eman 1,251 Posted November 23, 2020 Share Posted November 23, 2020 It's been suggested to me to look into these to guard against killing myself from dodgy gear. Never heard of it before but it essentially looks like a circuit breaker. I've got a new house and I know the breakers work. Do these do anything new ? Also there's simple plug in versions that would be easier if I do. Some have multiple outlets so useful as multiple power outlet. Thanks. Link to post Share on other sites
Bunno77 1,371 Posted November 23, 2020 Share Posted November 23, 2020 You should have them installed in your switchboard but find a sparky if not in your board. Something like this isn't a bad idea if you are building gear/playing around even if you do have them already installed in your switchboard. https://www.bunnings.com.au/click-4-outlet-powerblock-with-rcd-safety-switch_p0135806 2 Link to post Share on other sites
MrBurns84 439 Posted November 23, 2020 Share Posted November 23, 2020 7 minutes ago, Bunno77 said: You should have them installed in your switchboard but find a sparky if not in your board. Something like this isn't a bad idea if you are building gear/playing around even if you do have them already installed in your switchboard. https://www.bunnings.com.au/click-4-outlet-powerblock-with-rcd-safety-switch_p0135806 https://www.bunnings.com.au/hpm-10-amp-electrosafe-portable-powercenter-with-usb-charger_p4331113 Paid a bit more and got the one above. Well worth having esp when you have a bit of diy/imported gear. 2 Link to post Share on other sites
Bunno77 1,371 Posted November 23, 2020 Share Posted November 23, 2020 2 minutes ago, MrBurns84 said: https://www.bunnings.com.au/hpm-10-amp-electrosafe-portable-powercenter-with-usb-charger_p4331113 Paid a bit more and got the one above. Well worth having esp when you have a bit of diy/imported gear. This is a much better suggestion. HPM make very good gear. @eman Forgive my laziness for finding the first unit to appear and saying 'something like this'. I did find a clipsal unit but it was stupid money. Link to post Share on other sites
aussievintage 3,616 Posted November 23, 2020 Share Posted November 23, 2020 2 hours ago, eman said: It's been suggested to me to look into these to guard against killing myself from dodgy gear. Never heard of it before but it essentially looks like a circuit breaker. I've got a new house and I know the breakers work. Do these do anything new ? Also there's simple plug in versions that would be easier if I do. Some have multiple outlets so useful as multiple power outlet. Thanks. RCD/GFCI/ELCB/Safety switch Check the rules but for Queensland I found this Queensland If a home has been sold after 1 September 2002, a licensed electrical contractor can only do installation work if a safety switch is being installed as part of that work or if it is an emergency. All leased domestic residences must have safety switches on their power points. When a house is sold without a safety switch, it must have one installed within three months. Safety switches for lighting is not compulsory, but recommended. Link to post Share on other sites
eman 1,251 Posted November 23, 2020 Author Share Posted November 23, 2020 (edited) 35 minutes ago, Bunno77 said: You should have them installed in your switchboard but find a sparky if not in your board. Something like this isn't a bad idea if you are building gear/playing around even if you do have them already installed in your switchboard. https://www.bunnings.com.au/click-4-outlet-powerblock-with-rcd-safety-switch_p0135806 26 minutes ago, MrBurns84 said: https://www.bunnings.com.au/hpm-10-amp-electrosafe-portable-powercenter-with-usb-charger_p4331113 Paid a bit more and got the one above. Well worth having esp when you have a bit of diy/imported gear. 22 minutes ago, Bunno77 said: This is a much better suggestion. HPM make very good gear. @eman Forgive my laziness for finding the first unit to appear and saying 'something like this'. I did find a clipsal unit but it was stupid money. Thanks guys. It's for a cheap import. Suggested as a just in case idea, but maybe adds a safety level generally anyway. I do have a standard box full of circuit breakers on the house that I know do work. I was looking at exactly the ones you linked. What I didn't notice was the different manufacturer. Edited November 23, 2020 by eman Link to post Share on other sites
aussievintage 3,616 Posted November 23, 2020 Share Posted November 23, 2020 57 minutes ago, eman said: It's for a cheap import. If your house has one, as it should, then you don't need to buy anything. If your house doesn't, get one installed soonest 2 Link to post Share on other sites
eman 1,251 Posted November 23, 2020 Author Share Posted November 23, 2020 13 hours ago, aussievintage said: If your house has one, as it should, then you don't need to buy anything. If your house doesn't, get one installed soonest Thanks. That was what I thought to start with. House is New so it has all the right gear. I also know it works from when I had an electrical fault in a brand new RCM. Link to post Share on other sites
MrBurns84 439 Posted November 24, 2020 Share Posted November 24, 2020 13 hours ago, aussievintage said: If your house has one, as it should, then you don't need to buy anything. If your house doesn't, get one installed soonest Mine didnt - hence why i got one a while back. Since i updated the circuit box last month, its got an RCD wired for each circuit. Link to post Share on other sites
MrBurns84 439 Posted November 24, 2020 Share Posted November 24, 2020 6 minutes ago, eman said: House is New so it has all the right gear. I also know it works from when I had an electrical fault in a brand new RCM. 👍 Link to post Share on other sites
