SOLD: FS: GIESELER Klein DAC II
Recently Browsing 0 members
Similar Content
By Tassie Devil
Item Condition: Mint Shipping Options: Shipping is included in price. Suburb or Town: Dilston State: TAS Payment Method: Bank Transfer Reason for selling: Surplus to requirements Further information:
I have two of these but am parting with one. This is the best DAC I’ve owned and transforms good CDs to sound as good as SACDs and other hi-rez. I’m often surprised at the AQ being heard and find it is merely CD quality, not Hi-Rez. One acid test of a DAC;s ability to translate digital to pristine analog is a harpsichord recording. Most DACs turn this into a jangled mess but the LKS transforms all the complex harmonics into beautifully sounding music.
This LKS was modded by Rick Schultz and was imported from the USA so comes with a quality step down transformer which effectively isolates the DAC from power line nasties.
I’ll copy and paste below more info on this DAC gleaned from Rick Schultz net posts and please contact me for any more information.
As far as I know this is the first and only DAC in the world with two ESS9038 DAC chips running in dual mono. But it has so much more: discrete shunt regulators for the output stage, completely discrete output stages (no op amps), serious rectifier diodes, two 40 watt transformers, I2S input, digital volume control, DSD512 capable, Furutech AC inlet, 7 digital filter choices, Cardas output jacks, serious parts, etc. Even the remote is a hunk of aluminum. This thing is huge.....and it sounds amazing....even stock. The simple mods I do tfor a few hundred dollasrs ake it to another level. If you are using anything besides usb it sounds best with the usb board removed. I personally think that usb should always be done externally with a modded Singxer running I2S into the DAC.
A single ESS 9038 DAC is essentially 4 ESS9028 DACs in parallel. So running two of them in mono mode means you essentially have 32 9028 channels in parallel. The more DACs in parallel the better the resolution....this is a know fact.
Taken awhile but finally did some more terrific mods to the LKS and it is now clearly the best DAC I have heard. Amazing what changing and modding a few parts can do. Simply stunning!
I have a friend in Pocoima who has one of these and we have been tweaking them at the same time. He has a great expensive turntable system and he says that playing 16/44 from his Beatis server through coax and then through modified IFI spdif Ipurifier and then through modded LKS is at least as good as his turntable system!! No upsampling....nada....just great sound.
The Basic mod I have worked out makes a serious improvement in involvement, reality, dynamics, low level detail, imaging, depth, air, lower distortion......well, basically everything. I do mods to the AC power, the DC power, output stage filtering, all output stages, the spdif type inputs, etc.:
1. Remove fuse distortions.
2. Remove all steel from around the transformers and remount transformers on pieces of wood.
3. Twist secondary AC wires.
4. Apply Graphene contact enhancer on AC connectors on board.
5. Damp all rectifier diodes with constrained layer damping material
6. Damp all heatsinks with constrained layer damping material.
7. Remove all coupling caps on the spdif inputs and replace with custom pure copper wire in cotton (listened to for directionality).
8. Shorten the signal path on the unbalanced outputs and use our custom wire here.
9. Change filter caps in output stage to better ones
10. Change all compensation caps in all output stages to better ones.
11. Damp certain power supply caps
12. Remove steel leads from film caps on 3.3V power supply to DAC and orient caps in proper direction (outside foil to ground).
13. Properly orient poly caps on output of regulators for output stage.
14. Change IV resistors to high quality ones.
15. Remount output transistors in IV stages and bend them forward so they are no longer close to the power supply caps and wrap those power supply caps with gold reflective tape to further reduce their temperature. The transistors in the stock LKS are too close to the caps and can cause them to burn up within a year if left on all the time. The very latest LKS DACs have the transistors mounted underneath the chassis to eliminate this problem. My solution works as well.
PLEASE READ
If you include any reference to pricing whatsoever in this section (excluding RRP), your ad will not be approved If you are advertising multiple items, you must post one bulk price only, or post seperate ads for each item If you don't include photographs of the actual item being sold, your ad will not be approved You understand that a reasonable donation for selling fees is expected upon successful sale of your item
- if you have previously sold items and not made a donation, your advertisement may not be approved.
By DaRick
Item Condition: As New; Mint Shipping Options: Pickup available but audition is not available.,Shipping is included in price. Suburb or Town: Bracken Ridge State: QLD Payment Method: EFT, Cash on Pickup Reason for selling: NLR Further information:
Purchased from Audiophile Store AU in mid-January 2021. Have included Warranty Card for future use. If you need more information regarding purchase, please message me.
Condition is 'as new', or 'mint' - there are no scratches or marks on this unit to my knowledge.
Supplied with the original items, including: Instruction Manual, Warranty Card, Micro USB to barrel plug 5V cable, USB A-B Cable and the remote.
Original packaging is NOT available, BUT all items were sealed very tightly using a several-step process:
1) I placed items in seal lock bags, with appropriate descriptions.
2) I then wrapped bubble wrap around the seal lock bags and sealed the bubble wrap to the bags using masking tape.
3) I then placed the now-sealed items into a large seal lock bag, with appropriate descriptions, before using masking tape to seal that.
4) I used white packaging cardboard to reinforce the sides.
5) I placed bubble wrap over the sealed large bag, before covering the bubble wrap with two rows of aircushions
6) I then sealed the box with several rows of masking tape, which will then be covered by the label, should this need to be posted
Cheers to @lenticularis for providing the following:
"Like the Gieseler DAC range, uses an AKM chip (the AKM4493EQ). Sounds extremely good for its price.
This DAC can also be powered from a power-pack or an iFi 5V supply, using the same micro-5V cable described above."
Reviews of this DAC have been very impressive; although I've only tested it a couple of times, it impresses me as an inexpensive, reliable and effective product.
Thanks to @Ittaku for the following specs:
"Spec:
PCM
USB :44.1kHz-768kHz 16bit-32bit
OPT/COAX : 44.1kHz-192kHz 16bit- 24bit
DSD (Native)
USB :DSD64-DSD512
OPT/COAX :Not supported
DSD (DoP)
USB : DSD64-DSD256
Output Voltage:2Vrms@0dBFS
THD+N:<0.0003% @1kHz A-weighting
Noise:<2uVrms @A-weighting
Crosstalk:-130dB @1 kHz
SNR:>121dB @ 1kHz
Dynamic Range:119dB @1kHz
Channel Balance:<0.3 dB
Features:
1. AK4493 DAC chip
AK4493 is a new generation of premium model AK4490 from AKM.
-11 3dB :Distortion
1 26dB* :Dynamic range
DSD :Support DSD512
PCM :Support 768k
* This data is based on the MONO mode of chip, not equal to specs of E30.
2.Supports DSD512 and PCM32bit/768kHz
E30 uses 2nd generation XMOS XU208, USB supports up to PCM32bit768kHz and DSD512, which is far
more than CD and SACD. We also customise the driver (for Win7 and above) from Thesycon to get a better performance with your computer.
3.AK4118 receiver
AK4118 is currently the S/PDIF receiver with lowest jitter, compatible with optical and coaxial connection that support up to 24bit/ 192kHz.
4.Commonly used inputs
E30 supports USB, optical and coaxial inputs which cover a variety of commonly used occasions, such as computer, mobile phone OTG, digital turntable and media player, TV and set-top box.
5.5V power supply, anytime and anywhere
Using 5V power supply, E30 can easily access the working power supply anytime and anywhere in nowadays. You can power the E30 by USB port of computer, mobile phone charger or portable charger. When using portable charger, E30 turns into a portable DAC and bring the Hi-Res music around.
6.DAC filter mode
E30 is capable of providing 6 filter modes under PCM decoding, 2 filter modes under DSD decoding, which slightly adjust the details.
7.Auto turn on/off
E30 has auto turn on / off. It will automatically enter into standby when the input signal is lost or unavailable in 1 minute. Once detecting any signal inputs, it will turn on and switch to this input.
8.DAC + Pre-amp application
E30 has a built-in volume control function that can adjust the volume from -99dB to 0dB by using the remote control, so you are able to directly connect E30 to a power amplifier or active speakers, and control the volume of E30 through the remote control.
9. Pure DAC application
The E30 is able to fix to maximum output level so that it function as a pure DAC. In this mode, the DSD signal will bypass the DATT Soft Mute and 02 Modulator to provide pure/direct DSD performance."
I thank you kindly for any interest or queries.
P.S.: Don't worry how the DAC looks in one of the photos below - that's just the flash! I did that to illuminate the DAC, to prove that it was the genuine article.
PLEASE READ
By BugPowderDust
Item Condition: Excellent Shipping Options: Pickup available but audition is not available.,Shipping is available at agreed cost. Suburb or Town: Macedon Ranges or Melbourne CBD State: VIC Payment Method: Paypal, EFT, PAYID, Cash Reason for selling: Upgraded
Lumin T2 Network Streaming DAC
I've recently upgraded from the Lumin T2 to a MSB Premier DAC so this is now superfluous to needs.
[No the Fender Stratocaster in the background doesn't come with it]
This is a top tier streaming DAC capable of supporting playback of PCM up to 384 kHz and DSD512 with optional internal upsampling to DSD128 and PCM 384 kHz. The Lumin app is great, with support for Spotify, MQA, Tidal, Qobuz, tuneIn and Airplay. The T2 will also happily function as a Roon endpoint where it did most of its heavy lifting for me.
I have upgraded this unit to the latest and greatest firmware and it has not missed a beat in its time with me. It is in excellent condition, not a scratch on it. It comes in the original double box with all accessories and the receipt from purchase in 2019. The Lumin T2 has a 2 year global warranty so there is still time to run on this. If you're looking for something to take your streaming digital playback to the next level, this is the device for you.
Manufacturer Website: https://www.luminmusic.com/lumin-t2.html
SNA Review: https://www.stereo.net.au/reviews/lumin-t2-network-player-review
LUMIN T2 heralds the first redesign of the classic A1/T1 main boards and chassis. This new approach combines solid cnc panel construction with X1 technology to hit the performance sweet spot.
All-new chassis construction featuring thick cnc panels and an internal power supply New generation processor provides DSD512 and 384kHz playback Dual ES9028PRO SABRE DACS USB digital audio output Precision 32-bit internal digital volume Discreet clock system for precision timing Low-noise switching power supply with dual stage regulator Resampling to every supported format up to DSD128 and PCM384kHz MQA full decoding Roon Ready, Spotify Connect, MQA, TIDAL, Qobuz, TuneIn and AirPlay-compatible From MQA to DSD, FLAC to WAV, LUMIN can play all the high-resolution formats you could ever want Native support for TIDAL, Qobuz, Spotify and AirPlay-compatible, giving you access to tens of millions of songs New CNC panelled construction offers upgraded structural rigidity and sheilding compared to the T1 The newly-designed thick cnc panels provide the high-end LUMIN family aesthetic
By crimsondelagator
Item Condition: Excellent - fewer than 5 months old. Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Lennox Head State: NSW Payment Method: Paypal, bank transfer, Cash on pickup Reason for selling: NLR Further information:
The housing is scratch/chip free. Aesthetically & Functionally perfect. Will provide purchase receipt from Minidisc (Dec 2020)
Bought to listen to while nursing our newborn son at night. Turns out it's harder than I thought to relax and kick back to the Grateful Dead when there is a screaming baby beside you. I used it for less then 5 hours. Noob parent realisations... 😐
It sounds great with IEM's and lower impedance Headphones. Awesome for tidal MQA streaming on the go.
I will also sell the Apple lightening USB Camera adapter (rrp. $65.00 ) to Iphone users ... Note: this accessory is essential if you wish to use with an iphone. If you buy both we will negotiate a discounted price on it. Preference to pm's that want this included - as I now have no use for it.
I'm also selling Campfire Polaris IEM's. The Dragonfly and them make a killer combo. See Darko's thoughts on the paring below.
https://darko.audio/2019/07/10-more-thoughts-on-the-audioquest-dragonfly-cobalt/
PLEASE READ
By Pioneer Lux Man
Item Condition: Excellent for Age Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Tennyson State: QLD Payment Method: Paypal, EFT, Cash on Pickup Reason for selling: NLA Further information:
Amp is in virtually pristine condition with beautiful, polished walnut timber ends. Comes with both English & Japanese user manuals. Recently checked & serviced by technician prior to sale. Has a clean bill of original health to offer new owner. No issues whatsoever. Dual Bias was checked & measured with voltage of 247v. Output WRMS per channel measured at 130w @ 8ohm. Extremely well appointed integrated amplifier with mm/mc phono that offers sublime variable auto RIAA equalisation correction. Boasting a host of features, including multiple inputs/outputs & onboard DAC. Variable input voltage. (100-240v 50/60Hz.) High quality speaker wire connections & so on. (See Specs below.)
Amp is in unmodified, original condition.
New owner will receive a high end flagship amplifier of outstanding performance & condition. Amp can be auditioned in Tennyson (Brisbane) and packaging/shipping/insurance can be arranged for interstate buyers at cost.
Specification:
Form
Digital multi-interface loading Integrated Amplifier
<Power amplifier part (Line terminal -> SP terminal)>
Output power (20Hz - 20kHz)
130W+130W (6ohms)
110W+110W (8ohms)
Input sensitivity/impedance
CD input: 150mV/30kohm
THD
0.004% (20Hz - 20kHz, 55W, 8ohm)
Dynamic power
350W (2ohms)
275W (4ohms)
170W (8ohms)
TIM distortion
Below measurement full limits
Output bandwidth
5Hz - 100kHz (Output 55W, 0.5%, 8ohms)
Line-in frequency response
4Hz - 150kHz, and +0 -3 dB (outputs 1W and 8ohm)
Output load impedance
0.1ohm or less
Output terminal
Speaker: AorB:6-16ohm, A+B:12-16ohm
Headset-jack maximum except take-off: 430mW (8ohms), 8-400-ohm conformity
<A digital interface / the DAC section>
A digital-input/output level / impedance
0.5 Vp-p/75ohm same axle
Standard light input: Two lines
Frequency response (0dB)
5Hz-20kHz±0.3dB
Signal to noise ratio (dB for zero, 1kHz)
105dB
Dynamic range (1kHz)
100dB
THD (0dB, 1kHz)
0.0025%
<Preamplifier part>
Phono MM: 2.5mV/47kohm
Phono MC: 0.2mV/100 ohms
CD, AUX, Tuner, Tape1, 2PB:150mV/30kohm
The maximum except take-off/Output power
8V/150mV
THD
0.002% (MM, 1kHz, 8V)
Equalizer (RIAA) deflection
20Hz-50kHz±0.3dB (MC IN)
<Synthesis>
(an input short circuit, the auditory sensation weighting A)
Phono MM:82dB
Phono MC: 62dB (at the time of a 0.25mV input)
Line:108dB
Tone control characteristic
Bass: ±8dB (100Hz)
Treble: ±8dB (10kHz)
Subsonic Filter
16Hz, -12 dB/oct
Loudness control characteristic
100Hz:+6dB
10kHz:+6dB
Muting switch
-20dB
Power consumption
(Electrical Appliance and Material Control Law)
216W
Power source
AC100V – 240v, 50Hz/60Hz
Dimensions
(Includes, such as a foot, a knob, and a terminal)
Width 470x height 181x depth of 420mm
Weight
19.4kg
‘Translated’ Japanese info Below:
The PMA-890DG Integrated Amplifier features 20bit S.L.C and an optical Class A circuit. The real 20-bit super linear converter of right-and-left channel independence is carried in the D/A converter. Outstanding D/A conversion is performed in response to the 20-bit 8 time oversampling signal made from a digital filter. Moreover, the difference among sampling frequencies, such as CD, DAT, and satellite broadcasting, is identified automatically in a digital multi-interface circuit. Furthermore, the internal clock required for a recovery was made 2powerful PLL composition, and the influence of Gitta (time fluctuation of a digital signal) is lost.
The P.B.S (Penta Block Separated) chassis structure where the inside of amplifier was divided into 5 blocks for every basic circuit is adopted. The magnetic flux of a power-source block and the digital noise of a digital block and a display block have prevented jumping in to other circuits. Furthermore, interference with a very small signal part and the Taishin number part is solved, and an unnecessary fine vibration is simultaneously suppressed by the large improvement in chassis rigidity.
The optical Class A circuit is newly carried in the power amplifier part. This circuit is a Class-A circuit which uses an optical element for transmission of the control signal sent to a bias circuit from a bias control circuit, and has eliminated the mutual intervention between the main signal system and a bias controlling circuit. Moreover, a voltage magnification stage important for the drive of an electric power magnification stage adopts three steps of differential amplification, the first rank adopts ultra-low-noise FET, low-noise-izing and direct-current amplifier-ization are attained, and the final stage of power amplifier is using the high speed and the mass transistor of Pc80W by the parallel push pull.
The power-source part is what heightened instant response capability. A 6.3kg heavy weight class large-sized shield power transformer is adopted as a power transformer, and the pure dynamic circuit of adoption of high-class and large-sized a commutator and an electrolytic condenser and 2-2 system which intercepts a power-source noise is carried.
The wide-range MC/MM equalizer amplifier which adopted direct-current servo system is carried.
The Source-Direct switch which can link all the input sauce with power amplifier directly, broadband real-time tone control and the speaker terminal change of a protection relay system, and the reset type high-speed protection circuit are carried.
PLEASE READ
