Berkel Posted October 30, 2020 Share Posted October 30, 2020 G'day folks, Some of you may have seen my recent post re: moving on to a better TT than my Pioneer PL15 R. I read info about the Technics SL 10, and am intrigued by it. I remember when it first appeared. I can source one, but before taking the plunge, wanted to asked my " learned friends " their opinions. Cheers, Dennis Link to comment Share on other sites More sharing options...
mloutfie Posted October 30, 2020 Share Posted October 30, 2020 You can't go wrong with SL-10 it will be step up from the pioneer. I have the SL-7 and even though I have a technics SP10 mk2 that SL-7 is great sounding for it's price Link to comment Share on other sites More sharing options...
Berkel Posted October 30, 2020 Author Share Posted October 30, 2020 Thanks for the advice. Do they have any inherent problems I should be aware of ? Cheers, Dennis Link to comment Share on other sites More sharing options...
Emsworth Posted October 30, 2020 Share Posted October 30, 2020 I’m an SL-10 owner and love mine, it’s a beautiful sounding deck and the aesthetics are outstanding. I also love that the compact dimensions mean I can fit it into a small area in my shelf unit. if it has the original EPC-310MC cart in decent nick then even better. If you have a lot of transparent vinyl you’ll need a special paper sheet to block the light sensors in the platter. There are some reports of a servo movement translating as a knocking sound while listening but I’ve never experienced this. I would check that the clasps that hold the cover closed are intact (and if you buy it use the side buttons to close as well as open the unit). I haven’t had to have mine serviced and the build quality is insanely good - but if one day I need to I would expect it to be a bit of a search to find a qualified tech. Having said that I also have an SL-5 which looks like a battered old prop from Star Wars and it’s still powering along. Link to comment Share on other sites More sharing options...
Emsworth Posted October 30, 2020 Share Posted October 30, 2020 Oh and I suppose some might say the scarcity of p-mount carts (especially high quality ones) is an inherent problem - and they’d have a point! Link to comment Share on other sites More sharing options...
t_mike Posted October 30, 2020 Share Posted October 30, 2020 Being a lineal with a relatively short arm, they can be susceptible to groove distortion on records with off centre pressings and huge changes is stylus rake angle if the record has warps. This is not indicative of the SL 10 alone, but all short arm linears. The SL 10 has a common fault regarding the operation of the arm on the slide rail, mainly caused by poor servicing. If there is too much drag on the rail, the servo motor will simply raise the arm and send it back to the rest position. The remedy is quite simple and can be carried out by anyone with basic hand tools. Other than the above, with good vinyl and cartridge, this is an outstanding performer. If you are ever having problems with the arm operation, PM me and I'll point you in the right direction to sort it out at zero cost. Link to comment Share on other sites More sharing options...
Berkel Posted October 30, 2020 Author Share Posted October 30, 2020 Many thanks gentlemen for your helpful comments. I'm more convinced that I should buy it ! Dennis Link to comment Share on other sites More sharing options...
