Cono28 147 Posted November 25, 2020 Share Posted November 25, 2020 (edited) Item Condition: Excellent Shipping Options: Pickup available but audition is not available. Suburb or Town: Maribyrnong 3032 State: VIC Payment Method: Paypal Bank transfer Reason for selling: NLR Further information: This 8" sealed type sub is produce fast and solid note way above it size , just the problem is it colour did not matches well with my current system 😒 Impact, depth and scale The Sub One8 produces bass that integrates beautifully for even the most critical music listening. A good subwoofer that is set up properly should never call attention to itself. The highly advanced 8 inch subwoofer driver produces deeper and cleaner bass than most comparable divers. You will notice that your system will play significantly deeper than before with much improved authority. Driver The Sub One8 is equipped with an extended excursion 8 inch driver. This driver has been engineered with sound quality as the primary objective: Fast, impactful and refined. The soft, low loss rubber surround and spider contribute to more nuances get translated into sound rather than absorbed by harder, stiffer materials usually used in high excursion subwoofers. The much lower loss also means that we can listen to the subwoofer at very low levels, and it will still have the same sound signature and be more enjoyable compared to its rivals. The very large voice coil of the driver results in an extremely firm grip of the diaphragm movements, and much reduced compression at high volumes due to the increased power handling of the larger voice coil. Amplifier Our no‑nonsense 300W RMS continuous power Superior Class‑D Amplifier remains cool and unstressed even during extended high volume listening. The well designed auto on feature will turn on the subwoofer automatically when a signal is sensed on the input. Once the settings of the volume, crossover and phase have been dialed in, it is just a matter of enjoying your systems improved impact, depth and scale. Cabinet construction The curves of the sealed cabinet, along with extensive internal bracing makes the subwoofer extremely rigid and free of unwanted resonances, that would otherwise color the sound. Internal standing waves are avoided due to the internal curvatures of the subwoofer enclosure. This, in turn, means that only a small amount of damping material is needed to control the energy from the back of the speaker driver. Using natural sheep’s wool fibers in small quantities as a dampener results in a more natural and textured bass compared to the over damped “woof” of the usual square box subs on the market. Photos: PLEASE READ If you are advertising multiple items, you must post one bulk price only, or post seperate ads for each item If you include any reference to pricing whatsoever in this section (excluding RRP), your ad will not be approved If you don't include photographs of the actual item being sold, your ad will not be approved Edited November 25, 2020 by Cono28 2 Link to post Share on other sites
WFM 3 Posted November 25, 2020 Share Posted November 25, 2020 Hi I'm interested. Sent pm. Link to post Share on other sites
leon81 12 Posted November 25, 2020 Share Posted November 25, 2020 Also interested if first one falls through. Link to post Share on other sites
Cono28 147 Posted November 25, 2020 Author Share Posted November 25, 2020 Thanks everyone for interested, this sub is on hold for payment. Link to post Share on other sites
