Ian Lyons 10 Posted November 23, 2020 Share Posted November 23, 2020 Ive tried to follow recent threads on ethernet cabling but I am struggling.Being new at streaming and still in the throws of setting it up still,could you please advise as to what cable I should run.I would need about 15 metres. Quote Link to post Share on other sites
Neo 912 Posted November 23, 2020 Share Posted November 23, 2020 (edited) Would recommend this cable https://www.4cabling.com.au/15m-cat-6a-s-ftp-lszh-ethernet-network-cable-black.html Edited November 23, 2020 by Neo Quote Link to post Share on other sites
david j 139 Posted November 23, 2020 Share Posted November 23, 2020 (edited) Another good one hear I bought to run out to my garage http://www.lindy.com.au/cables-adapters/network/cat7 and very fast delivery Edited November 23, 2020 by david j Quote Link to post Share on other sites
Ian Lyons 10 Posted November 24, 2020 Author Share Posted November 24, 2020 Thanks David j andNeo. Quote Link to post Share on other sites
Ittaku 4,357 Posted November 24, 2020 Share Posted November 24, 2020 17 hours ago, david j said: Another good one hear I bought to run out to my garage http://www.lindy.com.au/cables-adapters/network/cat7 and very fast delivery Second this. Lindy's cables are excellent. Quote Link to post Share on other sites
Ian Lyons 10 Posted November 24, 2020 Author Share Posted November 24, 2020 Do I basically run the cable through a hole in the wall to the router and streamer directly.In other words no other connection points to affect the signal Quote Link to post Share on other sites
Ittaku 4,357 Posted November 24, 2020 Share Posted November 24, 2020 Just now, Ian Lyons said: Do I basically run the cable through a hole in the wall to the router and streamer directly.In other words no other connection points to affect the signal You will get a lot of debate over that fact and whether you stand to gain benefit by putting in an isolation device of some sort between the router and the streamer. I'd say just plug it straight in, but others will probably advise you otherwise. Quote Link to post Share on other sites
david j 139 Posted November 24, 2020 Share Posted November 24, 2020 (edited) I got that info from your recommendation in a post ittaku about Lindy I wouldn't buy anywhere else Edited November 24, 2020 by david j 1 Quote Link to post Share on other sites
