Soundguru 1 Posted December 3, 2020 Share Posted December 3, 2020 Hi Any recomendation for best music streamer and compatible speakers please. Quote Link to post Share on other sites
Snoopy8 3,334 Posted December 3, 2020 Share Posted December 3, 2020 Budget? Sources of music? Do you need amplification? Wired or wireless? Serious or casual listening? Quote Link to post Share on other sites
Soundguru 1 Posted December 3, 2020 Author Share Posted December 3, 2020 yes prefer amplification,have seen a marantz amp at $989, looked at Bluesound vault 2 @$1300 looking for a better quality sound compared to Spotify and sonos speakers Quote Link to post Share on other sites
dr_carl 193 Posted December 3, 2020 Share Posted December 3, 2020 One box solutions could suit you, like Naim mu-so. If you want separate speakers then Kef LS50 wireless ii would be good but $ is a factor. But there is so much you don't tell us, it's hard to give advice. What music do you play? How loud? Are you a details person or do you like a bit of tone too? Do listen intently or ambient? What is your music room like in dimensions and surfaces? 1 Quote Link to post Share on other sites
Snoopy8 3,334 Posted December 3, 2020 Share Posted December 3, 2020 18 minutes ago, dr_carl said: But there is so much you don't tell us, it's hard to give advice. +1 @Soundguru. Not sure why you are reluctant to tell us more? The answer to your intial question on a streamer can range from a cheap Chromecast to a $50K Taiko Streamer. Similarly for speakers, which can range from a few hundred dollars to hundreds of thousands.... Quote Link to post Share on other sites
Soundguru 1 Posted December 4, 2020 Author Share Posted December 4, 2020 yes prefer amplification,have seen a marantz amp at $989, looked at Bluesound vault 2 @$1300 looking for a better quality sound compared to Spotify and sonos speakers so my budget is $3000-$4000 Quote Link to post Share on other sites
Al.M 1,301 Posted December 4, 2020 Share Posted December 4, 2020 (edited) Here’s a bunch of review lists you can pick on ones you like and ask if any has experienced https://www.whathifi.com/au/best-buys/streaming/best-music-streamers https://www.themasterswitch.com/best-music-streamers etc just google them if you need more Edited December 4, 2020 by Al.M Quote Link to post Share on other sites
rantan 9,858 Posted December 4, 2020 Share Posted December 4, 2020 Bluesound Node 2i Rega Brio amplifier. Wharfedale EVO 4.2 ( with stands ) Around $4K at RRP and this gives you flexibility for line inputs as well as a nice phono stage if you wanted to try vinyl. 3 Quote Link to post Share on other sites
Andrew o_o 0 Posted December 4, 2020 Share Posted December 4, 2020 I had the AlloDigione Signature with 2 Shanti Linear Power Supplies which I thought was pretty good for the money. Quote Link to post Share on other sites
sleach 198 Posted December 4, 2020 Share Posted December 4, 2020 Just going to chuck out an option for you: look at something like a Cambridge CXN - very easy to use and very good performance for price. Then add a pair of powered speakers - budget like Acoustic Energy, more pricey like Kef Ls50, and many more excellent choices with no upper limit to price. Quote Link to post Share on other sites
Soundguru 1 Posted December 4, 2020 Author Share Posted December 4, 2020 15 minutes ago, rantan said: Bluesound Node 2i Rega Brio amplifier. Wharfedale EVO 4.2 ( with stands ) Around $4K at RRP and this gives you flexibility for line inputs as well as a nice phono stage if you wanted to try vinyl. thanks very much ,do you suggest also the bluesound vault 2 or does the Bluesound node 2i also rip and store? Quote Link to post Share on other sites
Soundguru 1 Posted December 4, 2020 Author Share Posted December 4, 2020 3 minutes ago, sleach said: Just going to chuck out an option for you: look at something like a Cambridge CXN - very easy to use and very good performance for price. Then add a pair of powered speakers - budget like Acoustic Energy, more pricey like Kef Ls50, and many more excellent choices with no upper limit to price. thanks for that Quote Link to post Share on other sites
rantan 9,858 Posted December 4, 2020 Share Posted December 4, 2020 1 minute ago, Soundguru said: thanks very much ,do you suggest also the bluesound vault 2 or does the Bluesound node 2i also rip and store? happy to help. If you require a rip and store facility you will need the Vault, although at the Vault's RRP I would be spending just a little bit more and buying an Innuos Zen Mini, which I think would be a large step up. It has rip, store and an onboard dac and can be upgraded later on with the linear power supply. I have yet to adopt streaming but if and when I do, the Innuos will be my first choice. I suggest you send a PM to @Hydrology who can assist you with Rega , Innuos and Wharfedale with customer service second to none. 2 Quote Link to post Share on other sites
