TommyGunn 4 Posted November 8, 2020 Share Posted November 8, 2020 So, doing a demo had A and B front channels/towers on played a 30sec youtube video to showcase my setup running at +15Db for about 10 seconds and went into protect mode. Turns out I had fried a few minor components and two of the major ones. Would that be because I had both front channels on at the same time at 90% volume ? Surly not. Any advice would be greatly appreciated...And no I won’t be turning it up that loud again. Lol Link to post Share on other sites
steffanth 185 Posted November 12, 2020 Share Posted November 12, 2020 i would suggest that if you want to be playing things at that level, you should be looking looking at a diffrent setup. A pre-pro setup with a decent amp. The amps in that avr are babies compared to a poweramp and you were driving them to max levels. Your actually quite lucky you didnt destroy your speakers at the same time. Im pretty sure they would have been clipping at that level. AVR's are really not designed for that kind of load. are they 8 ohm speakers or 4 ohm. alot of avr's are not capeable of powering 4 ohm speakers either. 3 Link to post Share on other sites
pete_mac 4,065 Posted November 12, 2020 Share Posted November 12, 2020 On 09/11/2020 at 2:08 AM, TommyGunn said: So, doing a demo had A and B front channels/towers on played a 30sec youtube video to showcase my setup running at +15Db for about 10 seconds and went into protect mode. Turns out I had fried a few minor components and two of the major ones. Would that be because I had both front channels on at the same time at 90% volume ? Surly not. Any advice would be greatly appreciated...And no I won’t be turning it up that loud again. Lol Which speakers are were you running at the same time? You'll note the writing on the rear panel of the amp regarding minimum speaker impedances, and that you effectively shouldn't be running your A+B speakers at the same time unless they are each 12 ohms impedance or higher. Unfortunately, if you haven't heeded this advice, and have also run the amp at very high output levels whilst running inappropriate/non-recommended loads, I'm not surprised that the "magic smoke" escaped Link to post Share on other sites
rantan 10,022 Posted November 12, 2020 Share Posted November 12, 2020 On 09/11/2020 at 1:38 AM, TommyGunn said: Would that be because I had both front channels on at the same time at 90% volume ? Surly not Sorry, you almost had me there. For a moment I thought you were serious and not joking.. OR are you really serious? 😱 Say it ain't so. 1 Link to post Share on other sites
TommyGunn 4 Posted November 12, 2020 Author Share Posted November 12, 2020 Than you for you advice. I am serious, silly if you ask my wife. The other channel had a pair of Jay carJV80 kit set speakers... Specs JV80 Jaycar kit http://www.siliconchip.com.au/Issue/2003/October/The+JV80+Loudspeaker+System Power: 100watts Type: 2way base reflex + 2 ports Impedance: 8 ohms Frequency range:30Hz-20kHz Crossover:3.5kHz Linkwitz-Riley Sensitivity: 91db/1W at 1 metre (on tweeter axis) Protection: PTC polyswitch thermister Kind of new to this stuff and, I guess you could call it a journey. To learning about the right setup and what not to do. Lol This gear is all second hand and not really worth a whole lot. I have learned a lot in the last few weeks. Cheers guys. Rock on 🤘 Link to post Share on other sites
TommyGunn 4 Posted November 12, 2020 Author Share Posted November 12, 2020 Forgot to mention that channel A was running a pair of Dali concept 6’s and channel B had the jaycar JV80’s. Both have an impedance of 8 ohms. Link to post Share on other sites
pete_mac 4,065 Posted November 12, 2020 Share Posted November 12, 2020 11 hours ago, TommyGunn said: Forgot to mention that channel A was running a pair of Dali concept 6’s and channel B had the jaycar JV80’s. Both have an impedance of 8 ohms. That's the root of the problem right there. As noted on the rear panel of the amp , if you run A and B speakers together, they must have a nominal impedance of 12 ohms or higher. The A and B outputs are wired in parallel, so this presents a 6 ohm nominal load on the amp (which happens to be the minimum impedance for speakers when you run A or B independently). If you run two pairs of 8 ohm nominal speakers on A and B at the same time, this is a nominal 4 ohm load (noting that speaker impedances are not fixed and actually vary, so the actual load could be noticeably lower). Your amp isn't rated for this. It might be OK at a low volume levels, but certainly not at full-tilt... even for a short period of time. 3 Link to post Share on other sites
TommyGunn 4 Posted November 14, 2020 Author Share Posted November 14, 2020 No worries mate. Thank you for your input. Appreciated greatly 1 Link to post Share on other sites
