JL Audio Fathom F212 Repair advice wanted
My JL Audio Fathom F212 has just started to hum. Even when the input balanced lead is removed.
Still makes music though when  the lead is plugged in but hums irrespective.. I am thinking something in the power supply is making it do a 50HZ hum.
As I am in Newcastle and it weighs 100kgs I dont wish to go far to get it fixed.
Any advice?
  • Administrators
In the first instance, have you tried plugging it into an alternative power point (preferably one on a different circuit)?
There is a guy in Perth that specializes in JL audio
The hum issuse was quite common and I think there was some mods that were required
I know that Perth is a long way away  but
1   You could unscrew the plate amp and just send that
2  Ring him and see if he has a contact in NSW that could help you
RF Waves  08  93427161
His name is Chamila
He is an excellent Tech
Any advice?
The version 1 F113's have issues in the power supplies where some caps fail and the amps don't switch on.  There's a kit available to do the repair from JL but when I took my sub to the local authorised tech to get the repair done he said that they have their own kit with higher quality caps.  I suspect the repair for this issue is pretty easy as it was only abut $300.   The plate amp is the hard part to get out, you can't just undo the bolts and pull it out.   It needs to be pulled out with some oversize bolts.   Info is available on google or from JL on how to do this.   My second sub has a transformer type him which comes and goes, sounds like it's different to your 50hz hum though.   I took this sub to the same repairer for the cap upgrade as it was likely to fail hoping that this would sort the hum, didn't help that.
I've had some very good response from JL's tech Randy Wagner via email.   I'd maybe start with an email to Randy as it might be a common issue with JL.
