WITHDRAWN: Gryphon atlantis loudspeakers(carbon fibre)
Item Condition: Great
Shipping Options: Pickup available and you can audition.
Suburb or Town: Sydney
State: NSW
Payment Method: Bank
Reason for selling: Nlr
Carbon fibre edition.
85 kg per speaker, active battery powered crossover for detail that is just incredible.
90db sensitive and very easy to power up, don't let it's size fool you. Condition is very very good and the glass tops are smooth and unscratched,. Can come  with upgraded footers for  extreme stability and ceramic balls for vibration control.
the bass tone and control from large cabinets is also a big plus.
i have had many many speakers, and i do not know anything at this proce point that will compete
audition is also welcomed.
*note*
i may be able to take swaps for certain high powered power amps if i am going to keep my other speakers.
thanks
PLEASE READ
Edited by Meluvmidfi
  • Like 13
  • Love 4
  • Meluvmidfi changed the title to Gryphon atlantis loudspeakers(carbon fibre)
18 minutes ago, palexsia said:
If you can post the spec / size may help the sale . GLWS
Features:
Three-way loudspeaker system
Duelund Constant Phase crossover for perfect phase at all frequencies at all times
System response 25 Hz – 32 kHz, -3 dB (depending on room size)
On-axis, time-aligned front baffle curvature for identical arrival time from all drivers at the listening position
Special cone surround termination to eliminate edge reflections
Hand-adjusted passive crossover network
Battery-powered bias for selected crossover capacitors
Accuton 30mm concave ceramic tweeter loaded with proprietary Gryphon wave guide
Reinforced enclosures with extensive internal bracing
Custom made Danish 8†woofer and 5†midrange drive units
Combination of pure wool and synthetic interior damping materials
Stylish string grille for driver protection
Custom finish options
Designed and hand-built in Denmark
Specification:
Crossover Frequencies: 250 Hz, 2,500 Hz, 4th order acoustical
Sensitivity: 90 dB/2.83V
Nominal impedance: 4 Ohm
Frequency Response: 25 Hz – 32,000 Hz, 3 dB (room dependent)
Dimensions (WxHxD): 39 x 118 x 72 cm
Weight: 85 kg (1 speaker)
Edited by cyberkank
Had a pair of these some years ago replacing my W/P 8’s and they were (and remain) superb transducers. Nothing will come close to it at this price!
And, for those who knew him, one of the (sadly) late Josef Riediger’s favourite speakers when it was released by Flemming Rasmussen.
