other sites
Mr Thorens 513 Posted January 14 Share Posted January 14 Now can you measure it from green cartridge wire at the cartridge end to the part that is soldered on the inside of the RCA? This may help tell you if the problem is inside the arm wiring or the solder joint to the RCA. Link to post Share on other sites
JOH1975 165 Posted January 14 Author Share Posted January 14 The reading jump all over the place and the tiniest movement either cancels the reading or makes it skyrocket. I can’t seem to get a steady answer. cheap multimeter? Or unsteady hands? Link to post Share on other sites
audiofeline 2,588 Posted January 14 Share Posted January 14 The probes need to be held firmly to the metal. Link to post Share on other sites
JOH1975 165 Posted January 14 Author Share Posted January 14 (edited) Hard to do with everything so light and small. If I hold it on the dob of solder then I get a reading in the 30’s And if I do it on the RCA again I get 30’s as well. (I put some of that rubbery kitchen draw liner under it so it stopped sliding around. That helped a lot) Edited January 14 by JOH1975 Link to post Share on other sites
audiofeline 2,588 Posted January 14 Share Posted January 14 Do you have a soldering iron? Try melting the solder on the green rca, and measure again when it's cool. Link to post Share on other sites
JOH1975 165 Posted January 14 Author Share Posted January 14 I do have a soldering iron somewhere. Looks like this is going to be a tomorrow job. Link to post Share on other sites
Mr Thorens 513 Posted January 14 Share Posted January 14 Potential dry solder joint by the looks of it. Heat the joint with a soldering iron and it might self heal. Link to post Share on other sites
JOH1975 165 Posted January 14 Author Share Posted January 14 That would be an easy fix. 🤞 thanks for your help so far. You’ve all been so generous and kind. 2 Link to post Share on other sites
JOH1975 165 Posted January 16 Author Share Posted January 16 Ok I’m hopeless. I’ve made it worse. Now there is no sound from the right channel. I give up. Link to post Share on other sites
audiofeline 2,588 Posted January 16 Share Posted January 16 Please don't call yourself hopeless, you're learning. Mistakes are part of becoming competent. So back to the turntable. What did you do to the right channel? The suggestion was to heat the solder joint on the RCA, and let it cool (with the wire still in position). Is this what you did? Check that you haven't accidentally created a short circuit between the + and -, this can be done with a continuity check (multimeter) from the centre RCA pin to the RCA earth. If you do have a short, un-solder the R -ve wire, and re-soder. Try doing the same with the +ve. It's fiddly and time-consuming, but that's all part of the fun. 1 Link to post Share on other sites
JOH1975 165 Posted January 16 Author Share Posted January 16 You’re very kind but I am useless at this stuff. i melted the solder and the wire stayed in place on the green. Looking at it there is no short but I can’t get any consistent ready on the multi meter. Then I accidentally broke the red wire so had to re connect that. Again pretty sure there is no short but again can’t get a stable reading using the multi meter. im sorry I don’t know what -ve and +ve is? Link to post Share on other sites
