rox 9 Posted November 8, 2020 Share Posted November 8, 2020 This is awesome placemat available in ikea , it’s a little bigger, all you need to do is trim to size and that’s it. Try it out and I think no regrets here. 5 Link to post Share on other sites
shailesh 24 Posted November 8, 2020 Share Posted November 8, 2020 Nice find Rox. Thanks for sharing. @WillR Link to post Share on other sites
Pipey 75 Posted November 8, 2020 Share Posted November 8, 2020 Looks cool. What’s it made of ? Link to post Share on other sites
rox 9 Posted November 8, 2020 Author Share Posted November 8, 2020 It feels like very rigid form but also flexible and the finish is awesome. Link to post Share on other sites
DEANO23 390 Posted November 8, 2020 Share Posted November 8, 2020 Love the look of it i wonder if its paper ? How is the static with it ? Link to post Share on other sites
rantan 9,868 Posted November 8, 2020 Share Posted November 8, 2020 (edited) It certainly looks the part. How much did you need to trim? Edit: I had a look on the Ikea website and couldn't find it. When did you buy it? Edited November 8, 2020 by rantan Link to post Share on other sites
metal beat 19,316 Posted November 8, 2020 Share Posted November 8, 2020 28 minutes ago, rantan said: It certainly looks the part. How much did you need to trim? Edit: I had a look on the Ikea website and couldn't find it. When did you buy it? https://www.ikea.com/my/en/p/panna-place-mat-dark-blue-10351144/ 1 Link to post Share on other sites
audiofeline 2,376 Posted November 8, 2020 Share Posted November 8, 2020 (edited) 4 hours ago, metal beat said: https://www.ikea.com/my/en/p/panna-place-mat-dark-blue-10351144/ The mat looks very cool; Spec's from the link: PANNÅ Place mat, dark blue EVA plastic Wipe clean with a damp cloth. Withstands temperatures up to 65°C. Width: & Length: 37 cm Edited November 8, 2020 by audiofeline Link to post Share on other sites
YCC 3,094 Posted November 8, 2020 Share Posted November 8, 2020 Looks like it's IKEA Malaysia site. Link to post Share on other sites
LogicprObe 7,633 Posted November 8, 2020 Share Posted November 8, 2020 ;Did you have to drill a hole in it? Link to post Share on other sites
vinilink 821 Posted November 8, 2020 Share Posted November 8, 2020 Singapore website https://www.ikea.com/sg/en/p/panna-place-mat-red-80351150/ I will grab one while in Singapore. 1 Link to post Share on other sites
rox 9 Posted November 10, 2020 Author Share Posted November 10, 2020 It’s available in Sydney IKEA I picked it up 3 weeks ago and yes it’s does not show on they website. You have to visit IKEA near you . Trimming is about 25 mm around. used a old mat as a template. It really sits well and a album with static does not lift it out of place. It does a good job. 2 Link to post Share on other sites
rox 9 Posted November 10, 2020 Author Share Posted November 10, 2020 Regarding hole in the middle , just made a small hole with a pen then used a round file to make the hole just to fit in the player. 2 Link to post Share on other sites
EV Cali 1,039 Posted November 10, 2020 Share Posted November 10, 2020 This is one of mine made from a IKEA cork place mat. They were slightly larger and I used a 6mm hole punch to form the hole. The main reason I used them was to raise the arm at the head shell end to make it level. I use a rubber mat on top of this. I remember the mats being round but this is the closes I can find. https://www.ikea.com/au/en/p/avskild-place-mat-cork-10281655/ 1 Link to post Share on other sites
DEANO23 390 Posted November 11, 2020 Share Posted November 11, 2020 On 09/11/2020 at 10:42 AM, vinilink said: Singapore website https://www.ikea.com/sg/en/p/panna-place-mat-red-80351150/ I will grab one while in Singapore. Grab a few if you can I wouldn't mine trying a couple , plus red looks good too. Link to post Share on other sites
rox 9 Posted December 2, 2020 Author Share Posted December 2, 2020 I found out this mats are run out and won’t be available anymore. Link to post Share on other sites
wasabijim 687 Posted December 4, 2020 Share Posted December 4, 2020 i remember seeing these a year back or so. i was going through another period where everything i come across was scoped for potential vinyl use. so its good to see its been picked up and put to task Link to post Share on other sites
