Item Condition: Fair
Shipping Options: Pickup available and you can audition.
Suburb or Town: Morley
State: WA
Payment Method: EFT or Cash
Reason for selling: Not being used
Further information:
For sale is a pair of 2-way tuned port speakers from the Interdyn Designer Series made in Melbourne.
The Designer Series concept was to source the quality drivers from SEAS in Norway for Australian designed and build cabinets. The crossover employ air-cored (as opposed to ferrite-cored )inductors and polypropylene capacitors. The two SEAS drivers consist of a 25mm aluminium tweeter and a 200mm treated fibre cone and heavy barium ferrite magnet woofer.
The speakers were for many years successfully pair with the Mission Cyrus III (2x 50W) integrated amplifier given the drivers' 94db sensitivity. These speakers are reportedly very well match with valve amplifiers.
The Jarrah veneer cabinets have faded over the years and there is evidence of wear. The drivers, however, have never been damaged, removed or even cleaned for sale and are therefore in good condition. The speakers' condition has been listed as fair overall.
The BT1
  • 40-150 watts amplifier required
  • 38 Hz - 20,000 Hz frequency response
  • 8 ohms impedance
  • 270W x 875H x 310D (mm)
  • 18 kg
    • By Sansui77
      Item Condition: Excellent condition Shipping Options: Pickup available and you can audition. Suburb or Town: S/E Melbourne State: VIC Payment Method: EFT, Cash is always good Reason for selling: NR Selling my 2 ways Seas Speakers. They incorporate the following high end drivers.
      http://www.seas.no/index.php?option=com_content&view=article&id=360:e0022-08s-w22ex001&catid=49:excel-woofers&Itemid=359
      http://www.seas.no/index.php?option=com_content&view=article&id=367:e0011-06-t25cf002&catid=50:excel-tweeters&Itemid=360
      Fantastic sounding quality, accuracy, wide sound stage and imaging. These would compare up to $5000 speakers. The cabinets have been professionally made with internal bracing. The crossovers have high end audiograde inductors, resistors and capacitors.
      Pickup only please.
    • By SssJedi
      Item Condition: Brand new Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Tarneit State: VIC Payment Method: Paypal with fees, EFT Reason for selling: No longer needed In new condition. Box bit battered.
      Product link: https://audioalchemy.ro/difuzoare/microprecision/MP-5-8-Widerange.pdf
      The 5.8 uses extrem low weight
      membrane and voicecoil. This results in
      an extreme extended frequencyrange
      up to 20.000 Hz. The natural papermembrane has no coloration of
      midrange and a, comparing to the small
      size, full bodied sound.
      The 5.8 can be used in cabinets from
      1-20 Liter and should be highpassed
      120-150Hz / 6 or 12dB/oct.
      PLEASE READ
    • By Dan_L
      Item Condition: Used Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Castle Hill State: NSW Payment Method: Paypal, Cash on Pickup Reason for selling: Too many speakers Further information:
      Used but in excellent working and looking conditions, only one minor imperfection on one box upper right hand corner(see photo)
      Reviews and User Manual can be found online.
      Will come with original packaging and I am the first user.
      Pick up preferred but can be posted with extra fees(to be checked with Aus Post)
      Specification:
      Description                         2 way stand/bookshelf loudspeaker
      Enclosure type                   Spendor 2D linear flow reflex
      Drive unit HF                      27mm coated fabric dome, damped vented enclosure
      Drive unit LF/MF                140mm ep38 polymer cone
      Frequency response         60Hz - 20kHz ±3dB on reference axis
      Frequency range               -6dB at 48Hz
      Dispersion                           Within 3dB of response on reference axis
                                                     Horizontal over 40o arc ± 20o
                                                     Vertical over 20o arc ± 10o
      Sensitivity for 1W @ 1m    86dB
      Impedance nominal          8 ohms
      Impedance minimum       6.8 ohms
      Crossover frequencies      4.8kHz
      Power handling                  15-125 watts into 8 ohms unclipped
      Harmonic distortion          < 1% 100Hz-20kHz 90dB @ 1m
      Connections                       2/3 way gold-plated bi -wirable terminals
      Magnetic shielding           All drive units shielded
      Dimensions H x W x D     340 x 165 x 260mm (13.4 x 6.5 x 10.2 in)
      Spikes/feet/stand height 500-600mm (20-24in) stand not supplied
      Net weight                          8.5kg (18.7 lb)
      Shipping weight                17.9kg pair (39.5 lb)
      Cabinet real wood finishes Cherry, Maple, Rosenut, Black ash
      Designed and Manufactured in the UK
      PLEASE READ
    • By Sansui77
      Item: Harbeth SHL5 30th or HL5 Super Anniversary Speakers.
      Price Range: Neg
      Missing the British sound. Pm me if you have a set you're willing to sell.
    • By Mrpseudonym
      Item Condition: Perfect 10/10 Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Waverton (north sydney) State: NSW Payment Method: EFT, paypal +3%, cash .. etc Reason for selling: Raising funds for new DAC Further information: ProAc Tablette 10 signature version, an upgrade to the regular Tablette 10. RRP $4200 (rosewood finish is a $400 option). These are closed constructed cabinets so can be placed close to a wall. Hardly used, less than a year old. Original purchase receipt will be provided for warranty purposes.
      Lots of great reviews
      https://darko.audio/2018/03/working-a-tight-corner-the-proac-tablette-10-signature/
      https://alpha-audio.net/review/review-proac-tablette-10-signature/
      And whole threads on the NAIM forum
      https://community.naimaudio.com/t/show-us-your-tablette-10
