Item Condition: good
Shipping Options: Pickup available but audition is not available.
Suburb or Town: ryde 2112
State: NSW
Payment Method: cash on pick up
Reason for selling: upgrade
Further information:
PLEASE READ
10 hours ago, hopefullguy said:
hmm need to borrow my glasses? no atmos there.
you are correct - I saw 2 height pre-outs and checked Yamaha specs and it said 11.2 ch pre-out so I assumed Atmos - my bad :(
    • By elmura
      Item Condition: New. Sealed in box. Shipping Options: Pickup available and you can audition.,Shipping is included in price. Suburb or Town: Oran Park State: NSW Payment Method: All payment methods. Paypal add 2.6%. Reason for selling: Excess
      Strong™ Universal Fine Adjust Projector Mounts for big Projectors up to 23kg.
      SM-PROJ-XL-BLK RRP $480 Price includes delivery. Or you can pickup and save $30
      I ordered two of these so someone else can benefit from the best projector bracket on the market. I've fitted this to the Epson flagship in my home cinema and it is completely invisible. Highly recommended for premium home theatre.
      The main benefits are the fine adjustment rotary knobs that lets you precisely locate your image without keystone or overscanning so you maximise your projected picture quality. Anyone who's installed a projector with a regular bracket will attest that it's painful and time consuming to get it perfect as the one screw usually locks all 3 axis at once. And, usually when you tighten the screw, it goes out of precise position. And often they're a bit wobbly which causes image shake with big bass hits.
      With this bracket, you can finely adjust the distance from the screen (within a small range); horizontal position; vertical position; and yaw (rotation) - all individually. That's four separate adjustments available.
      Additionally, it's made to handle big, heavy projectors and keep them rigidly positioned so you don't get subwoofer induced picture vibration. I fitted one with the big Epson 9300W and love it. Enough talk, below is the sales blurb.
      ______________________________________________________________________________________________________________________________________________________________________________________________________________________________________
      Manufacturer's website link
      Equipped with longer mounting arms and security screw holes, these projector mounts are specifically designed to handle oversized models up to 50 lbs., including JVC projectors, while offering maximum installation flexibility. They feature tool-less adjustments - so getting the ideal alignment is a breeze - and have a simple three-piece design that minimizes time spent at the top of the ladder. Also included is a plastic cover to keep the install looking neat and tidy.
      Tool-Less Adjustments
      Getting a projector image to perfectly align with a screen is easier said than done. Thankfully this mount simplifies the process with easy-to-use vertical tilt, horizontal roll and yaw adjustments. Just pop off the cover and use the tool-less dials to make micro adjustments until the ideal alignment is achieved - no tightening or loosening of the screws required.
      Easy To Install
      A smart three-piece design makes it easy to get this projector securely installed. The top plate attaches to the ceiling and screws into the mount assembly body, while the bottom plate (with attached projector) simply slides and locks into place. It makes installing the product fast and easy.
      Security Screws
      This mount features multiple security screws for projector attachment, as well as screws on each side of the mounting base - which all help to lock things in place. Move the mount around until you get the perfect center of gravity for the projector, then tighten down the screws and you’re good to go!
      Mounting Flexibility
      For the most versatility in your next installation, this projector mount features longer arms that extend for up to 17.7” diameter mounting. Plus it has a series of slots on the arms and the bottom plate that provide almost limitless placement options, so it’s easy to get the projector perfectly positioned. Need to install directly in concrete or ceiling drywall? Not a problem – just use the included hardware.
      Extension Capability
      If you want to drop the projector off the ceiling with an extension pole, we've included a separate ceiling plate to allow for easy connection to the pipe. Also included is a plastic cover to keep the install looking neat and tidy.
    • By franky995
      Item Condition: Used Shipping Options: Shipping is available at agreed cost. Suburb or Town: Heatherton State: VIC Payment Method: Reason for selling: Further information:
      Bought new from A2A. Just sold my Sony’s so no longer need the upgrade cable. Happy to supply invoice dated 20/10/20.
      Excellent condition, hardly used.
      PLEASE READ
    • By Thi Nguyen
      Item Condition: 9/10 - Beautiful as per photos Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: PERTH State: WA Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: No Longer Required Further information:
      Hi All up for sale is this  Audio Research SP10 - Two Box Preamplifier
      They are certainly no made like this any more - beautiful sound preamplifier which is not easy and almost impossible to be for the price!
      This preamp was bought from the USA as a 120V however has been modified and serviced by Jason Boyd in 2019 who is also Audio Research Authorized technician
      The selling price is including all the tubes (12 X ECC88/6DJ8 for the preamplifier and 2 X 6L6GC, 1 X 12AT7 for the power supplier). Power cord cable for connected between power supply and preamplifier is included.
      This one wont last long so get a move on...
    • By murrmax
      Item Condition: Good Shipping Options: Pickup available and you can audition. Suburb or Town: ACT State: ACT Payment Method: EFT, Cash Reason for selling: Not needed Further information:
      2x Midbass 12" PHL drivers in cabinets, can extract but prefer to sell with cabinets.
      Cabinets are 90L tuned to 40hz driver specs below. use up to 800hz.
      I used them in an active setup so no passive xover in them.
      https://en.toutlehautparleur.com/media/catalog/product/datasheet/phl/4530-8.pdf
      One dust cap has a superficial hairline crack see pic. No effect on sound.
      Cabinets are very well constructed and suitably damped plywood construction. pick up locally or could post drivers if cabinets not wanted.
      Pick up/ delivery in NSW a possibility post covid restrictions.
    • By linnmaster
      Item Condition: Very good condition Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Melbourne State: VIC Payment Method: Pickup - Cash, Bank deposit, wire transfer. Reason for selling: Selling collection of a friends's Further information:
      Serial numbers 4917 & 4923
      Ohm measure 4917 - 7.3 ohm
      Ohm measure 4923 - 7.4 ohm
      I have been told all diaphragms are all original.  In excellent working condition as shown.
      Attached as follows.
