SOLD: FS: Uptone Audio Ultracap LPS-1 - Linear power supply (3.3V, 5V, or 7V) -- SOLD PP
Item Condition: Great
Suburb or Town: Fitzroy North
State: VIC
Payment Method: EFT to PayID, Cash on Pickup.
Reason for selling: NLR
Further information:
Perfect visual and working condition, this will improve the quality of power going into any device.  Comes with original box, powerbrick and AU power cable as pictured.
Uptone Audio LPS-1
UltraCap™ LPS-1
The world's first bank-switching, microprocessor-controller, ultracapacitor-based, ultra-low-noise external linear power supply has arrived!
In development for more than a year, and with 262 parts on the double-sided, 4-layer circuit board, this tour de force of engineering challenges traditional notions about what is important in power supply design.
Use of the UltraCap™ LPS-1 in a quality music reproduction system will yield surprisingly audible improvements, and we invite comparisons to any other low voltage linear power supply.
The LPS-1 is a single output, 1-amp linear power supply intended for powering a wide range of audio and computer devices.  Examples include: UpTone's own USB REGEN, the Sonore MicroRendu, small DACs and headphone amps, USB>S/PDIF converters, specialty computer USB cards, SSDs, fibre media converters, PS Audio LANRover, SqueezeBox Touch, etc.
A switch on the back of the LPS-1 allows for setting of the output voltage to 3.3V, 5V, or 7 volts. The input and output jacks of the LPS-1 are standard 5.5mm x 2.1mm size DC barrel connectors.
The dimensions of the LPS-1 are: 110mm (4.33 inches) wide x 112mm (4.41 inches) deep x 30mm  (1.18 inches) tall; Add 6.5mm (0.26 inches) for included rubber feet.
Included with the LPS-1:
A 70cm, 16awg, DC cable with 5.5mm x 2.1mm plugs at both ends (correct for a REGEN, MicroRendu, and many other popular devices that use that size).
A Mean Well SMPS world-voltage-compatible tabletop SMPS for "energizing" the UltraCap™ LPS-1, along with a 45cm AC power cable (standard IEC plug one end, USA wall plug at the other—international buyers can cut and put a local plug on or just use any standard power cord).
An LED at the back of the LPS-1 changes color (red/amber/green) based on the status of the supply.  The programming of its 4096 logic-element FPGA controls and protects every aspect of its operation to assure safe and reliable performance.
There has never been a power supply like this before!  The UltraCap LPS-1 will elevate the performance of whatever component you power with it.
[The adventurous could even purchase two units and hook their outputs up in series, perhaps with one set to 7V and the other to 5V to obtain 12V; An even more interesting application would be for a DIY hobbyist to use two units harnessed together and center-tapped to produce a pure and isolated bi-polar (+ & -) supply for audio circuit use.]
PLEASE READ
Edited by snurb
  • snurb changed the title to FS: Uptone Audio Ultracap LPS-1 - Linear power supply (3.3V, 5V, or 7V) -- SOLD PP
