super kermit 12 Posted December 12, 2020 Share Posted December 12, 2020 100% movies only 1 bedroom apartment/unit Concrete walls and floors HTPC nvidia shield Want a separate subwoofer and rear speakers still Thinking 2019 Samsung HW-Q90R Samsung HW-Q90R Review The Samsung HW-Q90R is a great soundbar that's versatile for a wide variety of uses and it's one of our best performing soundbars so far. It has a great overall ... www.rtings.com OR 2020 Samsung HW-Q950T Samsung HW-Q950T Review The Samsung HW-Q950T is a 9.1.4 setup from 2020. It has a neutral and balanced sound profile that delivers a thumpy, punchy bass suitable for a variety of audio ... www.rtings.com Link to post Share on other sites
ThirdDrawerDown 4,415 Posted December 12, 2020 Share Posted December 12, 2020 Acoustically you are ahead with concrete walls, as compared to plaster and framing timber. Crisper. Subwoofers will cause the others in your apartment building to want to kill the power to your apartment. Is your ambition to feel the bass by way of movement of drivers pushing air, or by way of drivers vibrating the floor and building structure? Link to post Share on other sites
super kermit 12 Posted December 16, 2020 Author Share Posted December 16, 2020 I will have to turn the sub all the way down Link to post Share on other sites
Chill3 738 Posted December 16, 2020 Share Posted December 16, 2020 The Samsung is good for movies, that what I currently use movies only - both the models above are similar go for the best deal Link to post Share on other sites
tamarasue 17 Posted December 30, 2020 Share Posted December 30, 2020 Let us know how you go. Link to post Share on other sites
super kermit 12 Posted January 2 Author Share Posted January 2 Hi all Went back to a Samsung Q90R Link to post Share on other sites
