Item Condition: Fair
Shipping Options: Pickup available and you can audition.
Suburb or Town: Perth (SOR)
State: WA
Payment Method: Cash
Reason for selling: No room and not using them
Further information:
These speakers are able to be bi-wired. I believe they're rated at 100 watts.
I've listed them as being in fair condition as there are a couple of small dents and scratches (please see the photos).
Edited by bassowl
  • bassowl changed the title to FS: Whatmough C21 Pair (Price Drop)
    • By Biao
      Item Condition: as new Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Keysborough State: VIC Payment Method: Paypal, EFT, Cash on pickup Reason for selling: NLR Further information:
       10 months old.
      Very few hours.
      https://www.melbournehifi.com.au/products/rotel-ra-1572?gclid=CjwKCAjwgZuDBhBTEiwAXNofROMlJscBCX00MH7JOjc0qvB-g6yTA9KnrrpEDr8e5z1yal4uMUsBmRoCHwQQAvD_BwE
      PLEASE READ
    • By Josipg
      Item Condition: Excellent Shipping Options: Shipping is included in price. Suburb or Town: Adelaide State: SA Payment Method: paypal as friend, or standard paypal +3% Reason for selling: NLR Further information: recently purchased to compare suitability.
      sound is very detailed, open soundstage and drivers a low noise SUT solution. Best results were with a good quality coaxial interconnect with ground shield.
       The MCL uses transformers supplied by Lundahl of Sweden and is a superb step-up transformer designed specifically for modern low output moving coil cartridges and optimised for use into moving magnet phonostage inputs.
      It features very wide bandwidth, low distortion and carefully designed primary and secondary loading networks to optimise the performance and give beautifully reproduced transients, free from ringing.
      The core materials and winding techniques employed in the manufacture are unsurpassed and feature multiple primary and secondary windings configured to cancel hum pickup from external sources as well as minimise inter-winding capacitance and maximise bandwidth.
      The step-up ratio makes it compatible with a wide range of cartridges and our proprietary loading networks maintain  a 100 ohm input impedance, also compatible with a wide range of cartridges.
      Specification can be found at the following link:
      mc step-up transformer (rothwellaudioproducts.co.uk)
      turns ratio - 1:20
      voltage gain - 26dB (x20)
      core material - cobalt based uncut amorphous strip
      input impedance* - 100 ohms
      optimum load impedance** - 47k + 150pF
      bandwidth - 8Hz - 75kHz (+0/-3dB)
      cartridge compatibility (o/p) - 0.2mV - 0.7mV
      cartridge compatibility (imp.) - internal impedance <20 ohms
      dimensions - 60 x 155 x 92 mm
      weight - 580g
      *This is the load presented to the cartridge.
      **This is the optimum load for the transformer, ie the input impedance of the phonostage that the MCL feeds into.
      PLEASE READ
    • By Biao
      Item Condition: brand new Shipping Options: Shipping is included in price. Suburb or Town: Keysborough State: VIC Payment Method: Paypal, EFT, Cash on pickup Reason for selling: NLR Further information:
      PLEASE READ
    • By AJL999
      Item Condition: Excellent Shipping Options: Pickup available but audition is not available. Suburb or Town: 2257 - Central Coast State: NSW Payment Method: PayPal, EFT Reason for selling: House Reorg. Further information:
      These are truly unique – a commercial-grade prototype pair of Tikandi Grands from Australian company, Legend Acoustic.     The Tikandi Grand Be is currently LA’s flagship speaker.   Included in the sale is a DEQX  Express II calibration / ADC / DAC / pre-amp.  You will need the DEQX to run the Tikandis because of the way the Tikandis are structured.
      The Tikandis consist of a lower subwoofer module containing 2 x 12” drivers and a 500W BASH amp.   Mounted on top is a sealed 3-way unit containing a tweeter, midrange and upper bass – pretty much the same as the current LA ‘Isobaric Small Red’.  The tweeter and mid are connected.  To drive these you will need 4 channels of amplification.
      Basically the DEQX is set up to do time alignment and then room calibration (more later).  It then applies the calibration to an incoming digital signal (or analogue signal that’s been digitized by the DEQX), and then splits the stream into high / medium / low digital streams, and converts back to analogue.    The Low frequency analogue signal than goes straight to the Tikandi and uses their built-in plate amps.  The analogue high & mid signals are fed to discrete channels in a separate amp, and then to the high / mid inputs on the back of the Tikandi.  Note the DEQX also supports balanced connections.
      This system truly is world class, and all you need to add it a digital (or analogue) source and a BIG, high quality, multi-channel amp.  To buy this kit new would be between RRP 18K and 19K!   I am only selling it because I am about to reorg my house, and will have no location big enough to house such a system.
      What will YOU need to consider:
      Calibration: It is tricky, as it will need to be redone with the speakers in-situ.     I had the installer do mine – it needs to be done with a specific mike, a PC, etc.  However, I understand the guys at DEQX can provide this as a service, even doing it remotely.   If I were you I’d budget a couple of hundred extra for this.  (You can get the software from DEQX and do it yourself, but its complex.)
      Disclaimer:   The midrange driver on one of the Tikandis has somehow discolored.   I checked with Rod Crawford, and this happened to some of these drivers.  It has NO effect on the sound, and they seem to work perfectly.    That said, Rod has spares, so talk to me if this is an issue for you.
      Transport:    These are WAY too big and heavy to freight.   That said, as the total cost is high enough that I can (within reason) load them into my wagon and deliver them to your door, for a fee.     NSW / ACT is doable, and maybe as far as Brisbane or Melbourne.  Again…..talk to me if you are interested.
      Missing Amp:  A big, high quality, 4-channel (or more) amp WILL be needed.
      I am away till 09 April...so please be patient if you msg me.
      For reference:
      http://www.legendspeakers.com.au/products-tikandi-grande/
      https://www.deqx.com/products/hdp-express-ii/
      PLEASE READ
    • By ray4410
      Item Condition: new Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: mount martha State: VIC Payment Method: EFT,CASH ON PICKUP Reason for selling: have enough Further information:FULLY SHIELDED POWER CABLE Extra Info: fully shielded cable for hifi+av systems,braided cable made in Germany,eliminates rfi+emi from entering system also prevents contamination to nearby interconnects,very flexible, 1.5mtrs in length other lengths available, cable rated 18amp current rating 450volts rating od 10.3mm tinned copper braid more than one available ,.
      PLEASE READ
